01-28-2021, 03:10 PM | #135 |
Rep 7,468
Well for the transmission IIRC bmw says it's life time but that is not true, generally I do it every 4 years because my car is a lower mileage vehicle but if you drive it alot then I would recommend every 48k km - 50k km or less. For the differential bmw recommends doing it every 5 years or 50k miles, but I do it every 4 years.
08-19-2021, 09:26 PM | #136 |
New BMW owner
326
Rep 844
Mine's a grey market import CDN car but i don't think the first owner even had it serviced except for the first oil change.
Should I change the Diff? Look for MSP/A (75-140w). 2 liters. Drain and fill until it overflows. Holy cow it's 70$ a liter here. Is there an alternative for this? The Castrol one? Should i also change the 6MT oil?
08-19-2021, 09:39 PM | #137 | |
Rep 7,468
Yes you should also change the 6mt oil. If you can't get MSP/A then get SAF-XJ, if you can't get that then get the castrol syntrax limited slip 75w-140. you also need a new drain and fill plug for the diff, the O-rings are one time use and if you reuse the plugs you risk a leak which can take out your diff.
08-19-2021, 09:50 PM | #138 |
New BMW owner
326
Rep 844
I read on one of your posting you were thinking of using the Redline transmission oil before? Would you still recommend that? or stick w/ the LT5?
I have better access to these type of fluids than BMW. Amsoil, Redline, R Purple, ....Castrol (not so popular here) but myb there is.
08-19-2021, 10:55 PM | #139 | |
Rep 7,468
For transmission it's alot more flexible, I would have gone redline dctf if given the choice, but it was out of stock so I went with oem.
08-20-2021, 02:09 AM | #140 |
New BMW owner
326
Rep 844
Great! I actually have access to that redline DCTF so I'll use that. Thanks
08-20-2021, 02:16 AM | #141 |
Rep 7,468
No problem.
08-22-2021, 09:06 PM | #142 |
New BMW owner
326
Rep 844
Just wanted to share what I found that would be pretty close to doing this.
Sungillest101.50 Daytona_550466.50 |
08-30-2021, 06:41 AM | #143 |
Rep 186
Drives: 2017 BMW M3 Competition (LCII)
I got curious if my 2017 LCI M2 got the correct differential oil and looked it up in the service history. Luckily I found that MSP/A was used (part number 988).
09-20-2021, 09:52 AM | #144 |
Rep 155
I'm changing my diff oil at 20k km because my m2c is tracked often. Around 10 track days a year.
Any ideas of Motul Gear Competition SAE 75w140 (GL-5) is fine? It isn't msp/a, but it says it's above oem standards. |
09-20-2021, 12:05 PM | #145 | |
Rep 1,489
Transfer case is the one that you want OE BMW fluid if xDrive. In DCT I would also stick to OE BMW fluid. |
09-20-2021, 12:40 PM | #146 | |
Rep 1,644
Edit: tds shows they are different. |
09-20-2021, 01:34 PM | #147 | |
Rep 7,468
For example these diffs early in their life cycle had excessive clutch pack wear issues that were so bad it necessitated a recall and stop of delivery in 2016 for a diff recall. These diffs also demonstrated they were extremely fluid sensitive in certain cases when saf-xj + FM was used (this was the e9x ///M diff oil) the diffs would fail rapidly. So after the recall bmw also changed the stock fluid requirements to msp/a. So this is why I would only use the OEM fluid for the diff to avoid upsetting this extremely finicky diff, and also because aftermarket fluids don't just cater to bmw's fix m diff. They also make it work with the e9x M diff (which requires alot more friction modifiers and known to be too much for the f8x diff) and diffs from other cars. So honestly it might not be the best idea to use after market diff oils on this car. I know Castrol syntrax limited slip diff was approved on ista, but when I contacted Castrol I was passed through their customer service chain and no one could find bmw approvals and they did tell me they reformulated to a higher spec. So Im also worried that fluids could change and ista always lags behind so you might get a fluid that's now lost approval and incompatible.
09-20-2021, 01:48 PM | #148 | |
846
Rep 1,962
Obvs, if they did as my dealership did and filled the LSD with SAF XO and no FM at the RIS, that 'might' be a Bad Thing... |
09-20-2021, 02:43 PM | #149 | |
Rep 7,468
https://www.fcpeuro.com/products/bmw...rs-83222282583 As far as I know for open difs they don't need friction modifiers at all, because they don't have the clutch packs that need to engage and disengage to control slip. So saf-xo is just standard gear oil. That would be really bad for an LSD in creating excessive wear over time. If you had tracked it I would be certain your diff wouldn't have survived, since track conditions require the LSD to function constantly as you transition from corner to corner and accelerate, also the diff would get insanely hot which doesn't help with wear either. But yeah you're not the first person I've seen who had saf-xo put in their diff. I just can't believe how incompetent some dealerships are - which is why I check all service sheets and part numbers before I leave the lot.
09-20-2021, 02:52 PM | #150 | ||
Rep 1,489
F87source7302.00 |
09-20-2021, 03:16 PM | #151 | |
Rep 7,468
But in regards to motul, maybe they certified it in early 2014 with the m3/m4 and didn't update anything when the huge recall and fluid changes came in 2016.
09-20-2021, 03:54 PM | #152 | |
846
Rep 1,962
09-20-2021, 04:39 PM | #153 |
Rep 7,468
Correct (open diffs don't have clutches that actuate constantly like an LSD so no need for fm in the oil, it also generally doesn't get aso hot so lower weight oil for less drive train loss as well), it comes with a certain amount of friction modifiers which the clutch packs in an LSD require hence making it suitable for the LSD. XJ is also a heavier weight oil vs. conventional open diff oils again making it suitable for LSD's hence why you wouldn't want to run saf-xo on the f8x e-diff, as it's not only too thin but it doesn't have the correct friction modifiers. So it's really a double whammy in terms of excessive wear to your diff gears and clutch packs - especially if you track the car because the e-diff is really in action on the track and it gets hot AF and with a thinner oil like xo and the lack of FM I'm sure the diff would blow out rapidly.
Now the difference between LSD oils tend to be the amount of FM added, with the e9x it needed alot of FM or else there would be clunking or loud noises coming from the diff. So that's why saf-xj + FM exists, so it could have that extra booster of FM needed for the e9x. Some LSD's have more tolerant clutch materials making it able to tolerate a wide range of FM's without having issues like the GTR but some LSD's like the f8x e-diff blow up easily with the wrong fluid. So it's probably a better bet to stay oem diff oil with this car. Manual transmission seems to be fine (reported to be even another with redline dctf) with different aftermarket gear oils though so that's a plus. With a dct I don't know, so do your research carefully.
