06-07-2023, 01:28 PM | #23 |
The Seeker
13863
Rep 3,323
Just had the car coded for the CS upgrades, and the CCB's. Took about 20 minutes front to back with a super slow laptop. The drive past 4 miles to see if the errors are still there will have to wait until it's dry out again, but I did get a quick driveway snap.
ABS/DSC bleed + traditional bleed is next week. |
06-07-2023, 08:03 PM | #25 |
The Seeker
13863
Rep 3,323
Car drives fine.
Squeaks come and go, not as consistent or bad as last night (every time I turned left at all) Errors remain, they come on at 4 miles, close them, then they come back on at 6.8 miles. And a weird thing happened a few times. Lights off, but when I shut the car off and got out the rear lights were still on. Did that a few times, now working as normal (this was the clue that I missed that the brake light switch was too close to the brake pedal arm). I had the CS coding done as well, can't tell any difference, but I drive with everything off, and I wasn't driving hard. Last edited by ///MPhatic; 06-08-2023 at 09:26 PM.. |
chris7197334.00 |
06-08-2023, 11:17 AM | #26 |
The Seeker
13863
Rep 3,323
ERROR UPDATE
Status: Fixed. Cause: Brake light switch When removing the clip/brake booster pin/nuts we must have inadvertently hit the brake light switch and pushed it in towards the brake pedal arm so closely that just about anything would cause the brake lights to be on, including just shutting the door. Not really knowing how a brake light switch works, I got in there and started fiddling around and pushed it all the way in towards the brake pedal arm, which, to a person that doesn't know would be like, hey, this was loose, and I pushed it into place. No. I basically adjusted it all the way to the arm, then, again, not knowing how a brake light switch works, couldn't get it adjusted back out no matter how I pulled on it. I finally just pulled the brake pedal lever in the opposite direction of normal and it pushed the switch back out where it wasn't touching, and no more brake lights. After my drive just now there are no errors at the 4 or 6.8 mile markers that there were before. Some notes: Car drives fine, pedal is a bit weird at the top, could be just from being CCB's or could be the air in the ABS unit. We will see next week when I get my ABS/DSC bleed. Wet performance is DRASTICALLY reduced. Pulling out of the car wash I didn't think I was going to get the car stopped. A couple pumps and it was decent, but certainly not double the normal braking force (or whatever increase it is when you have metallic pads and iron rotors when they are wet). Those that say there is no brake dust are high. There is still brake dust, it's just vastly less compared to the iron rotor stock pads, and also much less than the CarboTech pads by quite a margin. It's even a good amount less than the Akebono pads, which are fantastic on dust. Maybe this is just dust from nowhere since they were just installed, but with 54K on them and light applications I expected there to be ZERO. There are still some squeaks and squeals here and there, which will hopefully just magically disappear. Overall this job was a PITA, but like most things if I were to do it again I'd pretty much breeze through it. I'll get the sizes and make a list of the 7 rubber nipples and 1 stopper needed to keep brake fluid from getting everywhere. Last edited by ///MPhatic; 06-08-2023 at 09:31 PM.. |
chris7197334.00 |
06-10-2023, 10:19 AM | #27 |
The Seeker
13863
Rep 3,323
A couple of before and after pix.
Before and after front by Andrew Thompson, on Flickr Before and after rear by Andrew Thompson, on Flickr Last edited by ///MPhatic; 06-10-2023 at 10:36 AM.. |
M2Pilot278.50 |
06-10-2023, 11:17 AM | #28 |
Rep 3,805
Easy fixes are the best!
///MPhatic13862.50 |
06-14-2023, 11:26 AM | #29 |
The Seeker
13863
Rep 3,323
OK, so an update on this.
