06-16-2023, 12:27 AM | #67 | |
Rep 7,509
06-16-2023, 12:35 AM | #68 | |
Rep 7,509
Here's an image (but alot of the tables are overlapped and covered up, but you can see in the pull down bar on the left the number of relevant tables there are, and note some of these 3D tables are massive and fall off screen): If indeed some tables are missing then I'm sure your tuner could talk to Dzenan from BM3 and he would have it added, otherwise you can now use any table editor you want and define your own tables via the DAMOS and an XDF file just like you would with MHD. This means you would be able to access some 50k tables on the ecu (most of which are unrelated to tuning but more for sensor calibration), so this issue shouldn't be relevant anymore.
AmuroRay2343.50 |
06-16-2023, 09:20 AM | #70 |
Rep 4,195
06-16-2023, 01:18 PM | #71 |
Rep 4,195
We are getting close - Part of me wishes I grabbed a TIC pipe and wrapped that as well as selectively wrapping parts of the intercooler itself. The reflective tape will hopefully keep IAT's down further.
He said he cut off an inch of it on each side of the charge pipe to make sure it sealed correctly. Last edited by AmuroRay; 06-16-2023 at 04:07 PM.. |
06-16-2023, 02:44 PM | #72 | |
Rep 1,071
Believe it or not installing the milvs I “lost boost” due to the car being more efficient. Thus turner the boost back up slightly to maintain torque throughout. Was peaking 24-25 at the time, after the install car was happy at 22 at peak to red line as torque and load was calculated to be achieved. I needed to have fuel added (expected with more lift) to the tune overall. I’ll be on the dyno within the next two weeks to officially have 93 + all the mods in my sig on a dynojet. Just trying to clean up sim random boost control/PID settings (causing a small throttle closure at the moment) before I spend time on the rollers. Aiming for 340whp+ on 93, and I hope to cross 390whp on e85. Not to derail your thread. But I did make 373 on 23psi with full e85, thus I believe my goal is achievable but we will see. Check my post history for the thread + post.
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
AmuroRay2343.50 |
06-16-2023, 03:06 PM | #73 | |
Rep 4,195
Do you have the before and after logs for me to look at? Have you tried plugging it into virtual dyno?
Mods: Yes.
06-16-2023, 03:12 PM | #74 | |
Rep 7,509
06-16-2023, 03:38 PM | #76 |
Rep 7,509
06-16-2023, 03:40 PM | #77 | |
Rep 4,195
What would that mean for us?
Mods: Yes.
06-16-2023, 03:51 PM | #78 | |
Rep 7,509
So it's not saying it'll be 12% more torque per say, but it's that he will be making more power and torque with less boost.
06-16-2023, 04:05 PM | #79 | |
Rep 1,071
Logs are too far apart for a before after comparison, didn’t actually log/dyno the car on 93ISH (e25 but with 93 trims) as our local 93 has been so inconsistent that e25 mix keeps things clean. Can do a comparison of full e85 to full e85 after milvs within the next 2 months or so
06-16-2023, 04:07 PM | #80 |
Rep 1,071
Share this link/app for virtual dyno. More than happy to plug it in and see what it outputs
06-16-2023, 04:15 PM | #81 | |
Rep 4,195
It's free, just plug data about your car in, upload your log and it can give you a comparison. It was pretty close for me.
Mods: Yes.
06-18-2023, 06:55 PM | #82 |
Rep 7,509
Wait, this just came to me but are you (or who ever is doing your spark plugs) using a swivel socket? Because the bmw spark plug well is angled, so you need to use a swivel socket because a straight socket puts too much strain on the plug or socket well and can cause damage.
06-18-2023, 07:11 PM | #83 | |
Rep 4,195
It will be a few more, because I ordered the AGA brake cable fix to be put on with the Midpipe for the exhaust. Super Sprint and AWE say the mid pipe is worth 10whp on its own - M and non M… |
06-18-2023, 08:50 PM | #84 | |
Rep 7,509
I kind of find it hard to believe that a mid pipe can bring 10 whp on its own but ok. Keep us posted with the results though!
06-18-2023, 11:57 PM | #85 | |
Rep 4,195
06-19-2023, 01:23 AM | #86 |
Rep 7,509
Yup that too, but generally it doesn't completely break the well, it'll scar it and scratch it. I can't even believe it broke - because that's a lot of force.
06-19-2023, 08:04 AM | #87 |
Rep 4,195
M135i/M235i
https://www.supersprint.com/ww-en/bm...-hp-2013-.aspx OEM: Claimed data: Horsepower 319,9 Hp @ 5800 rpm Torque 450 Nm @ 1300-4500 rpm Actual data: Horsepower 319,9 Hp @ 6250 rpm Torque 462,5 Nm @ 3140 rpm vs Supersprint: - Centre Pipe 988613 - Rear exhaust Right O100 + Left O100 988624 Actual data: Horsepower 330,9 Hp @ 6080 rpm Torque 469 Nm @ 2770 rpm Vs Supersprint: - Downpipe kit + Metallic catalytic converter (100 CPSI) 988521 - Front pipe 988612 - Centre pipe 988613 - Rear exhaust Right O100 - Left O100 988624 Actual data: Horsepower 347,9 Hp @ 6010 rpm Torque 486,2 Nm @ 2980 rpm
Mods: Yes.
06-19-2023, 11:14 AM | #88 | |
Rep 1,071
352 whp at 5676 rpm 386 wtq at 4000 rpm Mind you this was a 3800-7000 rpm 4th gear log, e25 in the tank with 93 fuel/timing trims.
AmuroRay2343.50 |
