M2 Technical Topics > Suspension | Brakes | Chassis > *KLONK* rattle sound EIbach Pro Kit?
      01-11-2018, 03:05 AM   #1
Levente_CSL
196
Drives: bmw m3 csl
I fitted the eibach pro kit with a mechanic. since then i get these klonk rattle sounds when i go over bumps on the road. i think i had this sound also before the pro kit. Is this normal ? anyone else have this?
      01-11-2018, 08:28 AM   #2
UltraMagneticAL
Meh
UltraMagneticAL's Avatar
926
Drives: M3CS & Cayman S
2019 BMW M3 CS  [0.00]
2018 X3 M40i  [0.00]
2017 BMW M2  [10.00]
not normal. check that the bump stops are seated correctly.
      01-11-2018, 08:35 AM   #3
DoZZa
DoZZa's Avatar
82
Drives: MY17 | M2 | DCT
I have Eibach pro kit and do not have this sound occurring.
F87 M2 | DCT '17
E46 M3 |SMG '06
E46 M3 | SMG '03
E30 320iS | '90
E28 M535i | '84
      01-11-2018, 11:36 AM   #4
M2GB
Drives: 911 and M2
Alot of people have had this problem.......including myself. Its an annoying sound
The solution for me was the bolt holding the strut to the lower mount (also has a bracket that holds the cables to the brakes)
This bolt should not be over tightened. It needs to be loosened to about 25lbtft with a torque wrench
      01-11-2018, 11:57 AM   #5
Levente_CSL
196
Drives: bmw m3 csl
hi! thanks for the reply. really? so its not the upper control arm or upper ball joint? its the strut? the first thing i thought that a screw or something is not tightened enough, but you say it had to be loosened. hmmm. But did you encounter this problem from the start with standard springs or only after eibach springs mounted? the strange sound i mean. Both strut in the back both sides has to be loosened or only one side? the front struts front axle you didnt bother with it right? just the rear?
      01-13-2018, 10:08 AM   #6
Andi-M2
Andi-M2's Avatar
Germany
193
Drives: M2 F87
Do you have a picture of it by accident?
Unfortunately I've got the same problem with my car when crossing small bumps.
      01-13-2018, 10:37 AM   #7
Bt12
Drives: 2018 X5,2018 m2, 2018 x1
In all my older cars that were lowered when I’ve had this noise it was one of 2 things... bolts not tight or 2 strut mount bearings needed to be replaced. Not sure if that helps but just trying to be helpful.
      01-31-2018, 08:15 PM   #8
SEAT TIME RULES
SEAT TIME RULES's Avatar
1103
2020 BMW M2C  [5.00]
Check your top strut nut. Very common for it to back off. Use locktite to keep it secure...
HTH
2004 Mazda Rev It Up Finalist
2002-Present HPDE Instructor
      02-16-2018, 02:17 PM   #9
wolfbane1967
Picture of what strut you guys mean ?
      03-20-2018, 09:31 PM   #10
NashvilleM2
Drives: 2021 BMW M3 Comp.
Anybody find the solution for this?
I just installed the macht schnell springs and have a noise like this on the driver side front. It only happens when going slow and hitting sharp bumps.
      03-21-2018, 08:47 AM   #11
horsepower_and_hounds
Drives: BMW
That sounds like a strut nut or swing arm link not torqued. Hopefully who ever did the install torqued the lower strut cradle correctly
      04-08-2018, 03:35 PM   #12
wolfbane1967
Is it this strut your talking about
