11-15-2022, 02:40 PM | #1 |
Rep 753
3 M2s on a Dynojet
Last Saturday (Nov 12, 2022) three of us got a chance to put our cars on a Dynojet. Below is the current state of the cars wrt engine modifications
User: bentom2 2018 M2 Stock Tune, AA Gesi downpipe, CSF intercooler, CSF charge pipe User: pal 2018 M2 Dinantronics Stage 1 harness, Akra downpipe, Akra catback, ER intercooler, ER charge pipe User: AlexB77 2017 M2 VF Stage 2 Tune, Fabspeed 200 cell downpipe, CSF intercooler, CSF chargepipe bentom2 also dyno'd his car stock in the past, so we will use that for comparison here. I am using Dynojet's SAE correction factor as I've found that to be consistent across days and dynos. SAE corrected numbers are also what we would expect for wheel horsepower on these cars given the BMW published crank numbers. Obvious insights that we have here are: - Bolt ons like downpipe and intercooler give gains across the powerband, even without a tune. Peak number here may not be representative of the improvements. - 5th gear pulls for us yielded better results - And tunes are better than no tunes for power - more boost - Uncorrected numbers can be hugely different compared to SAE correction. In this case we saw 20+ more whp since we dyno'd on a cool day. |
11-15-2022, 03:05 PM | #2 |
Rep 63
Thank you for sharing! On the first graph, I found it interesting that the stock tune w/ DP/IC/CP makes both less hp & tq compared to bone stock just between 6000-6500 rpm. I get that stock dyno was done on a different day so there could be other variables at play, but any other clue as to why that dip would exist?
2018 M2 - LBB 6mt
pal433.00 |
11-15-2022, 04:10 PM | #3 |
Rep 753
We noticed the sine wave pattern over 5500 rpm on both the stock tune dynos for bentom's car, and to a lesser extent on my Dinantronics Stage 1 car. I think that wave is some function of the stock tune trying to control something - maybe boost?
11-16-2022, 07:52 AM | #4 |
Rep 4,146
Awesome. The load based tuning logic is likely going to allow the car to add power where the restriction is the highest - but peak power generally will not be changed much because at the higher RPM, it's turbo limited. A turbo inlet will net about 10WHP on top end and give a more linear power curve.
SAE is about 2.2% lower than STD - the biggest considerations are having a baseline and using the same calculations pre and post. The Dinan is adding boost to the stock profile - do you know how much? Did anyone log any of the runs? And finally, have you done an IAT comparison? I personally think the ER should be superior to the CSF, especially if you trimmed that upper shroud, but I still want the data. My former FBO N52 with MILVS on STD vs SAE correction:
Mods: Yes.
pal433.00 |
11-16-2022, 08:31 AM | #5 |
24201
Rep 190,807
thank you for sharing
pal433.00 |
11-16-2022, 09:49 AM | #6 |
Rep 753
Ah, totally forgot that bentom2's car has the MST inlet pipe as well.
I did do some logging via VCDS' OBDII function and got some boost data. Will try to remember and upload the excel plots and post here later this evening. From memory, stock seems to shoot for around 14psi, Dinantronics is about 1-2 psi more and VF Stage 2 is about 4'ish psi more than stock. It was a cold day so IATs were not interesting on the dyno. They have a big fan and it's a fairly open shop/dyno area. As you can see on the Uncorrected file, the temp in the shop was around 52°F. A bit cooler outside. |
11-16-2022, 10:28 AM | #7 | |
Rep 4,146
hihowareyougood125.50 pal433.00 |
11-19-2022, 05:10 PM | #10 |
Rep 753
The lower one is off the car, the upper one is not. Since it doesn't block the intercooler, Inleft it there. I can see how not having it could be better for airflow though.
11-19-2022, 07:04 PM | #11 | |
Rep 4,146
So if you're looking for improved IATs, I would start there.
Mods: Yes.
