M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Anyone running 10mm spacers front/rear with stock wheels? Any issues/rubbing?
      03-14-2020, 12:45 AM   #45
wavyyyy
Drives: M2C
2023 bmw m3 6mt  [0.00]
Old thread I know, I’m lowered on KW V3s, 10mm all around and experiencing rubbing in front on any dips.
Thinking about either switching to 7.5mm or bringing my car up a slight bit. Don’t want to roll the fenders. I’ll take some pics in the morning though, the car looks beautiful, sadly it won’t work though.
      04-12-2020, 02:39 PM   #46
808F90
808F90's Avatar
Drives: BMW M5 F90
Originally Posted by 2PUTT View Post
i read somewhere here that the fender liners are different on the M2C which might cause rubbing. i just recently added spacers and went very conservatively with 5mm all around. i just wanted a slight push out of the wheel to be about even or slightly under the top of the fenders since i am at the lowest setting on the M Performace coilovers (installed rears without the perch).
You think you could have gone with 10mm around?
William
      04-12-2020, 07:06 PM   #47
wavyyyy
Drives: M2C
Brought it up half an inch and still rub a little bit but now it’s only at high speeds on dips. I can deal with it while I wait for my new wheels.
      04-13-2020, 09:13 PM   #48
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
The issue isn't with the fenders most likely, it's with the plastic fender liner in the wheel well, specifically the area in front of and towards the outside of the tires. If so then there's no need to change spacers or ride height and definitely no need to touch the fenders. If you look closely you'll see some marks where the tires are making contact. You just get the area in question hot with a heat gun, push it forward a bit with something and hold it for a little and then pour some cold water on it so it sets in its new position. Problem solved.
https://f87.bimmerpost.com/forums/sh...4&postcount=34
wavyyyy1045.50
      04-19-2020, 01:56 PM   #49
2PUTT
Drives: F87
honestly, those 5mm spacer cause rubbing against the front fender liners after i got lowered with my M Performance coilovers. i ended up removing the spacers completely. keep in mind, i was running 255 up front.
widetyres279.00
      04-22-2020, 11:58 PM   #50
808F90
808F90's Avatar
Drives: BMW M5 F90
Thank you for your feedback. I will not be ordering spacers.
Best, Willy
William
      04-07-2021, 05:22 PM   #51
M2_MEDUSA
M2_MEDUSA's Avatar
Drives: 2021 M2 Comp. SpecialEdition
Old thread sorry, but I have an M2 comp. 7.5mm all around would be okay on stock tires, suspension and wheels? I have 763M wheels.
Instagram: M2_Medusa
      05-10-2021, 08:13 PM   #52
M2_MEDUSA
M2_MEDUSA's Avatar
Back with an update. I fit 12mm front and 10mm rear on stock 763m wheels. No rub whatsoever on hard driving. Stock suspension.
      05-12-2021, 07:36 AM   #53
FrozenGT
FrozenGT's Avatar
1117
Drives: 2021 Z4 M40i - Lexus NX300 F
MPERFORMANCE Suspension with Future Classic 10mm spacers All Around- stock tires. If you are on springs you will not have any adjustability. I would only buy Future Classic spacers buy two sets and do some testing.
Rundskop148.00
Stylin.M2270.00
      09-21-2021, 02:41 PM   #54
Atam
Drives: 2020 M2 Competition
Any pics?
      11-19-2021, 01:03 PM   #55
MASHCT
MASHCT's Avatar
Drives: 2017 BMW M2 MG
Originally Posted by VisualEcho View Post
For me? A picture of one spacer and a quantity drop-down, or something that obviously said spacers were sold in pairs. Once the spacer quantity was selected and the buy-button pressed a pop-up notification about requiring longer lug bolts, a picture of 1 lug bolt populated and a quantity drop-down.
Burger Motorsports won my business for this very reason. I am not super hung up on price, but BMS's spacers are significantly cheaper & include the bolts. BMS has adequate descriptions of their kits so you know exactly what you're getting, an installation guide you can check out, and you get a nice wheel hanger for free from BMS to boot.
2017 M2 | MGM | 6SPD Std | RWD | MP Exhaust | CSF FMIC | Active Autowerke DP w/ HF CAT | FTP Charge & Boost Pipes | Fortune Auto series 500 7k/14k coilovers | CDT Audio ES Gold Fronts & HD series Rear | Richland Forged Project Nurburg RF-GT4 Wheels | AudioControl LC-6.1200 | JL Audio TWK 88 | CF Goodies
      11-22-2021, 07:04 PM   #56
MASHCT
MASHCT's Avatar
I just tried 10mm BMS spacers on the rear with stock wheels. The wheel & tire poked outside the fender. Me no likey. (First pic)
I originally bought 12mm for the front, but since I opened & installed the 10mm I used them on the front & they're perfect! (second pic) It's juuuusssst shy of the fender.
My car is lowered by about a 1/2" on fortune auto full coilover kit. No rub issues so far. But only just installed the spacers. I'll be returning the 12mm's. You gotta like poke to like 12mm on the rear.
I also took the time to polish the wheel hubs removing the rust & oxidation. All shiny & nice-like. Looks really good and was weirdly satisfying to do the work.
      10-10-2022, 01:45 PM   #57
willworkforsushi
Drives: '24 G87 M2, '11 E90 335d
Looking sick! Good to see another black M2C in the Loudoun area!
      10-11-2022, 11:52 AM   #58
jliuod
Drives: 21' M440I
My car is stock and when I put the 12mm front and back I get this grinding noise ONLY when I back up with the steering wheel turned all the way to the left. The noise is coming from the front.
I have since removed the spacers and no more noise.
Anyone has any ideas as to why?
      10-12-2022, 05:52 PM   #59
billypopo
Drives: Bmw 435i GC, glacier silver
Old thread I know, I'm lowered on KW V3s, 10mm all around and experiencing rubbing in front on any dips.
Thinking about either switching to 7.5mm or bringing my car up a slight bit. Don't want to roll the fenders. I'll take some pics in the morning though, the car looks beautiful, sadly it won't work though.
Brought it up half an inch and still rub a little bit but now it's only at high speeds on dips. I can deal with it while I wait for my new wheels.
https://f87.bimmerpost.com/forums/sh...8;postcount=34
Rubbing in fender liner, do what Andrew says.
      11-04-2022, 05:16 PM   #60
M2_MEDUSA
M2_MEDUSA's Avatar
Currently running 265/30 12mm spacer upfront no rub, no camber. Its a hair close tho.
      11-05-2022, 09:30 PM   #61
M2_MEDUSA
M2_MEDUSA's Avatar
Stock wheels, stock camber on eibach springs
