M2 Technical Topics > Suspension | Brakes | Chassis > Camber Plates Design Comparison
      04-02-2021, 11:54 PM   #1
FaRKle!
For a while I've thought, "All the monoball camber plates are pretty much the same." Having the recent luxury of having three different makes of monball camber plates (Ground Control, Vorshlag, and Millway) and inspecting them further I've found that my perception was really wrong. There are clear design differences with each, translating into strengths and weaknesses.
Originally Posted by Index
-0:00 Intro
-0:25 Ground Control Overview
-2:21 Ground Control Thrust Bearing/Spring Perch
-3:50 Ground Control Strut Brace Ring
-5:59 Ground Control Camber Adjustment
-6:58 Ground Control Monoball
-9:34 Vorshlag Overview
-10:48 Vorshlag Monoball
-12:45 Vorshlag Camber Adjustment
-13:05 Vorshlag Thrust Bearing/Spring Perch
-15:39 Millway Overview
-17:14 Millway Thrust Bearing/Spring Perch
-18:49 Millway Monoball
-21:50 Camber Plate Mounting Hardware
-23:26 Closing Thoughts
*EDIT*
As a follow up, if you're wondering how to replace the monoballs in your Millway camber plates I made the video below on the process.
-0:00 Intro
-0:16 Monoball sleeve/shim removal
-1:26 Locking ring removal
-3:59 Pressing out the monoball
-6:09 Pressing in the new monoball
-9:25 Locking ring installation.
-11:51 Monoball sleeve/shim installation
-12:34 Monoball dimensions and closing remarks
Appreciate 14
M2Debt98.00
gphung193.50
mcvaughan704.00
Fabb228.50
redgs4320.00
Rundskop148.00
StephGOD218.50
FTP2034.00
ZM22810.50
widetyres279.00
ddnmkun153.50
      04-03-2021, 11:34 AM   #2
M2Debt
M2Debt's Avatar
98
Drives: '17 Alpine White M2
Concisely detailed, unbiased, and very well presented. Thanks for taking the time to make such informative content, this is a great buyer's guide.
I recently installed Ohlins R/T on my OG M2 and have been looking into adding camber plates, which I originally avoided to keep NVH down. Slight regret.
FaRKle!4016.00
      04-04-2021, 10:42 AM   #3
mcvaughan
mcvaughan's Avatar
Drives: F87 Competition
Thank you for this review. It has me considering moving to the Vorshlag from GC to reduce the spring noise I often have on my MCS setup.
Matt
      04-04-2021, 10:51 AM   #4
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Nice video!
It's too bad you didn't have a set of TCKline plates. Those are what I run and I find them very well done. Relatively low NVH and very solid.
Motorcity BMWCCA Member
Instagram | YouTube
      04-04-2021, 04:38 PM   #5
chief1richard
chief1richard's Avatar
2018 M2  [0.00]
Recently installed Vorshlag Camber Plates on 18 M2. Can highly recommend them. Zero noise or vibration. Was hesitant to use Camber Plates because of all the complaints of Noise and Vibrations. Could not be happier with them.
At a Point above 7,000 RPM.
mcvaughan704.00
Trub34.50
      04-04-2021, 04:54 PM   #6
McLaren720s
McLaren720s's Avatar
Drives: 2024 M4 Competition X
Good video!
I'm getting the Vorshlag camber plates installed in a few days. My shop recommended them over GC and Millway so that's what I went with.
      04-07-2021, 08:28 PM   #7
nando_514
Drives: None
Phenomenal video Farkle, thank you!! I remember seeing you a few years ago on Sheikhs old stuff! That guy is the real deal
      04-08-2021, 02:27 AM   #8
David.m
Drives: M2 LCI 6MT BSM
Great video.
Would be good to gather info of what max neg camber is achievable for each without having to remove the alloy brace for access to the plate adjustment screws. I believe the GC allow more adjustment because you can move 2 of the screws to other holes, but how the brace is fixed to the GC plates doesn't look solid.
I have Millway street plates, with Ohlins R&T (lowered 10mm with stock top hats) max camber leaving the alloy brace left on is -2.4. Between swapping in the Millway plates & -2.4 camber car dropped another 4-5mm.
n8dgr84173.50
Thevesh30.50
      04-08-2021, 04:31 PM   #9
Shadowfax028
Drives: 2016 BMW M235i
camber
Great video for starters. I to just install Ohlins with the GC camber plates. I love the Ohlins kit. The GC plates, I don't like at all. Tons of noise when driving slowly.
On my M235i I had the M2 Ohlins kit modified to fit the f22. I ran the Vorshlag Camber plates. Still a lil noisy but nothing like these GC plates.
LESSON LEARNED!!!! Now I need my CC .
      04-08-2021, 10:30 PM   #10
FaRKle!
