M2 Technical Topics > Suspension | Brakes | Chassis > Jacking up the M2
      09-04-2017, 12:31 AM   #1
V.Smurf
V.Smurf's Avatar
162
Drives: M2 LBB DCT (LCI) | X3 30i
Jacking up the M2
Hi All,
I'm intending to have a bit of fun fitting some cosmetic components to my new MY18 which is due in a couple of months. Some of these are going to require the car to be jacked up so that I can easily access the underside of the car (this is for the installation of an M Performance Rear Diffuser).
I've read the manual, and I can see the jack points documented ... but I wanted to use a trolley jack like this one to raise the car before lowering the car onto jack stands which I would position at the jack points.
My questions are:
  1. Do I need to purchase jack pads..? I've seen a few videos where these are referred to. As I don't have the car yet, I don't know whether it comes with pads (or not), and how essential they are.
  2. I've seen (again) youtube videos where BMW owners have roughly pointed to sections under the car where I should place the trolley jack ... but I'm reluctant to second guess where this would be on the M2.
Advice is most welcome!
Cheers,
      09-04-2017, 12:45 AM   #2
Prodigy.
Prodigy.'s Avatar
698
Drives: ///M2
Car does not come with jack pads so i purchased one from Burger Motorsports that i use in conjuction with my trolley jack to utilise the oem jack points. There are 2 jacking points on either side of the car.
Just be mindful when buying a trolley jack that it's advisable to buy a low profile jack so it fits underneath the car comfortably, especially with the jack pad on top.
http://www.burgertuning.com/BMW_jack_pad_adapter.html
V.Smurf162.00
      09-04-2017, 01:37 AM   #3
V.Smurf
V.Smurf's Avatar
162
Thanks Prodigy,
I'll order a couple from Burger Motorsports ... but I don't want (if I can avoid it) to jack up the car at the jacking points as I want to put the jack stands at these points.
The process that I think I would follow is using the trolley jack at a central point on the rear axle and jack up the car, before then lowering it onto the jack stands (which are placed at these jacking points) ... then moving the trolley jack out of the way so that I can work underneath the car. Does that make sense...? Hence the question about where I can jack the car with a trolley jack
Essentially I'm asking how to raise the car onto jack stands that are positioned at the jack points (i.e. I can't jack them at the same point as where I am going to place the stand).
Sorry for the noob question!
I've purchased one already, with exactly that mind The jack is 100mm high when fully retracted. I hope that's going to be sufficient ...? I couldn't actually find one that was lower than 100mm fully retracted.
      09-04-2017, 06:48 AM   #4
BAN_M2C
BAN_M2C's Avatar
4171
1987 BMW 325is  [10.00]
2004 BMW X3  [6.50]
2018 Porsche 911 GT3  [10.00]
1974 BMW 2002tii  [10.00]
2004 BMW M3  [10.00]
This thread helped me find the correct jack point and where to place jack stands.
Center lift point on rear? http://f87.bimmerpost.com/forums/sho....php?t=1306220
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii
V.Smurf162.00
      09-04-2017, 04:14 PM   #5
V.Smurf
V.Smurf's Avatar
162
Thanks BAN_M2,
That's exactly what I was looking for ... most appreciated!
I see that the jack pads that Prodigy has linked me too are not suitable for jack stands ... so I've got a few questions you may be able to help with.
From your reply on the post you've linked me too (where you've asked where to place the jack stands .. and you've included a super-helpful photo!), it looks like you've used the jack points ... so how did you place the jack stand..? Did you place the top of the jack stand directly into the jacking point, or did you put pads into the jacking point and then place the stand underneath...?
Really appreciate the help!
BAN_M2C4171.00
