M2 Technical Topics > Suspension | Brakes | Chassis > Monster DIY: KW V3, torque specs, re-indexing, spacers, alignment, coilovers install
      04-07-2019, 02:02 PM   #45
M Fifty
844
Drives: M2 & 330CI
Okay, that could be a workable approach to torquing the Torx on the aluminium brace...
      04-18-2019, 10:40 PM   #46
mleroux
Drives: 2017 BMW M2
Update. I installed my Eibach springs and it went fairly smoothly. I decided to have the dealer re-index all the bushings for me but we ran into a snag with the rear upper control arm bolt/nut. You can't properly re-torque this nut without dropping the subframe (no clearance for a torque wrench and I don't think the crows foot fit in there either...
How did you guys manage this?
      06-07-2019, 11:25 PM   #47
jcarr343
Drives: 2018 F87 M2
Does anyone have a SKU for the strut pinch bolt? I cannot seem to find it.
      06-08-2019, 03:12 AM   #48
M Fifty
844
Drives: M2 & 330CI
https://www.realoem.com/bmw/enUS/sho...diagId=31_1121
      06-13-2019, 10:19 PM   #49
jcarr343
Drives: 2018 F87 M2
I started my install this evening and ran into a issue. When removing the rear camber bolt, I made a mistake and may have ruined the camber control arm. The material towards the end of the arm is now bent/torn. I assume this needs to be replaced...?
      06-14-2019, 01:47 AM   #50
M Fifty
844
Drives: M2 & 330CI
It's not structural - it's just there to help adjust the position of the camber bolt.
      06-14-2019, 06:44 AM   #51
Caduceus
342
Drives: 2008 135 (sold), 2017 M2
I bet you swore when you did that. Never mind, M Fifty is right - the lip is not structural and the suspension isn't going to fall apart or be unsafe in any way. It's the torque applied to the eccentric both that holds it in position. The lip just gives the cam on the head of the bolt something to press against when making adjustments. Even if the lip shears off, you will still be able to adjust the bolt and get it aligned.
In fact, depending on how the bolt ends up being orientated, it may not even come in contact with that lip at all.
      06-14-2019, 07:55 AM   #52
jcarr343
Drives: 2018 F87 M2
Thanks for the help, I reinstalled the arm.
Finished everything up tonight, and the front height setting is perfect. The rear did not drop at all... I hope I don't have to pull the camber and shock bolts to make an adjustment? That would be a major pain.
      06-15-2019, 09:43 AM   #53
M Fifty
844
Drives: M2 & 330CI
Can you take some pictures of the rear spring perches?
KW recommend removing them to make adjustments, but with the wheel off you may be able to wind them back.
      11-17-2019, 09:30 PM   #54
m2rs4_official
Thanks
Originally Posted by Mosely View Post
Regarding the lube thing, I meant just for adjusting the perches. A little degreaser afterwards to clean things up, agreed you don't want to attract dirt but it also doesn't matter once you're happy with height. Next time I take them off will be if they fail or when I sell the car/upgrade coils and KW even include the instructions on cleaning above the perch, then slide up and clean below, before making large adjustments. Thinking about it actually, I'd rather a little dirt stick to a non-moving part than rust develop.
Not sure why KW recommend removing to adjust, its quite easy once you get it moving to do it on the car and the only thing turning is the adjustment collar.
Edit: Here is the final stance, just a quick cell shot
Cheers for the comprehensive write up. made my V3 install a breeze, tinkering with my setup is a pain in the bum
[IMG]undefined[/IMG]
Instagram: m2rs4_official
Proud owner of Amelia & Rae. Yes, I named my vehicles
2018 BMW M2 LCI (Wedge Performance Tuned + Pure Turbo Stg 2 Upgrade)
2019 Audi RS4 Advant
      02-28-2020, 01:59 PM   #55
Kankles
Rear Admiral
Kankles's Avatar
Drives: Bavarian Milk Wagon
2019 BMW M2C  [0.00]
Great write up. Will be using this as reference soon. I’m assuming you didn’t replace the rear camber bolt (which was marked with sharpie)? Or did I miss that it was a one time use? Thanks and cheers
      02-28-2020, 11:06 PM   #56
Mosely
Mosely's Avatar
594
Drives: '18 M2 | '20 X5 | '07 E92
Nope, that one was re-usable I believe.
IG Photo Gallery:
instagram.com/dr_m2sko/
Kankles1484.50
      03-03-2020, 12:31 PM   #57
wavyyyy
Drives: M2C
2023 bmw m3 6mt  [0.00]
For the top hat nut, is that 18mm or 22mm? And is that torqued to 50nm? I have a clunking noise with my V3s, pretty sure it's that nut. Going to order the needed tools, just want to make sure I'm ordering the right ones.
      03-03-2020, 02:37 PM   #58
M Fifty
844
Drives: M2 & 330CI
Open the bonnet, remove the rubber cap, put a jack under the front jacking point and lift while looking at the nut. Yes?
      03-04-2020, 02:17 PM   #59
wavyyyy
Drives: M2C
Yup, that one. I see it's a bit complicated, gotta hold the 10mm in place while twisting the 18mm, is this the one that I have to put under load to tighten properly?
      03-05-2020, 01:55 PM   #60
M Fifty
844
Drives: M2 & 330CI
Generally speaking, once you've got the shaft seated properly using the nut (when you might have to use an Allen Key to hold the shaft still), the final torque setting just needs a socket spanner on the nut and a torque wrench.
      05-16-2020, 03:06 PM   #61
wavyyyy
Drives: M2C
For those that drive primarily on the street, what settings are you guys running? Also anybody go wider on the tire? What height are you at and any rub?
      05-16-2020, 03:23 PM   #62
M Fifty
844
Drives: M2 & 330CI
No to the wider tyre - others may be able to advise. Noting that I'm running the BMW badged version, I went with the recommended ride height (it can be tricky to go lower at the rear as the spring is pretty long). 2 clicks lower bump and rebound than the recommended road setting as it makes it easier to get the car moving around on the roads I drive, at vaguely sensible speeds.
wavyyyy1045.50
      07-14-2020, 11:19 AM   #63
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
So much win in this thread.
Mosely593.50
Kankles1484.50
      08-29-2020, 04:43 PM   #64
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
I'd like to know the answer to this as well.
      08-31-2020, 08:20 AM   #65
Kankles
Rear Admiral
Kankles's Avatar
2019 BMW M2C  [0.00]
I know this is an older post but in case anyone else is curious. The stock 14x1.5 (ID) top nut is an 18mm (OD) and a schwaben tool is super helpful in removing.
https://www.ecstuning.com/b-schwaben...3046sch01a-01/
A lot of aftermarket (KW) use a 14x1.5 (ID) nylock style nut that has a 22mm (OD). For these a 22mm O2 sensor socket works really good.
TEKTON 47749 3/8-Inch Drive by 7/8-Inch (22 mm) Offset Oxygen Sensor Socket https://www.amazon.com/dp/B00GMN4D1Q..._VIptFbHQHRK4E
      08-31-2020, 10:28 AM   #66
M Fifty
844
Drives: M2 & 330CI
ECS Tuning actually sell the official BMW tool for use on the standard nut - but it costs more.
https://www.ecstuning.com/b-genuine-...302360213~oeb/
Kankles1484.50
