04-06-2018, 08:32 PM | #1 |
Rep 207
Another Reason to HATE The F'ing ASD!!
Just yesterday the car started to continuously play out all sort of popcorn-popping and fabric-tearing sounds through the speakers, except it sounded much worse. This is happening independent of throttle and car movement. This is happening even when the ignition is off and the car is locked from outside. There's also a very loud white noise. I had the ASD coded off since I got the car 4 months ago. I recoded to its org backup to turn it back on to no avail. Took it to the dealer today and they said the ASD amp appears to be oxidized from winter salt bc there is a small opening to outside element. F'ing ASD POS that has no place in the car to begin with and it's now another thing to go gremlin. OMG, I want to find the asshat responsible for the ASD decision and lock him in the same room with the Dr. Pepper mini-me until his ears bleed. /end rant
Gone but not forgotten:
'14 Corvette Stingray (2014-2017) '05 Boxster S (2005 - 2014) '00 S2000 (2000-2005) |
9
04-06-2018, 08:49 PM | #2 |
Rep 6,981
Drives: 2018 M2 AW DCT
I agree with you. Wish the ASD would just disappear.
nachob2317.00 Die ///M Rakete671.00 |
04-06-2018, 08:57 PM | #3 |
Rep 488
Drives: M2CS
ASD??
04-06-2018, 09:18 PM | #6 |
Rep 488
Drives: M2CS
04-06-2018, 10:27 PM | #8 |
Rep 1,086
OP: Sorry this happened to you. Where is the hole the dealer said caused the water entry and corrosion? A battery vent? An uncapped water drain? A defect in the trunk weather-strip? Missing body sealer? For sure, it’s odd and not normal - but I’m suspicious of the dealer’s diagnosis.
04-06-2018, 10:32 PM | #9 |
Rep 1,459
04-06-2018, 10:59 PM | #10 |
Disrupter
1566
Rep 2,484
I coded mine off 10 days ago with Carly for BMW, and it's been gone ever since. I have no intention of coding it back on.
Disappointing People for Two Centuries; 3 Pedal Fanatic
04-06-2018, 11:02 PM | #11 |
Disrupter
1566
Rep 2,484
And you base this on what?
I'm not a believer in doing a lot of coding; I'll code off 2 or 3 things on a car and let it be, such things (in this case) as the ASD and Seat Belt Chime. I can see where someone would try to get each and every choice on each and every module exactly the way that they think they want it; I think that is a mistake. But a few codings are unlikely to screw anything up. What is the basis for your comment, if there is one, that is?
04-06-2018, 11:46 PM | #12 | |
Rep 207
Spa2k1195.00 |
04-06-2018, 11:55 PM | #13 |
Rep 4,554
Drives: 2015 328d xDrive
He clearly said the amp got physically damaged from salt and moisture.
04-07-2018, 12:10 AM | #15 |
Rep 207
Yes, the amp is f'ed and needs replacing. The service guy said "ASD amp" but now that I think about it, that amp likely powers all audios. If that is the case, this could've happened even without ASD unless the opening that he mentioned is ASD related. Still many unknowns but I will post concrete findings as I learn about them
04-07-2018, 12:16 AM | #16 | |
Rep 4,554
04-07-2018, 12:23 AM | #17 |
Rep 207
ASD sounds more like a hyena's roar. For a genuine lion's roar, sport cat is the answer imo
04-07-2018, 04:18 AM | #18 |
Rep 1,028
Have the M-Performance one
Burbles are nice but rest of exhaust is not very audible unless with windows or moon roof open. Drone also gets annoying on long trips I'd go catted downpipe but mpe with open valves already is pissing off my entire neighbourhood |
04-07-2018, 08:06 AM | #19 | |
Rep 340
04-07-2018, 08:28 AM | #20 |
Disrupter
1566
Rep 2,484
The ASD is auto-amputating itself, which is fitting, don't you think?
04-07-2018, 08:55 AM | #21 |
Rep 45
The last time someone thought that the ASD module got wet from the outside and destroyed itself found out that it was not the case. He thought that by power washing inside the fender wells that water somehow got onto the ASD through the vent.
It was later determined that when his windows were tinted, the tint shop used and I know they do, copious amounts of water that subsequently traveled down the electrical cabling and entered the ASD slowly killing it. I’ll bet your car is tinted. Btw, the best way to get rid of the ASD is the bypass harness. http://f87.bimmerpost.com/forums/sho....php?t=1436701 |
DanG10848.00 |
04-07-2018, 09:17 AM | #22 | |
Rep 207
