M2 Technical Topics > Suspension | Brakes | Chassis > Monoball Bushings on the M2C
      05-20-2020, 02:03 PM   #45
M Fifty
844
Drives: M2 & 330CI
Originally Posted by Big Fabri View Post
stainless steel
Are you familiar with the term "electrolytic corrosion"?
If it never sees winter road salt, or there are passivating washers fitted between the bushing and the (aluminium) subframe, you have nothing to worry about.
      05-20-2020, 02:04 PM   #46
Big Fabri
Big Fabri's Avatar
Italy
95
Drives: Lamborghini Huracan
stainless steel
There are washers 😉
M Fifty844.00
      05-22-2020, 07:42 AM   #47
2020M2Competition
2020M2Competition's Avatar
429
Drives: Yes
Does anyone have any thoughts on these tension arm bushings from Rogue Engineering?
https://www.rogueengineering.com/Rog...F8X_p_101.html
I was wondering if they might be a little more street friendly alternative to a monoball arrangement
      05-22-2020, 09:26 AM   #48
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
RE link you posted is essentially solid metal bush with poly (AFAIK) inserts and I'd say these are serviceable/sacrificial.
These from RE are more matched to OEM mballs bmw fit in LCA and sealed for longevity ie more fit n forget solution.
https://www.rogueengineering.com/Rog...X-Z4_p_96.html
Current '22 X3M LCI..
      05-22-2020, 04:31 PM   #49
2020M2Competition
429
Drives: Yes
Thanks for the input Bee Pee
My next 2 mods for the track are going to be front tension arm bushings (or monoballs) and camber plates
A lot of people that install monoballs in the front tension arms claim no added NVH whatsoever while others do notice an increase in NVH
The same is true of camber plates
In any case, I'm hoping to keep any additional NVH to an absolute minimum
That is why I'm considering some of the bushing instead of bearing alternatives such as the Rogue Engineering front tension arm bushings I mentioned above as well as the Millway street camber plates
https://www.millway.se/camber-plates...mw-m2c-m4.html
Bee Pee1779.00
      05-22-2020, 04:44 PM   #50
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Sub'd for any feedback once you've fitted TS bushes and CP's✅
      05-22-2020, 06:44 PM   #51
McLaren720s
McLaren720s's Avatar
Drives: 2024 M4 Competition X
I have the Turner Monoball Thrust Arm Bearing Set on order and will report back in a week or so once they get installed.
Can someone explain the difference between Tuner monoballs:
https://www.turnermotorsport.com/p-3...oball-upgrade/
and Millway monoballs:
https://www.millway.se/front-control...4-f82-f83.html
      05-22-2020, 07:21 PM   #52
2020M2Competition
429
Drives: Yes
The Millway monoballs in your link are not sealed
However, they do offer a sealed version
Turner supposedly uses an OEM BMW ball joint whereas I have no idea what Millway uses
The Turner uses a locking ring while the Millway uses a machined cap and hardware as additional security measures
Beyond that I can't really comment
      05-22-2020, 08:04 PM   #53
2020M2Competition
429
Drives: Yes
Ordered
Rogue Engineering Front Tension Arm Bushings with Black (Street) Durometer "Urethane-Silicone" Bushings Preinstalled in OE Arms (Tension Struts)
Millway Street Camber Plates with Polyurethane Bushings
LBBFTW9.00
      05-23-2020, 03:40 PM   #54
Big Fabri
Big Fabri's Avatar
Italy
95
there are 2 version of those. street and track. i recommend you get the street. first of all the monoball are sealed. so no dust on the long therm also the camber plates have busgin instead of a bearing. the bearing will support all the strees once driving resulting in a failure. the bushing has elastomer inside and so it will be absorbing stress. alothough the monoball are the same, the plates are not as precise as the bearing due to the eleastomer. it's a minor thing, but when racing everything counts
      06-04-2020, 07:33 PM   #55
McLaren720s
I just had the Turner tension strut monoball bushings installed and, while I haven't been able to drive the car hard yet due to traffic, it seems like a nice improvement over factory rubber bushings. Steering seems more "confident", direct, more responsive, a bit more communicative over certain types of pavement and a lot of the 12 o'clock dead spot seems to be reduced.
Looking forward to the next track day with these installed!
bentom2335.50
      06-14-2020, 09:29 AM   #56
Ilikemike
Ilikemike's Avatar
251
Drives: E92: F82: M2C: M2 CS (Now)
Has anyone installed/upgraded the front bushings on the M2 to the Monoball spherical design?
They are supposed to really improve steering response, turn-in and feel.
Example:
https://ind-distribution.com/product...conversion-kit
I had the Dinan mono ball on my M4 and can honestly say I noticed no difference in handling or feel, but there were annoying clicking sounds when backing out of my driveway, after about six months. Probably a great track modification, but personally I can't say because I don't track the car. Most of the modifications seem to really shine when you're at 9/10ths. Good luck...
