BMW M2 Forum > BMW M2 Discussions > is this AMP compatible?
      11-01-2023, 02:36 PM   #1
khanmohammed
khanmohammed's Avatar
Drives: BMW M4 CS
Hi guys the amp in my 2018 M2 went out from the water ingress issue. Does this amp work as a replacement?
      11-01-2023, 05:15 PM   #2
F87source
F87source's Avatar
Drives: Bmw M2
No that won't work, that's for the F8x m3/m4 - which has a different harmon kardon audio setup (different number of speaks, wattage etc), it won't fit on the m2.
You need this:
Part number: 65122622869
https://www.realoem.com/bmw/enUS/par...&q=65122622869
You'll likely have to get it coded as well.
      11-01-2023, 07:17 PM   #3
khanmohammed
Drives: BMW M4 CS
You need this:
Does it have to be coded even if it’s used?
      11-01-2023, 07:24 PM   #4
khanmohammed
Drives: BMW M4 CS
You need this:
Does this one work? Listing says F87 M2 with Harmon Kardon
      11-01-2023, 07:26 PM   #5
F87source
F87source's Avatar
Drives: Bmw M2
It depends on if the amp has differences in software or is a slightly newer model vs. the one you have.
Some people have said they didn't need any coding, some have said they required a firmware update. So it depends.