After 2 traditional heavy bleeds (4 psi on the Motive per nipple) my brakes were good, but the initial bite wasn't there. Did the ABS/DSC bleed today, but instead of using ISTA my mechanic used a older Snap On Solus scanner tool. ISTA basically cycles the ABS valves 3 times, which my mechanic thought was overkill (he regularly works on Porsche/BMW/Ferrari/Audi/etc), but the Snap On only called for 1 cycle while pumping the brakes, so that's what we did. We then bled the driver's side outside nipples only, rear then front, 5 second each while the brakes were pumped and the Motive at 20 psi instead of 15. Then we did all nipples the traditional way, same 5 seconds per nipple + the Motive. The Snap On tool did call for 20 psi on the Motive instead of 15, not sure why. Worked like a charm, pedal is vastly improved, brakes start earlier and hit harder. Very happy with the results! Colors. 6 by Andrew Thompson, on Flickr Colors. 1 by Andrew Thompson, on Flickr |
jefe2000739.50 |
06-14-2023, 11:33 AM | #30 |
The Seeker
13863
Rep 3,323
I also wanted to thank kubax86 (bimmer-remote.com) for coding my CS diff/steering/dsc and my carbon ceramic brakes. Even on a dial-up slow laptop it only took 20 minutes front to back.
06-17-2023, 08:48 PM | #31 |
The Seeker
13863
Rep 3,323
Very happy to report that after washing the M2 with these CCB's a few times there is no longer that huge amount of orange (rust) residue all over the barrel when I go to wipe the wheels off. Seems like a little thing, but for someone like me (re OCD) that has spent so much on nice wheels, it's a huge plus. Even without wiping them down they're passable IMO.
06-18-2023, 07:23 AM | #33 |
Rep 332
Drives: 2018 BMW M2
Great looking setup
06-18-2023, 08:36 AM | #34 | |
The Seeker
13863
Rep 3,323
I do love the fact that there is no iron in the dust, but hate the fact that I can no longer blow my wheels off after every drive with a leaf blower because the dust from the pads is super unsafe without a mask. The price paid I suppose. |
06-19-2023, 10:25 AM | #35 | |
Rep 4,672
06-19-2023, 11:25 AM | #36 |
The Seeker
13863
Rep 3,323
07-07-2023, 09:55 PM | #37 |
NA M3
260
Rep 145
Drives: 2020 bmw M2cs , 2013 frozen m3
Hey , do you have the part number of the booster?
M3George
07-09-2023, 04:47 AM | #39 |
Rep 757
Nice work. Other than after a wash, have you driven with them in the rain/wet?
'17 M2 DCT Long Beach Blue
07-09-2023, 07:49 AM | #40 | |
The Seeker
13863
Rep 3,323
Beyond that I'm dealing with terrible squeal now. It comes and goes. I think I got the brakes too clean before installation because the previous owner of the brakes didn't have any such issues. BMW recommends no lube on anything, but I'm going to take them apart anyway and lube the common areas. |
dtmurf481.50 |
07-09-2023, 09:05 AM | #41 | |
Rep 4,672
07-09-2023, 12:41 PM | #42 | |
The Seeker
13863
Rep 3,323
I have read that the weaker brake booster and 2NK emergency stop coding was so that the calipers didn't damage/crush the much weaker carbon rotors. I have screen-caps, but was told not to share, so all I can say is that... Under SALAPA - Element the 2NK code is present, and under Ausgelesen, the first folder says F87CS (I think this is the CS diff/steering/MDM upgrade). I have read that some manufacturer's CCB do apply the brakes automatically in rain in order to make the rain performance better, but I can't confirm that for the M2/M4, nor can I confirm that I got that coded. I CAN confirm that I hope I never have to drive this car in the rain again. |
07-09-2023, 02:52 PM | #43 | |
Rep 1,334
The booster is only to remove sensitivity to brake pedal. |
07-09-2023, 06:35 PM | #44 | |
The Seeker
13863
Rep 3,323
As far as every reason for the booster, I can't say, but I do know that the carbon ceramic pads are less sensitive than the stock 2NH pads, even when hot, so I'm not sure how a weaker booster would correct anything. I also know that if you don't change the booster you get a softer pedal, not a harder one. |
