01-07-2022, 10:11 PM | #1 |
Rep 140
Super knock + Injector Deactivated
Hey everyone, I have an N55 M2 and I am running full E85 (Dorch Stage 2) and in the process of getting a custom tune done for my car. I was at a car show and banged the rev limiter cause the crowd wanted to see it and then I got the following codes in the attached image. The car idled really rough and I was like "alright I effed the engine up and I'm going to need a new one".
I shut the car down, ran the diagnostics using BM3 and cleared the codes, prayed, and restarted it and it fired up and has been idling with no problem so far. Did a 3rd gear pull WOT and car seems fine. Code hasn't come back. Should I be worried about this? Did my car just freak out at me because I banged it off the limiter for a few seconds? Any feedback (positive or negative) would be greatly appreciated. |
01-08-2022, 12:48 AM | #2 |
@lbb_kev
491
Rep 514
If all you did was bang the rev limiter and the codes no longer show up then you're *probably* fine. Best would be to consult your tuner and they should be able to tell you if there are any issues from your logs.
01-08-2022, 12:51 AM | #3 | |
Rep 140
01-08-2022, 10:11 AM | #4 | ||
Rep 140
Once again, just waiting on the tuner hahah |
01-08-2022, 03:34 PM | #5 | |
Rep 7,431
Super knock is really really bad, but if you were doing it while neutral just revving it that should be less detrimental because there was no load on the engine and likely you wouldn't be making huge boost - especially without antilag. Again like others have said just talk to a tuner about it, the car should never have super knock under any circumstance so yeah have your tuner address it.
01-08-2022, 05:35 PM | #6 | ||
Rep 140
01-08-2022, 07:10 PM | #7 | |
Rep 7,431
Next super knock could damage the spark plug tips (electrode, ceramic etc) which is why you'd swap them out. Not for plug to piston contact which would never happen. Also you'd likely never bend the rod even if you hit the valves or the spark plug, the rod is so much stronger than the valves or the spark plug those would bend first along with denting your pistons. Also Super knock is a huge knock event which could crack pistons and bend rods due to the huge cylinder pressures that occur due to the preignition happening so far before TDC that the combustion gas expansion combined with the compression due to the piston moving up creates astronomical amounts of pressure. This pressure will possibly bend rods and crack pistons not any form of contact. So the best way to check for piston damage is a leak down test and maybe a bore scope visual inspection, rod damage will be harder to check for. But again I don't think anything too major occured if you were only revving it.
01-09-2022, 05:45 AM | #8 | ||
Rep 140
Here is a WOT 3rd gear log I took after I cleared the super knock codes and they didn't come back. Think you could provide some insight before my tuner gets back to me on Monday? https://www.bootmod3.net/log?id=61d9...0b434a91ee8dda Based on the timing in this log, everything looked fine to me, so I did a high speed high load run to see if it would come back and it took it just fine: https://www.bootmod3.net/log?id=61d9...90c630d62f94ff FYI both were on around E75-E80 fuel |
01-09-2022, 06:36 AM | #9 | |||
Rep 140
https://www.bootmod3.net/log?id=61d8...90c630d62f94b3 This is the idle right after: https://www.bootmod3.net/log?id=61d8...729b734798c054 This was idling after clearing the codes and restarting the engine: https://www.bootmod3.net/log?id=61d8...90c632d97c4223 |
01-09-2022, 12:21 PM | #10 |
Rep 3,696
After logs look ok to me, but you guys aren’t even pushing that hard yet (20.3psi, 8deg of timing). For example, we’re currently at 22.2psi & 16deg with the Stg 2+ E50 beta with no issues. Even the OTS 2+ Multimap runs more boost & timing than your log.
Hopefully it’s ok and you guys can keep pushing. I didn’t have a very good experience with Cary, and his maps didn’t run right on my car while at the very same time Halim’s Stg 2+ E30 beta maps ran perfect when we were working on those for the OTS back in summer 2020. Once you’re happy with Cary’s map my suggestion is to hit a Dynojet and compare it to the BM3 Stg 2+ maps to see how the curves differ. Last edited by ZM2; 01-09-2022 at 05:04 PM.. |
01-09-2022, 12:25 PM | #11 | |
Rep 140
Yeah I'm just hoping it was a freak accident. Cary had tuned so many of my friends cars that are amazing so I trust him to make a safe tune. The issue is why did this happen when the car wasn't even being pushed hard? Are my knock sensors just that out of whack? I have 0 knock right now on the Stage 2 Multimap and the code hasn't come back. I should also add that I was running like E77 when this happened. |
01-09-2022, 12:28 PM | #12 | |
Rep 3,696
Has to be tune related. I’ve never seen superknock from all my years of tuning with Halim, even with a ton of track time. Let us know how it goes! |
01-09-2022, 12:30 PM | #13 | ||
Rep 140
I will definitely keep you posted on how it goes! |
12-08-2022, 07:36 PM | #15 |
Rep 140
