02-03-2021, 12:44 AM | #1 |
Rep 108
Who's got the highest mileage?
Saw this post on the F80 forums and thought it'd be interesting to see the same here as I'm beginning to put lots of miles on the car.
I'll start; 2016 M2 just hit 51k kms and so far nothing wrong except drivetrain malfunction once. Excited to see who's got the highest score
02-03-2021, 08:20 AM | #3 | |
Rep 55
22k kms here, 2018 M2. |
02-03-2021, 10:31 AM | #4 | ||
Rep 108
I'll be doing spark plugs this weekend and will take a look at the ones in the car currently and see how they look. I suspect a bad batch of fuel, or just G forces causing possible fuel starvation, but I have no idea what was the exact cause.
02-03-2021, 12:37 PM | #5 | |
Rep 55
Perhaps you should report back to the dealer to have it on record before the warranty expires. |
///M TOWN18325.50 |
02-03-2021, 12:53 PM | #6 | |
Rep 568
You could have done some damage to the motor that won't be apparent until post-warranty, and having the dealer records reflect that this occurred during the warranty period could be very important. |
02-03-2021, 04:16 PM | #7 | ||
Rep 108
I guess I'll roll the dice and see how things go.. it happened conveniently after warranty just expired
VicF87OG72.50 |
02-04-2021, 12:18 AM | #8 | |
Rep 7,439
Also is your car modded?
02-04-2021, 08:11 AM | #11 | ||
Rep 108
02-04-2021, 09:29 AM | #12 | |
Rep 1,263
Have you pulled any codes hat were saved from your issue? Or were their none?
02-04-2021, 10:03 AM | #13 | |
Rep 108
That's all, cleared and never came back
02-04-2021, 10:18 AM | #15 |
Rep 1,263
Depending on how much fuel you had in your tank could have been a bit of water. Your doing the plugs, not much else to do prevent wise...
02-04-2021, 10:27 AM | #16 | |
Rep 108
02-08-2021, 12:21 PM | #18 |
Rep 2,136
40400 on mine as of this morning.
'20 M2C |
6speed_M23648.00 imperfectluck426.50 |
02-08-2021, 10:43 PM | #19 | |
Rep 1,619
02-11-2021, 02:58 AM | #20 |
Rep 447
I sold my 2018 M2 6-spd end of last summer that I had purchased to use as a rental car on Turo, which has about low 50k miles now and lives with a friend. Never a mechanical issue even with all the hard miles on it, did replace the clutch/flywheel at 45k miles but that was after 200+ rentals and some crappy manual drivers.
My buddy has a 2017 M4C DCT and 2018 M2 DCT on Turo both with nearly 60k hard miles and a 2019 M2C with about 30kish miles and also no mechanical issues. We wish our Shelby GT350's could say the same Needless to say modern M cars seem pretty stout. Here was my maintenance log on the 2018 M2 for anyone curious: 9/5/18 1,429 Oil Change- BMW 0w30 Diff Fluid Change- BMW 75w140 1/24/19 9,337 Oil Change- BMW 0w30 (CBS #1) 3/7/19 11,780 Tires- Michelin Pilot Sport A/S 3+ 6/19/19 19,466 Oil Change- BMW 0w30 (CBS #2) E-brake Adjusted Cabin Air Filter Replaced 8/20/19 23,884 Rear Tires- Michelin Pilot Sport A/S 3+ RR Genuine BMW Wheel 10/25/19 27,605 Oil Change- BMW 0w30 (CBS #3) Spark Plugs- Genuine BMW Engine Air Filter Replaced Key Battery Replaced RR Tail Lamp Replaced (Warrantied) Exhaust Actuator Clip Replaced 11/1/19 27,787 Four Wheel Alignment 1/8/20 31,858 Front Brake Pads & Sensor- Genuine BMW LR Tail Lamp Replaced (Warrantied) 2/11/20 33,506 Front Tires- Michelin Pilot Sport A/S 3+ 3/24/20 35,944 Oil Change- BMW 0w30 (CBS #4) Key Battery Replaced Cabin Air Filter Replaced 5/12/20 38,765 Rear Tires- Michelin Pilot Sport A/S 3+ 6/12/20 41,180 Rear Brake Pads & Sensor- Genuine BMW 7/30/20 44,889 Oil Change- BMW 0w30 (CBS #5) Trans Fluid Change- BMW 75w80 DIff Fluid Change- Castrol Syntrax 75w140 Brake Fluid Flush- Castrol Synthetic DOT 4 8/26/20 45,459 Flywheel & Clutch Replaced
2020 M2 CS AW 6-spd
Previous M Cars: M2C, M2, F80 M3, E46 M3, Z3M Coupe, E36 M3...and some other fun rides. Last edited by windnsea00; 02-11-2021 at 09:35 PM.. |
GTIGUY1992128.50 ROASTM163.50 |
02-14-2021, 09:27 PM | #21 | |
Rep 222
ROASTM163.50 |
