06-17-2022, 08:23 PM | #67 | |
~Spyder
638
Rep 870
Drives: '19 M2C Hockenheim 6sp
Yeah, well, the Indy shop is well regarded here in the Dallas Ft Worth area; I used them for other work and never disappointed. So, I can't really tell if the front is the max height or there is the installation could be improved. I chose the B16s since I think they have the min drop compared to KW3, Ohlins, MPS etc… Y'all think I should take it back for another tech to re-inspect the height adjustments? Anyone else rocking the B16s and ended up having this issue? The fronts ended up being lower by 59.5 mm…is that the expectation? The B16s never came w/ instructions in the box Regardless, I will reach out to the vendor I bought them from (Turner Motorsport) and ask for input/advise.
Skål från Sverige...via Texas y-all
06-17-2022, 09:41 PM | #68 | ||
~Spyder
638
Rep 870
I will be going back
Kattanah137.50 Capt Canuck704.00 |
06-18-2022, 02:31 AM | #69 |
Rep 243
590 F is around the lowest that the MPS can go. I’d would be surprised if the B16s can’t to higher. If adjusted my set to be at 595.
No_curebimmer637.50 |
06-18-2022, 09:11 AM | #70 |
Rep 390
I’m no suspension expert, but I just put on TC Klines and it feels similar to stock except it’s considerably more forgiving on bumps and road imperfections.
06-18-2022, 11:39 PM | #71 | |
Rep 415
For proper, well-regarded kit (that's not meant to be slammed) it really doea seem deep. Hope they have no problem sorting it.
therealm3: "You could preventatively swap in a B58 from a Supra? Then it would at least have a Toyota badge on it and you would sleep easier."
06-19-2022, 03:23 AM | #72 | ||
~Spyder
638
Rep 870
So, and this is my bad as I have never made any suspension updates on any of my previous bimmers, or other autos: the paper that the shop printed it out for me said F 595mm and 610mm in the rear. I mistook that as a typo (59.5 mm drop not 595mm). Then it dawned on me that these measurements represent the actual height from the floor to the fender… Regardless, this post clearly proves that the M2C w/ Bilstein B16 can be set higher… https://www.bimmerpost.com/forums/sh...php?p=24525012 I sent an email to the shop to work w/ me and relook at the installation: it has to be higher as the B16 seems to be one of the more conservative coilovers available for the F87 (I believe B16 can go higher than KW V3s).
Kattanah137.50 |
06-20-2022, 04:07 PM | #73 | |
Rep 8,970
Lucky for me they're only 1.5 hours drive from home so i can drive there, get parts fitted and drive back same day. I had some problems with the adjustable front drop link lock nuts coming loose and knocking but they sorted that with a free service too and AST developed a new part to sort it fully. The kit is great, i don't do track work just fast road hooning. It felt fidgety at low speed and a bit softly sprung at first compared to stock but that's misleading, the ride at speed and body control over fast rolling crests and dips is superb, the faster you go the better it gets which is a good sign. Now you can actually feel the tyres working which on stock suspension was masked. It let's the car move and roll but in a beautifully controlled manner. Some like the teeth jarring track setup, but that would spoil my M2 as, let's face it, its not a track car! Last edited by doughboy; 06-20-2022 at 04:13 PM.. |
06-20-2022, 04:11 PM | #74 |
The Seeker
13863
Rep 3,323
06-20-2022, 04:31 PM | #75 |
Rep 440
I have been very happy with my Öhlins. Worth to note that my shocks were valved differently (softer) than the standard RT kit and Öhlins is taking feedbacks from me to decide if this will be available for a "touring" kit that focused more for ride comfort and street use.
While I'm happy with the overall ride quality so far, they are sending me an extra pair of rear springs that are 20lbs softer than my current set to try. |
chris7197334.00 |
06-21-2022, 07:45 AM | #77 | |
The Seeker
13863
Rep 3,323
And yes, the helper spring, the ability to go lower, they are advantages of the V3 (if someone needs those advantages). |
06-21-2022, 08:42 AM | #78 | |
~Spyder
638
Rep 870
Related questions: 1. as most coilovers would "settle" after ~2k miles/a few weeks or so and would go even lower by about 5-10mm, should I wait to bring it back? 2. Afterwards, would I need to rebalance it? The shop balanced it right after the coilover install. 3. Dumb-ass question, but why can't I find the written installation instructions for these PSS B10 (they weren't included in the package). Dr Google yielded me with zero results…not even Bilstein's website had the actual pdf. I would like to see if I can adjust the height myself just in case. In a week or so, I will be taking off the wheels to ceramic coat them w/ CARPRO CQUARTZ DLUX Wheel and Trim Coat, and it will be a great opportunity to see if I can adjust the height myself. This is my first ever suspension upgrade so I have no idea what I'm doing, but it has to be some sort of rotating and locking collar? Anywho…I appreciate any input on this folks!