Thanks! Yeah Shaikh was a good inspiration for me to really look deeper into what aftermarket companies were really offering us and how well that aligned with end-user goals. I've been very fortunate for his support to dyno all of these dampers! There's no other shop out there willing to invest in the community's education like he is.
Originally Posted by David.m View Post
Great video.
That's a good idea, thanks! I'll make sure to mention this being your idea when I document it.
Thanks for the data points! That's interesting the GC ones are so much noisier. I wonder if it's due to the weaker fastening torques, or just the multitude of parts in their design not being secured well.
      04-10-2021, 02:56 AM   #11
3t3p
New Zealand
455
I don't get camber plates, a tiny screw holds the position of a wheel on a heavy car? Or am I missing something
      04-10-2021, 02:10 PM   #12
mike082802
Drives: 2010 135
Originally Posted by Anthony1s View Post
I put the TC Kline's on a few weeks ago. No NVH increase at all. They also updated their design so adjustment is now slotted, instead of the fixed position adjustment holes we see in all pictures. It was a nice surprise, because all their website photos still show the old versions.
Mine are set at their lowest setting, which added 1.3 degrees of neg camber, and 1 degree of caster. Not sure if that is dependent on ride height though, so you might get different results depending on your coil settings.
got a pic of the new design?
thanks
      04-10-2021, 07:00 PM   #13
ZM2
Drives: 2017 LBB M2
Great vid.
Been running my Vorshlag's for 4-years, 50+ track days, 30k+ miles, and still working great.
M2RAW121.00
      04-11-2021, 05:17 AM   #14
CSBM5
CSBM5's Avatar
2721
Drives: 2019 M2 Comp, 2011 M3, etc
Great video! Thanks for the detailed look at these plates. From a mechanical engineering standpoint, it's an interesting look at 3 different approaches to a singular problem.
If possible, it would be nice to know stack height measurements for the camber plates versus the stock top hat. I know there are various claims made, but nothing beats measuring the actual end products.
I'm also curious about the monoballs themselves since I assume they are industry standard parts. I wonder what the specs are on each versus their application loads.
It's been many years now, I guess back in 2005, when I put GC camber plates on my E39 M5 when they first made them available, and for that design back then they claimed there was no increase in stack height versus stock. It turned out they increased stack height about 1/4" which was undesirable. Fortunately, they never had any rattles or clicks (sold the car in 2018), but they definitely increased NVH transfer. Once I installed monoballs in the thrust arms, then the NVH went way up all via the GC plates to the chassis.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac
2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg
2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8
      04-11-2021, 10:27 AM   #15
Commanderwiggin
Commanderwiggin's Avatar
2050
Drives: M2C - X3M - Turbo E46 M3 - 45E
Solid comparison; I've been very happy with my TCKline Camber plates.
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration
1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder
      04-11-2021, 10:32 PM   #16
xmq1990
Drives: bmw m2
never use ground control camber plates with onlins r&t suspension .
      04-11-2021, 11:19 PM   #17
FaRKle!
I thought about that, but would only be able to provide it for standard coilover springs. I think generally the stack up height comparison to OE is more useful when doing it for the OE spring perches (and I don't have those for Vorshlag or GC unfortunately).
CSBM52721.00
      04-14-2021, 10:21 AM   #18
FaRKle!
As a follow up, if you're wondering how to replace the monoballs on Millway camber plates I made the video below on the process.
-0:00 Intro
CSBM52721.00
n8dgr84173.50
mcvaughan704.00
      04-18-2021, 07:45 AM   #19
CSBM5
CSBM5's Avatar
2721
FaRKle!,
Off this topic, but pretty sure you know the answer -- does the front subframe on an F31 have to be lowered to change sway bars?
Current Stable:
      04-18-2021, 01:24 PM   #20
FaRKle!
FaRKle!,
Yes. Subframe has to be lowered for front and rear bars on all the F2x/F3x. I have some DIY videos for both on my channel.
CSBM52721.00
      04-20-2021, 10:13 PM   #21
Doublej
40
Drives: 2020 X3M, 2022 911 GT3
One thing on the GC plates and, I think the reason for the silver ring is it allows you to make minor caster adjustments. If you look at the underside, the 6 fasters have tiny slotted holes which would allow caster adjustment to some degree. Probably just to dial one side up or down to match the other.
I'm still deciding which I want. I've had GC before on a Golf R and had no issues. No noticeable noise.
Current: 2020 X3M, 2022 911 GT3
Past:
2020 M2 Competition,2018 X3 M40i,2017 X3,2016 VW ,Golf R,2015 BMW M3,2010 VW GTI,2008 911 GT3,2005 VW GTI,2002 VW GTI 337
      04-20-2021, 11:35 PM   #22
FaRKle!
The silver ring on top has no effect on caster. That ring is where the alu strut brace mounts to. On F2x/F3x cars that silver ring isn't included.
