M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Hard wiring radar detector question
      06-20-2018, 01:46 AM   #45
ORIGIN M.
3161
Drives: ///M
Originally Posted by m2ruder View Post
Yes what Nezil said....I have the R3 and would like it up higher. Also with the type of mount that comes with it the unit vibrates up and down a lot when driving then when it is really hot the knuckle slips and lets the unit drop down in the back
I'm using the small two suction cup mount, up close by the head liner.
IMO it doesn't move very much using the smaller mount.
The large mount was laughably to large.
      01-02-2019, 12:27 PM   #46
MAMBA_M3
MAMBA_M3's Avatar
Drives: 2022 SPY G80 M3C Xdrive
All - Question on this. I am trying to pin the taps into the connector, but cant get it to actually fit into the connector. Am pushing beyond when the pin stops and still get it in there.
The fit is really loose and the pins for the hardwire just pop out easily.
Anyone else run into this and how did you fix it?
      01-02-2019, 01:35 PM   #47
DaveZ
DaveZ's Avatar
Drives: 2017 M2
Are you using MirrorTap? If so, I found that I had to try inserting the tap on one of the 4 sides of the factory lead depending on exactly how the factory wire was crimped to the connector. I documented my install at http://www.zeleznik-klein.com/m2/fixit/v1/index.html
DaveZ - http://www.zeleznik-klein.com/m2
2017 M2, Mineral Grey, DCT
      01-02-2019, 01:38 PM   #48
MAMBA_M3
MAMBA_M3's Avatar
I used radar mount which looks the same as what you used. You didnt have any issue with the pins just sliding in and sitting loose, ie not actually plugged into the connector?
      01-02-2019, 03:31 PM   #49
sobek305
sobek305's Avatar
Drives: xxx
Try orientating the tap on another side of the pin
      01-02-2019, 04:23 PM   #50
DaveZ
DaveZ's Avatar
Drives: 2017 M2
That's what I was trying to say, but it didn't come out as clearly. My brain-finger connection is still impaired from NY eve! So, try each of the four compass directions around the pin until you find a side that works. Since the blade is flat, one of these four positions around the wire should work:
Code:
|O|
