08-19-2022, 06:42 PM | #1 |
Rep 1,244
Drives: 2017 Big Turbo BMW M2
I currently run an aftermarket SpeedTech N55 exhaust manifold and wanted to know if you think the Funk Motorsport N55 exhaust manifold blanket could work on the SpeedTech manifold as well. If not, I may need custom inconel heat shielding, not sure if you know any companies for this.
In addition, I'm currently running a BorgWarner 8374 connected to the SpeedTech manifold and wanted to buy a Funk Motorsport turbo blanket for my BorgWarner. Let's says theoretically the Funk Motorsport N55 manifold blanket worked on the SpeedTech manifold, do you guys think it would be compatible with the Funk Motorsport BorgWarner 8374 internal wastegate turbo blanket ? Lastly for installation, would I have to remove the turbo and manifold, or can I install these two blankets with the parts already on the car ? These are the links to the items I'm interested in : Funk Motorsport Exhaust Manifold - https://funkmotorsport.com/product/b...et-n55-engine/ Funk Motorsport BorgWarner 8374 Turbo Blanket - https://funkmotorsport.com/product/b...turbo-blanket/ Last edited by shaneguags; 08-20-2022 at 01:47 AM.. |
08-19-2022, 06:54 PM | #2 | |
Rep 7,431
In terms of the exhaust manifold heat shield I do not know of any company that makes a good custom and affordable heat shield. You could always ceramic coat it, exhaust ceramic coating does take the edge off of the heat and does a pretty good job of it too.
shaneguags1192.50 |
08-19-2022, 08:12 PM | #3 |
Rep 1,244
I currently run an aftermarket SpeedTech N55 exhaust manifold and curious if anyone knows if the Funk Motorsport N55 exhaust manifold blanket would work on my SpeedTech manifold.
As well, I'm currently running a BorgWarner 8374 connected to the SpeedTech manifold and wanted to buy a turbo blanket for my BorgWarner. Let's says theoretically the N55 manifold blanket worked on the SpeedTech manifold, does anyone know if it would be compatible with the BorgWarner 8374 turbo blanket ? Also for installation, would I have to remove the turbo and manifold ? |
08-19-2022, 08:18 PM | #4 |
Rep 1,244
If I were to run a turbo blanket on my turbo it would look something like this :
08-19-2022, 08:39 PM | #5 |
Rep 7,431
08-19-2022, 08:54 PM | #6 |
Rep 1,244
my turbo is the 0.92 A/R T4 internal wastegate, I'm pretty sure what I sent you is what I have. I may be wrong, I'm not even sure how to tell to be totally honest.
08-19-2022, 11:26 PM | #7 |
Rep 7,431
08-19-2022, 11:29 PM | #8 | |
Rep 1,244
08-19-2022, 11:31 PM | #9 |
Rep 1,244
Also, when comparing the two manifolds (top being stock, bottom being SpeedTech), I feel like it could maybe work, only issue being the middle connecting area.
08-19-2022, 11:40 PM | #10 |
Rep 7,431
I know, but the ewg versions are extremely tight. I spoke to jeff about it awhile back and he told me the same thing. So that's why I am warning you to ensure there is enough clearance.
shaneguags1192.50 |
08-19-2022, 11:50 PM | #11 | |
Rep 1,244
08-19-2022, 11:56 PM | #12 |
Rep 7,431
shaneguags1192.50 |
08-20-2022, 12:07 AM | #13 |
Rep 1,244
I just contacted Jeff at SpeedTech and Funk Motorsport about the manifold and BorgWarner blanket. I'll update you what they say. Also, for installation, do you think I would have to remove the turbo and manifold for the covers ?
F87source7253.50 |
08-20-2022, 02:06 AM | #14 | |
Rep 7,431
Well that depends on how small your hands and forearms are + how dexterous your fingers are. You will probably need to work with a bore scope camera or an inspection miror to see the turbo and waste gate area. Having tools like those shown in the funk video would defintely help. Worse case scenario you will likely have to take off the downpipe, stiffening plate, intercooler, turbo outlet, and turbo inlet to reach all sides of the turbo to get it on.
shaneguags1192.50 |
08-20-2022, 02:18 AM | #15 | ||
Rep 1,244
08-20-2022, 03:38 AM | #16 | |
Rep 7,431
Imo none of this will be fun. |
08-20-2022, 11:08 AM | #17 | ||
Rep 1,244
08-20-2022, 07:11 PM | #18 |
Rep 1,244
great news, Funk Motorsport believe their exhaust manifold and turbo blanket setup should work on my SpeedTech kit. I'll be contacting my shop on Monday and to clarify with them whether or not I need to remove the manifold for installation. Funk Motorsport says I won't have to remove the turbo and manifold
08-29-2022, 03:42 PM | #19 |
Rep 1,244
Just ordered, will update once it arrives
09-27-2022, 07:33 PM | #20 |
Rep 1,244
installation came out taking 4 hours with a $520 installation fee. I didn't get to push the car due to it not being dialed in yet but it seemed to feel responsive on full 93 octane. I had to evacuate Tampa due to a hurricane so I didn't fill up with ethanol.
F87source7253.50 |
09-27-2022, 08:55 PM | #21 |
Rep 7,431
Nice, keep us posted and stay safe!
shaneguags1192.50 |