06-21-2022, 08:48 AM | #79 | ||
~Spyder
638
Rep 870
Aside from the front height which is too low for my liking (595mm, lower wheel to fender), these have transformed the car for the MUCH better: planted, more precise turn-ins/cornering with a more compliant overall ride.
06-22-2022, 03:52 PM | #80 |
Rep 566
06-22-2022, 04:21 PM | #81 | |
~Spyder
638
Rep 870
I was simply referring to height adjustment commonality between most coilover systems having spanner wrenches and rotating collars. KW, Ohlins, Bilstein, and yes, even M Performance should all use similar adjustments tools and techniques.
06-22-2022, 07:17 PM | #82 | |
Rep 566
On the subject: The rake you've got is not normal. Most likely not installed correctly, perhaps OE spring perch left in which isn't suppsoed to be there or something like that. The rake alone... I doubt the handling is balanced or the ride is really that supple with the ass up high. You probably should be aiming to get the ride at about level, with the front some 3-5 mm lower than the rear, measurements done as specified by BMW, get the alignment re-done with the correct height and load, set the middle soft/hard settings of the shocks, and take it from there. I think in your case maybe the most sensible thing to do would be to take the car to some other shop, who actually know what they are doing, and have it sorted it out for you. Certianly hope you get it sorted out. Cheers. PS: I have the installation manual in PDF but I don't know how to get it to you. |
No_curebimmer637.50 Rainey943.00 |
06-22-2022, 07:34 PM | #83 | ||
~Spyder
638
Rep 870
Funny enough, I have toyed with the idea of taking it to a different shop that specializes in suspension, especially after they stated that the front is the highest it can go. There are forum members w/ same setup and the front does not have the tires tucked in/low rider effect. From your comment, it seems the OEM spring perch isn't supposed to be left in (presumably the B16s come with one). So yeah, the shop said the right things: they set the F/R height delta according to BMW specs, and balanced (albeit not corner balanced). Heights are now 595 mm front and 610 mm rear (measurement taken from the lower part of the wheel to fender), but I'm wondering what it was stock (didn't provide that). I didn't think that coilover installation could be that complex for a solid BMW Indy shop where every tech is BMW Master certified (not sure to what level). So…yeah, something is amiss here. Now, with that said, does anyone in the Dallas - Ft Worth area have a recommended suspension shop? The ride has improved, but I am wondering if there is definitely room for improvement Cheers
06-23-2022, 07:30 AM | #85 | ||
The Seeker
13863
Rep 3,323
And yes, every time the suspension is moved up or down you need to have the alignment checked because an increase in toe will kill your tires post haste. |
06-23-2022, 01:23 PM | #86 | |
844
Rep 1,962
On the M2 you have to be doing something drastic before it has a major effect on front toe... Last edited by M Fifty; 06-23-2022 at 01:34 PM.. |
06-23-2022, 01:36 PM | #87 |
Rep 3,006
Is this correct. Before they pulled the TIS I believe it specified 612/615.
As a side note. My M2C was delivered with the MP Coilovers installed the height set at 595 mm/610 mm. They have since settled significantly and I plan to have them raised above the 595 mm/610 mm b/c it's too low for my street and while I'm at it, I'll suck it up and have the car corner balanced. No_curebimmer the attached PDF is the BMW MP Coilover installation instructions. Your height settings are spot on, see section 3. But you should be able to go higher. Note: seems the dealer set the rears at 610mm instead of the 600mm specified. Not sure why maybe there was an update?The image attachment is the alignment settings. Forget where I got this from so take it w/a grain of salt. The pictures are of my car are w/the MPC installed at delivery and 9 miles on the car. Last edited by omasou; 06-23-2022 at 01:58 PM.. |
No_curebimmer637.50 Sundinisagod107.00 |
06-23-2022, 01:53 PM | #88 |
~Spyder
638
Rep 870
Yes I just did, using a rudimentary tape measure.
For traceability and perspective: I measured from the lower part of the rim, straight through the middle/center cap, to edge of the fender. (believe this is the way BMW recommends?) Front = ~ 23.5" (597 mm) Rear ~ 24" (610 mm)
