05-14-2020, 11:34 AM | #1 |
Rep 1,286
Monoball Bushings on the M2C
Has anyone installed/upgraded the front bushings on the M2 to the Monoball spherical design?
They are supposed to really improve steering response, turn-in and feel. Example: https://ind-distribution.com/product...conversion-kit
05-14-2020, 12:11 PM | #2 |
844
Rep 1,962
They are also supposed to make for very noisy driving experience. Fine for regular track days, maybe not for daily use.
Edited: Like this.https://f87.bimmerpost.com/forums/sh....php?t=1716822 Hopefully this isn't (yet) another instance of me messing up a perfectly good marketing attempt. |
05-14-2020, 01:47 PM | #5 |
844
Rep 1,962
Separately, if you want to fit them, why not go for the BMW items?
https://www.realoem.com/bmw/enUS/sho...diagId=33_2163 |
cncmastr1590.00 |
05-14-2020, 05:36 PM | #6 |
Rep 1,286
What brand?
05-15-2020, 01:05 AM | #8 |
Rep 1,286
05-15-2020, 06:25 AM | #9 |
Rep 251
pay attention. those are great if you track but you don't want these for the street. they tend to be noisy,you want to get the dinan or millway since they are sealed against dust. If a track car is noisy, nobody cares, but for daily you must lubricate them very often. The product itself its great. i have all the uniball conversion in my gt3 rs and it's an maazin mod. just not for street. i have millway street in my m2 competition and it is perfect.
instagram: https://www.instagram.com/big_fabri/?hl=it
05-15-2020, 07:25 AM | #10 |
Rep 1,664
sly1types431.50 |
05-15-2020, 07:50 AM | #11 |
Dom
1080
Rep 1,718
I had 2 different setups on my e92 M3. First I had the Dinan monoballs which were sealed. Zero additional NVH.
The second setup I had were the front tension struts from SPL Parts (Had the full SPL ARM conversion front and rear). Not sealed, geared towards track. Zero change in NVH from Dinan Monoballs. Also to add, they did not give me any issues at all from street driving. I will be going SPL Parts arms again on the M2C. |
05-15-2020, 08:03 AM | #12 |
Rep 4,516
Folks,
my understanding is that oem F8x lower control arm - LCA - already has a m'ball bush fitted as standard. The tension strut aka upper control arm - UCA - has a solid rubber bush from factory and so upgrading UCA bush to m'ball is worthwhile but not sure why folks would want to swap an oem m'ball for an aftermarket m'ball ??? Hence, I'm aiming at B'world UCA as its alledgedly same/similar to oem LCA m'ball and should stabilise the front end geo under braking/turn-in by taking out deflection from rubber mounts. https://www.bimmerworld.com/Suspensi...Bearing_2.html BP PS - word of caution on the adjustable poly bushes linked in one of the posts above, feedback from users is that these have a tendency to roll the inner eccentric bush as poly bush part wears. No great.
Current '22 X3M LCI.. Last edited by Bee Pee; 05-15-2020 at 08:09 AM.. |
05-15-2020, 08:18 AM | #13 | |
Rep 1,664
05-15-2020, 09:02 AM | #14 | |
Dom
1080
Rep 1,718
The LCA or Wishbone seems to have a rubber bushing per my experience and found online. The UCA or Tension Strut is seems to have a rubber bushing per my experience and found online. Again, you'd be amazing on how my car transformed without additional NVH with full spherical SPL Arms. Also, with these arms, I had a wide adjustable range. I think the net is that upgrading your bushings is better than stock, ultimately it's your choice. I personally have never tried these Bimmerworld ones but it is sealed like Dinan and will do the same thing. Plenty of options out there. Also, I agree with you on the Poly parts. |
Heronween0.00 |
05-15-2020, 09:49 AM | #15 |
Rep 1,263
I just ordered the Bimmerworld bushings. Will report back after a few Auto X and track days...
2004 Mazda Rev It Up Finalist 2002-Present HPDE Instructor My 2020M2C Build: https://f87.bimmerpost.com/forums/sh....php?t=1696726 Last edited by SEAT TIME RULES; 05-15-2020 at 01:58 PM.. |
sly1types431.50 |
05-15-2020, 10:04 AM | #16 |
Rep 427
I went with the Turner thrust arm monoball, which they offer preinstalled in an OEM thrust arm.
https://www.turnermotorsport.com/p-4...nstalled-arms/ Their monoball uses an OEM ball joint, which is sealed, so should remain quiet. I have a few thousand street miles, but only two track days on them ( pacific raceways) since replacing over the winter. I changed to coilovers and rear toe links at the same time. There’s a bit more road noise overall, but probably less than the increase from adding camber plates on stock suspension. Not sure where to attribute the added noise with all the changes. On track, turn in feels much more immediate, but again, hard for me to say whether that’s the monoballs. High speed braking feels much more confident. The car used to move around quite a bit when dropping anchor at the end of a long straight into a mid or low speed turn (13x mph -> 6x mph), which was the main reason I installed them. The monoball being preinstalled in an arm was nice for DIY. Made for a quick swap while doing the coilovers. I’m hoping to be back on track (the ridge) this Sunday. There’s one turn at this track with a cambered braking zone, and the camber plus braking used to try to pull the wheel out of my hands. I’m interested to see what affect the monoballs have here. Hopefully we get some dry time. |
McLaren720s1476.00 |
05-15-2020, 10:15 AM | #17 | |
Rep 1,286
05-15-2020, 12:04 PM | #18 | |
Rep 4,516
https://www.turnermotorsport.com/p-1...necontrol-arm/ Extract from above TMS link "Product Details This is the left front lower control arm (also called a wishbone by BMW) for the F80 M3, F82 M4, and F83 M4. This can also be used as an upgrade on the F22 2-series and F3X 3/4-series. The M3/M4 control arm features a sealed inner and outer ball joints that are superior to elastometer rubber. The ball joints on the M3/M4 wishbone give a more precise feel and allow the control arm to move freely without resistance and with minimal deflection."
Current '22 X3M LCI.. |
05-15-2020, 12:09 PM | #19 | |
Dom
1080
Rep 1,718
Bee Pee1779.00 |
05-15-2020, 12:19 PM | #20 |
844
Rep 1,962
Looking at RealOEM, there don't appear to be any rubber bushes between the rear subframe and the body shell on the M2 - unlike the E9x. As such, that you didn't have any NVH issues with the latter when running something other than rubber bushed suspension links is not totally surprising.
Let us know how you get on. |
05-15-2020, 12:31 PM | #21 | ||
Rep 4,516
