02-14-2022, 10:59 AM | #23 | |
Rep 546
One last thing, is that I'll definitely be winter driving my car...is there any different in all-weather durability between these (rust etc.)? Sounds like MPS and KWV3 are quite similar, so I'm guessing they'd be the same? I'm a bit tempted to go with the KW even though I'll be like 80% just driving on the road, but only because it might be worth it for that occasional twisty?
'98 BMW 328i sedan (R.I.P.)
'16 Porsche Cayman GT4 '18 Porsche 911 GT3 Touring '20 BMW M2 Competition (6spd, Euro-delivered July '19) |
02-14-2022, 11:57 AM | #24 | |
The Seeker
13863
Rep 3,323
I've given you my take, having owned the stock suspension, MPS, and driven the KWV3 and researched the Ohlins, but M Fifty is more of an authority on suspensions, so you might ask him as well. |
white2abbit1122.00 |
02-14-2022, 12:14 PM | #25 | |
844
Rep 1,962
The only thing to watch is that the lower damping adjuster on the front struts is alloy, so with a little road salt thrown in to the mix will seize due to electrolytic corrosion of the alloy. Plan to either pack the space between the adjuster and the strut body with the kind of white grease used on mountain bikes, or adjust and reset the damping regularly and use plenty of WD40. HTH |
02-14-2022, 03:07 PM | #27 |
Rep 340
I would highly recommend the Öhlins given my personal experience of having them on both my original M2 and my M2 competition. Spring rates are just rates and there's more to the package than that.
Why I'd recommend the Öhlins R&T
Why I wouldn't recommend them
The difficulty in these threads is experiences are subjective. Very few people have probably driven/ridden in more than 1 or 2 of these setups. I myself have never ridden in an M2 that's not stock or on the Öhlins R&T setup. I assume if you have a GT4 (which I have been in on track) and you find the M2 suspension lacking, a stiffer spring rate is not something you'll be uncomfortable with. I'm not sure how a US purchase goes, but I'd highly recommend 3DM for an R&T kit. |
Fabb228.50 |
02-14-2022, 03:16 PM | #28 | ||
Rep 107
Looks like you're running the same winter setup as me. I have a little bit of rubbing on the stock suspension. I can imagine it would get worse when you change out your suspension. Based on what I could find the MPS seems to be able to stay closer to the stock ride height than KW V3's. Quote:
02-15-2022, 02:27 AM | #29 | |
Rep 555
Also KW is quite soft for track. Ohlins doesn't provide as much height drop but I'm not looking for the perfect stance. Also you will never figure out how to adjust the 3 way suspension as a normal dude. 1 way adjustability is way enough
IG: M2C_SO |
02-15-2022, 03:13 AM | #31 |
Rep 414
It is actually quite easy. Rebound, compression high and low speed. I literally wanted to fix some stuff on mine, changed a couple of things, it's as I want it. Quite simple really, if you know what you want (that is the issue more often than not )
02-15-2022, 06:35 AM | #32 | |
Rep 1,576
I tried a friend's M2C with B16s (Bilstein) on his car and they were lovely on the road. If your car is mainly driven on the road this is the one I'd recommend. If mainly track use, I think the others are right with Ohlins. I will definiltey be upgrading my MPS in the future. |
02-15-2022, 06:46 AM | #33 |
Rep 243
02-15-2022, 06:51 AM | #34 |
Rep 414
Squealing from the back dampers. Took many visits to BMW and lots of headaches to get it fixed through warranty. At the end I had to change my read dampers 3 times and at the front one valve screw got loose, meaning I also had to replace my both 2 suspensions arms at the front.
After getting it fixed I sold it immediately. The suspension itself isn't bad, but it is harder than stock, meaning for a daily I would not choose it. I've driven a KW V3 - very similiar to MPS - and it was much more comfortable. Just my 2 cents. And I bought it at 1600 EUR new (!!), I would never ever pay 2.500 EUR+ for it. |
02-15-2022, 09:12 AM | #36 |
Rep 1,576
Agreed B16 are lovely on the streets. Actually my favourite for road use of the ones I tried.
02-15-2022, 09:16 AM | #37 |
Rep 111
02-15-2022, 09:45 AM | #38 |
4693
Rep 2,542
We have spent a lot of time with the M2C dialing in our Nitron single adjustable kit with the help of Inertia Laboratory. We have come up with a combination of valving and springs that I am very happy with - excellent on the track and still has very good street manners. Have done very well in time trial competition with only the Nitron suspension and Essex/AP brakes against fully prepped track cars - not just in our class but also above it.
Going to be running in the Street class at Super Lap Battle at COTA this weekend. Not going to be competitive against the top "Street" cars (some approaching 1,000hp, lots of weight loss, full aero, etc) - but we should still hold our own pretty well though & have a lot of fun doing it. Adding in a bit of power this time around though too Bit more on the Nitron's in here: 223 - M2C Street/Track Build
04-12-2022, 09:47 PM | #39 |
Rep 192
Anyone using these https://www.motioncontrolsuspension.com I've heard good things about them but they are a little pricey
04-13-2022, 12:41 AM | #40 |
Rep 130
If you want track orientated coilovers then go for MCS, AST/Moton, Nitron, Penske.
04-13-2022, 01:04 PM | #41 |
Rep 546
I ended up going with KW V3, just getting them on today actually! Thanks for all the feedback ya'll.
x233284.00 |
04-13-2022, 02:03 PM | #42 |
Rep 126
04-13-2022, 04:28 PM | #43 |
Rep 2,291
Man, BMW M tax is a thing. Nearly $3K for coilovers is insane. Then again, I suppose I haven't bought coilovers in over a decade so who's to say what the norm is anymore. Is that really the going rate on suspension these days?
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed |
04-13-2022, 05:39 PM | #44 |
Rep 158
Coming from the VW world, prices appear to be similar for brake and suspension kits.
