06-25-2017, 11:34 AM | #23 | |
Rep 3,077
And I can tell you right now, videos never truly capture the sound completely. Not having tips choices wasn't an issue to me since I really just wanted them black, either glossy or flat and wasn't interested in a carbon finish. Being that said I was happy with what they rolled out with. The size on them also make them look good. Fitment was perfect, no hassle install. Once you install this, let me know your feels, I am pretty sure you will be just like me!
Follow me on IG
No Boost4021.00 |
06-25-2017, 01:12 PM | #24 | |
Rep 4,551
Drives: 2015 328d xDrive
BAN_M2C4180.00 NYC Bimmer259.50 |
06-25-2017, 01:24 PM | #25 | |
Rep 3,077
Probably once you go with this setup you will forget about how it looks based on the sound
Follow me on IG
AndrewC198910931.00 |
06-25-2017, 06:06 PM | #27 |
enthusiasm > practicality
4021
Rep 2,247
Drives: 987 CS | G35x
Full Dinan exhaust + sport cat DP = forced induction perfection
06-25-2017, 06:37 PM | #28 | |
Rep 3,077
Indeed, now I just need to figure if I will pair with an Intake (been considering the DINAN). Next mod for sure is the FMIC and finally the tune.
Follow me on IG
07-13-2017, 07:22 PM | #29 |
24197
Rep 190,805
07-13-2017, 07:56 PM | #30 |
Rep 4,323
200 cell passes emission?
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
09-05-2018, 09:42 PM | #33 |
Rep 4,551
It depends on where you live and how the test is conducted. If they use an ODB scanner tool to read the ECU/DME then the car will pass (because no CEL).
If you live somewhere that uses a sniffer tail pipe test then it may or may not pass. I have no idea what the increase in CO2 emissions would be from this mod nor would I know what the legal amount of CO2 emissions are where you live. It probably varies state to state, country to country. Also if you live in California it's illegal to modify your cats at all so if they physically look at them and determine they're aftermarket you could potentially fail. I live in NJ where they use the ODB scan every 2 years (but only after the car is 5 years old) so it should pass emissions just fine once it's due for it's first test in 2022. |
NYC Bimmer259.50 Blurbo311197.00 |
10-03-2018, 06:56 PM | #34 | |
Rep 4,323
10-03-2018, 06:59 PM | #35 |
Rep 4,551
Are you tuned?
If so then that doesn't surprise me that you failed. Raising boost puts added heat and pressure on the cat and it will wear it out much faster. The tune could have hidden the CEL since most of them have that feature built in, and then you went and got tested thinking you weren't throwing codes when you were. If you're stock like I am you shouldn't have any issues passing emissions in NJ. Next time do yourself a favor and scan the car for any fault codes before you go get it inspected. Also keep in mind you don't have to get inspected at the DMV. I've gone to emissions certified Indy shops before and slipped someone a $20 if you catch my drift.
NYC Bimmer259.50 |
10-03-2018, 07:50 PM | #36 | |
Rep 1,348
https://www.dec.ny.gov/chemical/90781.html Q: When can an AMCC be legally installed? A: A new AMCC may be installed when the vehicle is beyond its warranty period and a legitimate need for replacement has been established and documented. Most vehicles in New York State are covered under the federal emissions warranty of 8 years or 80,000 miles. A legitimate need for replacement may be established through an annual vehicle inspection performed by a licensed inspection/maintenance (I/M) technician. Non-I/M program related reasons for replacement may include damage resulting from vehicle accidents, cracked or melted substrate, exhaust leaks, or converter malfunctions. Non-I/M program related AMCC replacements must still be established and documented by the installer. Q: Can a missing catalytic converter on a vehicle still under the warranty period be replaced with an AMCC? A: No. An OEM catalytic converter must be installed because the vehicle is still under the emissions warranty. AMCC may only be installed on vehicles beyond the warranty period
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 |
10-03-2018, 08:32 PM | #37 | |
Rep 4,551
NYC Bimmer259.50 |
10-04-2018, 03:30 AM | #38 | |
Rep 1,348
I am pointing out that the info in your post is not completely false and not completely true. It is always good to post what the technical legalities are in this situation to avoid confusing folks especially since you addressed it. Not bashing you so please do not take offense ,not my intention. So now folks can have some ,should I say accurate knowledge concerning this issue and what they do is up to them. I am sure some would find it important.
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2 Last edited by ceedawg; 10-04-2018 at 03:43 AM.. |
10-12-2018, 06:09 PM | #40 |
Chuggin' Along
333
Rep 588
Fabspeed sport cat does NOT throw a CEL, tuned or stock.
In NJ on all OBD2 cars, at the NJ MVC inspection station, they look to see if you have a cat (which they can't tell on the M2, and they check the car's computer for stored codes and readiness. Assuming that these conditions are met, you will pass inspection. I passed with my OBD1, 500whp 95 M3, turbo car that had a vibrant cat. If that passed, your M2 should. And being that it's not up for inspection for 5 years after purchase, I don't even understand why I just had to explain all of this. |
10-18-2018, 10:39 AM | #41 |
Rep 4,551
10-18-2018, 10:43 AM | #42 |
1006
Rep 1,653
Phil from Fabspeed here. I believe that particular customer had done multiple different upgrades to the vehicle at the same time if we are talking about the same owner. We worked through it with them and the CEL did not stick arond.
10-22-2018, 08:28 PM | #43 | |
Rep 4,323
Drove 200 miles. Didn't pass with a 200 cell cat. Fabspeed may pass I dont know but just sharing my $.02. I had to put the stock cat back on then clearly it was fine....
10-22-2018, 08:47 PM | #44 | |
Rep 4,551
And yes fabspeed will pass and they're guaranteed not to throw codes or lights. That's where your extra money is going and it's well worth it IMO.
4