      06-14-2020, 02:42 PM   #57
McLaren720s
Well I just had the Turner monoballs installs and I think they make a fantastic difference with zero NVH so far.
Bosozoku693.50
      06-17-2020, 06:28 PM   #58
M2guru
2018 BMW M2  [10.00]
Help needed: I can't get the ball joint of the Thrust Arm/Tension Strut out of the wheel hub in order to upgrade the monoball. Any tips from someone who has done it? The ball joint removal tool doesn't fit well in there. TIA.
      06-17-2020, 11:26 PM   #59
bentom2
It isn’t a press fit like most ball joints. I don’t recall any extraordinary offers to separate it from the hub. At most we put the nut back on and rapped on it a couple times with a hammer. We were unsure about doing the monoballs in the garage, so if we encountered any trouble, we would’ve skipped it and just focused on the coilovers, which was the primary job I recruited my friend to lend a hand with.
I have a pair of loose torque arms if pictures help. Just let me know and I’ll take a couple.
M2guru383.50
      06-18-2020, 04:27 PM   #60
M2guru
2018 BMW M2  [10.00]
In case anyone else has this problem, PB Blaster worked great for ~24 hours. It came out without using the ball joint remover - just a big hammer. I did end up bending the ball joint yesterday thanks to the bad angle on the ball joint removal tool and I tore the swaybar end link boot, so I have some additional parts to buy now.
      06-22-2020, 04:01 AM   #61
MR RIZK
MR RIZK's Avatar
758
Drives: AW M2C
Fuck me never seen anyone bend that before on any car. Well done 👍
Jokes aside least you got it out. Maybe buy the turner ones pre-fitted since you need to buy a replacement arm anyway.
M2guru383.50
      06-23-2020, 11:32 AM   #62
M2guru
2018 BMW M2  [10.00]
So, I did end up buying a new arm and installing the Turner Motorsports Monoball in the new arm. Here's an installation video in case anyone is contemplating doing the same:
Cost comparison:
Harbor Freight 12-ton Press (yours to keep!): $140
Front Wheel Bearing Press Kit (yours to keep!): $75
Monoball bearings: $330
TOTAL: $545
Preinstalled version: $598
      06-27-2020, 05:02 PM   #63
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Bimmerworld TS/UCA m'ball on track today. Felt good and no doubt will feel even more benefit once I upgrade to front BBK
bentom2335.50
      07-21-2020, 12:18 AM   #64
Bosozoku
Almost completely sane
Bosozoku's Avatar
Drives: '17 M2, '00 S2000
Installed the Turner Monoball Thrust Arm Bearings about two weeks ago, and I think it was worthwhile. Just calmly puttering around on the street, there is a small but noticeable increase in the crispness of steering turn-in and braking. There is also a small but noticeable increase in the amount of vibration coming through the steering wheel, but to me this is better road feel. It's never annoying - not even over really rough roads. Sometimes I'll get in and drive and forget about the mod until the first turn. (People complain about the electric power steering removing feel - but I think it's all the rubber in the front suspension.)
If you flick the wheel over hard at moderate speeds like you do in an autocross, the car simply points right there and goes. The stock rubber bushings compress and rebound just a little, so there's a tiny fraction of a second of recovery. That goes away with the Turner monoballs.
I also did a track day at Laguna Seca on Friday 7/17, and there was a much bigger improvement in the car's overall feel. As you'd expect, because the turning and braking g-forces were much higher than in casual street driving. For example, under v-max braking into turn 2, the front end was more solid and less squirmy, with better precision on turn-in. (But the rear fishtailed a little on brake application AND release. I was on old thin Hawk DTC-60 pads in Sport+. WTF.) New personal best by 0.8 seconds with no other mods and being really rusty.
So yes, I'm happy. Perfect tradeoff of improved response and road feel for only the tiniest increase in NVH. No extra N or H. Just a tiny bit more vibration.
'17 BMW M2 (BSM 6MT Exec CarPlay, TechnicPnP ASD bypass, IND M Perf shift knob + keyhole cover, Pedal Haus pedals + heel plate, 3M CR90 tint, BavSound Ghost woofers, Racing Dynamics strut tower brace, Dinan midpipe, Turner intercooler)
'00 Honda S2000 (Silverstone Metallic, black leather, factory titanium shift knob + front lip + trunk spoiler, front shock tower brace, front subframe x-brace)
      07-26-2020, 04:40 PM   #65
onesixeight
Drives: F82 M4/i8
For those that did the install yourself, were you able to remove the thrust arm bolt and nut by just removing the underbody plastic shield just forward of the front arches?
Thanks!
      07-26-2020, 05:02 PM   #66
bentom2
Thanks!
I also pulled the fender liners since I was doing coilovers and end links at the same time. If you find they’re in the way, it wasn’t too much additional work to pull the liners. Access wasn’t bad with both removed.
