09-03-2023, 10:02 AM | #1 |
Rep 40
Can anyone tell what is causing this noise?
Hi folks, I am getting a humming sound when turning right at speed (60mph+). Started by checking wheel bearing play on the left side. I cannot perceive any play when pulling/pushing at 12 and 6 clock positions. However, when rotating the wheel back and forth there is a clunk sound and cannot see any pad movement causing it. Is this coming from wheel bearing? Thoughts?
Here is a video of the sound: https://youtu.be/R6dqBXvvqZI?si=2eFxIxbdoS1HFTd2 |
09-05-2023, 01:40 AM | #2 |
Rep 4,261
Stones in brake shield?
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
09-05-2023, 10:56 PM | #3 |
Rep 40
I removed the pads and the wheel speed sensor and it is pretty much confirmed it is wheel bearing, not a pretty noise to say the least:
https://youtube.com/shorts/Xa0VDz3XV...Oc84hoB1CA_opa Ordered parts and now searching for torque settings for the wheel bearing hub, if anyone knows or can point me in the right direction, that would be great |
///MPhatic13862.50 Sparky68683.50 |
09-05-2023, 11:28 PM | #4 | |
Rep 97
Here are the torque specs: |
///MPhatic13862.50 |
09-06-2023, 08:22 AM | #5 |
Rep 40
Thank you, this is exactly what I was looking for. BTW, I am new to the M2, is there a recommended workshop manual to get or reference available in the internet?
09-06-2023, 11:01 AM | #7 |
Rep 40
I just got it, 2016 and 48k miles. I know the car jumped a curb which bent a suspension link and a wheel and did at least 2 track days.
I highly recommend folks spin the rotors when changing pads to check for noise. There is no perceivable play, yet it is evident the bearing is failing per the video above. |
09-06-2023, 02:38 PM | #8 | |
Rep 97
Also, do not blindly trust the torque specs you find on YouTube, most of them are guesstimates at best. With that said, one exception to this rule is FaRKle! , highly recommend you sub to his channel [1], he does great stuff and the torque specs he provides are from ISTA (or at least it was spot on for all the ones I cross-checked). [1]: https://www.youtube.com/@FaRKle0079 |
09-06-2023, 02:51 PM | #9 |
Rep 4,261
My rear right bearing went bad at 52,000
09-06-2023, 02:54 PM | #10 |
Rep 4,261
Intermittent droning between 60 and 80mph.
///M TOWN16539.00 |
09-07-2023, 10:48 AM | #11 | |
The Seeker
13863
Rep 3,323
09-07-2023, 12:48 PM | #12 |
Rep 40
Thank you all, I will circle back as soon as I change the bearing to report on what humming/droning noises go away as reference for others since I do not have a baseline (the car already had the bad bearing when I bought it).
///M TOWN16539.00 |
09-11-2023, 03:09 PM | #13 | |
16539
Rep 8,424
Yeah, it’s most likely from those two (+) track days Classic damage from hitting the curbside edge of the track aggressively
09-12-2023, 10:00 PM | #14 |
Rep 40
Thanks MTown, better to stay out of the curbs at ~$350 each without labor.
I replaced the left side. It was major improvement but I could still hear a faint similar sound. Checked the right side and it is also going bad. Weird that the sound is still when turning right, I read about someone had the same thing on a M235i. Just ordered parts…. again. |
7tune115.00 |
09-23-2023, 11:15 PM | #16 |
Rep 98
Threads like this are really important. There simply isn't enough info online for items like this going bad. I'm also having to budget for bearings on an 80k mileage OG and wanted to know the exact same things.
The rears look like a royal PITA and the hub design is garbage. BTW, you can add the Hoff to that video list... when you get past the intro. |
jefe2000739.50 |
09-24-2023, 01:51 PM | #17 | |
Rep 98
Can anyone explain what part numbers and parts are associated or why that even happened? I don't want to mess this job up buying parts I can't use. |
09-25-2023, 01:30 AM | #18 |
Rep 40
Since you have to replace the bolts also which screw directly on the new hub-bearing, you will be fine buying the latest part number. Here is what I ordered per side:
BMW Wheel Hub Assembly BMW-31207857506 Price: $317.99 QTY: 1 BMW Wheel Bearing and Hub Assembly Bolt BMW-31206872920 Price: $6.79 QTY: 4 BMW Brake Caliper Carrier Mounting Bolt BMW-34106864424 Price: $7.09 QTY: 2 |
7tune115.00 |
09-25-2023, 02:14 AM | #19 | |
Rep 98
09-26-2023, 04:53 AM | #21 | |
Rep 98
Too good to pass up. 👍🏻 |
