04-04-2018, 12:49 PM | #1 |
Rep 477
Drives: M2CS
Ground Control Camber Plate Settings
Hey guys.
I got my plates yesterday. One side is done. The four small circles on the top. Approximate what kind of camber can I expect? I have camber gauges but thought I'd get a general idea of what to expect as should be pretty uniform with our cars. Would I expect the toe to change significantly as I do anything to deviate from the factory camber setting. Thanks again guys. |
04-04-2018, 09:58 PM | #2 |
Rep 477
Drives: M2CS
04-05-2018, 06:10 PM | #3 |
Rep 477
Drives: M2CS
Anyone?
04-09-2018, 08:39 PM | #5 | |
Rep 477
Drives: M2CS
After that I'll see where I'm at for the track. Will it change your toe much? Thanks. |
04-10-2018, 03:17 AM | #6 |
Rep 4,516
yes - changing camber will have a noticeable on effect toe.
Current '22 X3M LCI.. |
04-10-2018, 08:50 AM | #7 |
Rep 570
Factory camber setting is -1.0 degree w/zero direct adjustment. In my case, there was a stack-up tolerance issue that made side-to-side camber adjustment impossible (to both equal overall -2.0 degrees), so opted for Vorschlag plates which allows more incremental tailoring.
04-10-2018, 10:43 AM | #8 | |
Rep 477
Drives: M2CS
04-10-2018, 10:57 AM | #9 |
Rep 570
Meaning from the factory (w/out camber plates). With both the camber plates set to -1 degree (assumed to be an additional negative degree over stock), I was getting 2.0 LF and 2.7 RF. The variation being stock suspension (car is brand new and almost no miles and zero damage).
W/the camber plates removed, it aligns w/in factory spec. -1.0 and -1.2 I switched to Vorschlag Camber plates which had more variation in adjustment +/-.1 degrees across the range |
