M2 Technical Topics > Cosmetic Modifications > Is A Special M2C Trunk Required For The Vorsteiner Carbon Wing?
      05-27-2021, 03:24 PM   #1
Iamlemon
Enthusiast
Iamlemon's Avatar
Drives: Now: Aston DBX, BMW M2C
Hey guys and gals, I am thinking about installing the VRS carbon wing for the M4 GTS on my M2 Comp. I saw this setup in person and was blown away. However, I did not have the chance to ask if the owner was running a stock trunk. So, my question is: Do I need a special trunk for the M2 Comp to run a wing on it? I have heard a few people mention that the M Perf wing goes with the M Perf trunk, but I am not sure if that is because it needs to, or if they just fit well together. Thanks!
Here is the link of an M2 Comp with the wing:
https://europeanautosource.com/blog/...and-vorsteiner
Here is the wing itself:
https://europeanautosource.com/vorst...nufacturer=206
      05-28-2021, 03:40 AM   #2
Megator
Megator's Avatar
518
Drives: M2 Competition
The stock trunk may not be strong enough to support the aero load of a race car wing. The Mperformance trunk (CF) and M235i Racing (and M2 CS trunk I guess) are reinforced to accept a BMW wing. The mounting holes + reinforcements may not match the Vorsteiner wing. The reinforcements stop the top of the trunk from becoming dented.
This Vorsteiner wing is not really designed like a motorsport wing so the amount of DF it generates is probably not that high. I would run it on the stock trunk, if it gets dented by the aero load simply get a body shop to push it back and add reinforcements.
https://f87.bimmerpost.com/forums/sh....php?t=1646928
Tags
m2c, trunk, vorsteiner, vrs, wing
