09-15-2022, 09:49 AM | #1 |
Rep 7
Are these tyres worn out?
I recently took my car for a service at a local mechanic and he said the edge of the tyre was finished. I was just wondering if you guys agree with this [IMG][/IMG]
09-15-2022, 11:00 AM | #3 |
Rep 6,939
Drives: 2018 M2 AW DCT
I am wondering if he tracked the car. Could be track wear or a bad toe adjustment. But the tire is not near the wear bars, so no it is not worn out.
09-15-2022, 11:08 AM | #4 |
Rep 527
Drives: 2020 F87 - M2 Competition
Personally I'd rock them through the rest of the year then put on a fresh pair in the spring
09-15-2022, 11:41 AM | #5 |
The Seeker
13863
Rep 3,325
Yeah, looks weird being just in that specific spot. I don't know enough about track wear on tires to tell the difference, but definitely I've heard the M2 wears the outside of the fronts pretty badly if you don't increase the negative camber.
09-15-2022, 02:06 PM | #6 |
Rep 1,335
If you continue in a short time you will reach the wires, do you have the car lowered? You have a lot negative camber.
09-15-2022, 02:12 PM | #7 | |
Rep 7
09-15-2022, 02:43 PM | #8 | |
Rep 1,335
Try aligning the wheels, it's too much wear for 2.5cm. With the alignment adjusted you will still be able to use that tyre. Last edited by Track/S; 09-15-2022 at 03:00 PM.. |
09-16-2022, 08:57 AM | #11 |
Rep 4,672
I'm guessing with the tread pattern those can't be swapped L to R to get that on the outside. Then fix the alignment? There's a lot of life left in that tire if you can fix the alignment
