02-15-2021, 04:32 AM | #419 | |
Rep 931
02-17-2021, 05:05 AM | #420 |
Rep 1,977
Drives: 2020 M2C HS & Ferrari Roma
What a difference these coilovers make, currently set to BMWs recommended settings
595 front 600 rear (Maxxed out rear) It does seem a tad lower than I'd like, I may raise it to 600 front 605 rear once they settle in. Definitely no regret in getting these however, instantly feel the difference when I drove it post install
2020 M2 Competition | Hockenheim Silver | 437M Wheels / 763M Wheels | RHD | 2NH Brakes OEM M2 CS Steering Wheel | MP Carbon Steering Wheel Trim | MP Pedals | MP Dash | MP Interior Kit OEM M2 CS Bonnet | M Performance Coilovers | MP Rear Spoiler | MP Rear Diffuser| Perl Carbon Front Lip | Remus Race Exhaust |
02-19-2021, 06:23 AM | #421 | |
Rep 8,665
02-19-2021, 08:51 AM | #423 |
6643
Rep 4,145
Drives: '18 M2 6MT
I can't say enough about how good they are. Yes, the spring rate causes more movement than the stock suspension, and I wish that wasn't there, but the ride is so much more compliant (no more crash!) that it's easily worth it.
One of the best mods I've done to the car for sure. |
ASAP10232.50 |
02-19-2021, 09:13 AM | #424 | |
Rep 8,665
Is the car generally stiffer hence naturally it will move more over a bump...? Or Is it more bouncy like a pogo stick due to not good rebound? Will it jump over bump? If you drive over a bump does the rear end feel like it will take off? I know it's hard to qualify in words but the 2nd option above would sound terrible to me. |
02-19-2021, 10:07 AM | #425 | |
6643
Rep 4,145
Drives: '18 M2 6MT
ASAP10232.50 |
02-19-2021, 11:17 AM | #426 | |
Rep 3,009
So I guess my point is if you want to keep everything you like about the M2 suspension but get rid of the crashing the MPS will help but you may "notice" more of a bounce over some roads. |
ASAP10232.50 |
02-19-2021, 02:22 PM | #427 | ||
Rep 8,665
02-19-2021, 06:30 PM | #429 |
6643
Rep 4,145
Drives: '18 M2 6MT
02-20-2021, 10:04 AM | #430 | |
Rep 1,389
Oh but it's stiffer too and you feel bumps more?! Seems mutually exclusive. I don't get it. |
02-20-2021, 11:57 AM | #432 | |
6643
Rep 4,145
Drives: '18 M2 6MT
Let me explain it using the stock M2 suspension as an example. The stock suspension felt very tight, but soaked up a lot of road cracks and bumps without any movement. However, when there was a larger crack or bump, the movement of the car was jarring, what I call "crashy." And in mid corner, encountering a larger crack or bump made the car feel unsettled. Upon swapping to the MPS I found that I could feel more of the cracks and bumps in the road, like the car was moving me up and down more than it was with the stock suspension, but the top and bottom of those movements felt like they were more in control, and ultimately softer. And the same larger crack or bump in mid corner didn't make the car feel unsettled at all. So it looks like this. Stock suspension: less up and down movement, but when the movement exists, it's harsh. MPS: more up and down movement, but softer, and overall more controlled. Yes, weird, but yes. The reason for this change is that the spring rates got stiffer, but the damping got better. What would be perfect for me? Stock spring rate with MPS damping. Can that be had? Not that I've found. |
TrentMeister2950.00 |
02-20-2021, 03:11 PM | #433 | |
Rep 1,389
Cheers thanks that helps. I think the Litchfield will be like this as they use their own Spring which is custom made and the mission statement from them is slightly softer than stock. The dampers from Bilstein or Nitron are then custom valved. |
02-20-2021, 03:55 PM | #434 |
Rep 4,528
Yes.
I took the car to get the mperf coilovers set up fettled and set up properly. I bought adjustable end links. Once the cars ride height was set and corner balanced, the oem end links were refitted without any issue.
Current '22 X3M LCI.. |
02-20-2021, 04:10 PM | #435 |
847
Rep 1,962
Interesting. Should be possible to fit those to other C/O...
02-20-2021, 04:52 PM | #436 |
6643
Rep 4,145
Drives: '18 M2 6MT
I did quite a bit of research before buying the MPS, and checking the spring rates was a nightmare. Some were progressive, some linear, but all were more aggressive than stock. If the Litchfield's are going with a softer spring rate, I would have considered them more. Overall I'm very happy with my MPS, but will be very interested in hearing how the Litchfield's play out.
02-21-2021, 07:30 AM | #437 | |
Rep 1,977
You do feel the imperfections and bumps slightly more however it is not intolerable. Although you feel the bumps more, I personally feel like it absorbs them better. When you really start getting on it, that's when the difference becomes more obvious, much more composed in the corners and confidence inspiring. Definitely more positives to getting these coilovers than negatives. Here are some pictures after the springs settled after 500kms of driving, I wouldn't wanna go any lower than this so I think BMWs recommended setting is perfect.
4
02-21-2021, 09:18 AM | #438 |
Rep 8,665
Thank you... the only real answer is to drive a car with them... and see if I see a noticeable improvement.
What I am really looking for is less pogoing over bumps and much more settled rear over bumps... |
03-01-2021, 09:02 AM | #439 |
Not great. Not terrible
7452
Rep 2,700
After hmming and hawing and reading, I set up an appointment to have this installed by a dealer on Monday. I think this will be a great performance upgrade for what I like to do, twisties in the mountains. I don't need more HP for that.
Can't wait!
Current: 2024 BMW X3 M40i.
03-01-2021, 02:32 PM | #440 |
Rep 1,389
Congrats let us know how to get on.
