09-23-2022, 01:47 PM | #23 | |
Rep 33
09-23-2022, 01:48 PM | #24 | |
Rep 3,696
Some guys upgrade to the EU5 injectors, but that's not necessary unless you're pushing a good bit over 500whp while using E85. And, requires custom tuning or applying the BM3 checkbox. I'm at 480whp on E50 and don't plan on pushing more, so I just went back with the EU6 injectors. |
09-23-2022, 01:49 PM | #25 |
Rep 33
09-24-2022, 06:09 PM | #26 |
Rep 142
From what I’ve seen with my car, it has always been one or more ignition coils slowly going bad that finally failed completely with a misfire code for the cylinder with the dead coil. You usually get a lean code and then the above happens down the road. I’ve even had brand new coils fail.
I seriously doubt it’s clogged or failing injectors unless you don’t use top tier fuel. My car is nearing 100K miles and runs like a top with a glass smooth idle. It’s worth running some Techron concentrate every 5k miles or so as well and can alternate with Berryman B12 Chemtool in the tank. If you are running an ethanol blend, then run 3 ounces of TCW3 2 cycle oil in the gas to restore some lubricity to the ethanol blend and it also has detergents in it that keep the entire fuel system clean. A bit of preventative maintenance goes a long way as does running the car hard to clear out carbon deposits, but don’t think most here would have that problem…lol. Last edited by ctt300; 09-24-2022 at 06:14 PM.. |
09-24-2022, 06:32 PM | #27 | |
Rep 33
1) You started seeing the cold start stumble and rev up once at first start up of the day 2) Then this happened at every start up 3) Then eventually get a lean code and/or misfire code 4) Then you replace coils and the startup idle dip rev-up goes away entirely? I have seen multiple reports that leaky injectors cause this weird startup behavior, and it sort of makes sense when you think about it. It only happens after the car has been sitting for about 24 hours. Every startup after that is perfectly normal, along with every idle situation, as long as it's within the 24 hours of initial start (not enough fuel has leaked yet to cause the strange cold start dip and rev up). This is my situation right now as it was for the others and will probably turn into every start eventually. |
09-27-2022, 11:31 AM | #28 |
Rep 3,696
For my full update, see my latest post on this thread: https://f87.bimmerpost.com/forums/sh....php?t=1884838
Direct post link: https://f87.bimmerpost.com/forums/sh...6&postcount=70 |
09-30-2022, 12:57 PM | #29 | |
Rep 33
ZM22813.50 |
09-30-2022, 04:17 PM | #30 | ||
Rep 1,244
Drives: 2017 Big Turbo BMW M2
Rough cold starts
ZM22813.50 |
10-02-2022, 01:41 PM | #31 | |
Rep 33
10-02-2022, 01:55 PM | #32 | ||
Rep 1,244
10-02-2022, 03:30 PM | #34 |
Rep 1,244
10-02-2022, 06:28 PM | #36 | |
Rep 1,244
10-02-2022, 08:55 PM | #37 |
Rep 1,244
Just logged a cold start :
https://www.bootmod3.net/log?id=633a...0b43298cbc23f7 I wasn't completely cold but it was sitting for around 5 hours. startup felt fine. |
10-02-2022, 09:32 PM | #38 | |
Rep 33
Regarding your log after 5 hours, anything you see that is interesting? Even if my car sits for 12 hours it seems to be just a normal start. For some reason, it's after around 24hours sitting, even with new injectors, it likes to take a few seconds after start at 1k rpm and then rev up to 2k rpm and drop from there. Who knows. |
10-02-2022, 09:40 PM | #39 | ||
Rep 1,244
10-02-2022, 10:20 PM | #40 |
Rep 33
10-03-2022, 03:05 AM | #41 |
Rep 647
I’ve got 20k miles on mine and it never sees more than 1100RPM upon cold start. I run Shell 93 and I’m on NGKs gapped to .23 running BM3 S2(will be going back to stock plugs at some point.)
Generally it behaves the same on a cold start after 3 days as it does after 8 hours. I’ll get a video of it for reference later this week. |
10-03-2022, 02:04 PM | #42 |
Rep 1,244
it could be because my gap size is .018 but I did that for my E60 blend. I'm on full 93 as of now, maybe that's the issue ?
10-03-2022, 07:15 PM | #43 |
your average JAMF
3101
Rep 4,094
Using Top Tier gas or some shitty generic stuff?
'21 M2 Comp
'19 Golf R |
10-03-2022, 09:13 PM | #44 |
Rep 33
I only use organic, grass-fed gas. After talking with my BMW tech today, who is very familiar with N55s, and the one who installed my injectors, told me that the few second delay before rev-up is what he sees all the time at altitude (we're at about 6k ft in Colorado Springs); apparently, nothing to worry about.
