09-06-2020, 10:58 AM | #46 |
6637
Rep 4,145
Drives: '18 M2 6MT
I haven't driven it much, but I can tell you it feels more bouncy. I don't mean to say it's a bad thing, just generally the car moves more when driving, if that's a better description. However, just like everyone says, it's less "crashy", so it feels less harsh (moves more, but less harsh movement). I'm going out to take some pix later and will get a better impression then.
BTW, I went 1-click softer on everything than BMW ships the suspension with. I had been speaking with a friend of mine that does suspensions for a living and he said that softer isn't always better, and recommended that I only do one click at at time for a 2-week minimum before making any other changes. |
09-06-2020, 11:29 AM | #47 | |
Recovering RS4 owner
297
Rep 266
Wei718339.50 |
09-06-2020, 11:33 AM | #48 | |
Rep 3,006
Not saying you didn't but I do agree that the lower gasket in the picture should be rotated clockwise by one hole to align ALL the holes. |
09-06-2020, 11:37 AM | #49 | |
844
Rep 1,962
For the nuts on the strut/damper shafts - not sure. I'm going with the part numbers on RealOEM. It could be the other way round? |
09-06-2020, 12:00 PM | #50 | ||
6637
Rep 4,145
Drives: '18 M2 6MT
Wise words.
They were all 4 identical, the taller one. Maybe some come with shorter ones? Maybe they updated the part number to use the shorter one in the rear for some reason? No idea. I'm going to send an email to the BMW parts for sure. |
09-06-2020, 01:32 PM | #51 |
844
Rep 1,962
Okay. For me, I'd want the taller ones on the front. So probably stick with what you've got.
The rings can be seen on all M3/4 and reinforce the body shell where the strut tops attach. How are you finding the driving experience? Having fitted it yourself you might be feeling a little tired, but hopefully you'll get to enjoy the fruits of your labour soon. |
09-06-2020, 01:42 PM | #52 |
Rep 1,089
Definitely! Thanks for the reassurance. I’ve used this method when I installed the KW HAS kit on my E92 M3 before but at that time I wasn’t sure if it were the right way or not.
09-06-2020, 01:48 PM | #53 |
Rep 4,516
loving the FG 437m 😍
Current '22 X3M LCI.. |
VisualEcho6636.50 |
09-06-2020, 04:27 PM | #54 | |
Rep 8,626
09-06-2020, 04:49 PM | #55 |
6637
Rep 4,145
Drives: '18 M2 6MT
09-06-2020, 04:49 PM | #56 | |
844
Rep 1,962
VisualEcho6636.50 |
09-06-2020, 06:06 PM | #57 |
6637
Rep 4,145
Drives: '18 M2 6MT
OK, just got back from a long drive and wanted to share my thoughts. I first drove my normal daily commute twice (only 5.4 miles round-trip), and then twice on my "fun" roads (about 11 miles round-trip on dreamy curves). I did this same drive last week and made notes so I could compare them exactly. I also matched the tire psi, and even the time of day to be as accurate as possible.
Here's a list of what was obvious to me. 1. The car definitely moves around more on everything from rough to super smooth pavement. I'm literally moving in the seat a lot more than what I was before. Another way to describe it would be that it's like the stock suspension was kind of floating on top of the road, whereas the MPS is following it much more closely. 2. All bumps, from the very smallest to the largest, feel quite a bit (20-40%) less harsh than before, which is fantastic. The noises I used to hear on certain bumps are now gone, or much reduced. Just wow, didn't expect that. 3. Most would consider the handling increased, as the car feels like it changes direction better now, but it also finds the limitations of the tires earlier and easier, so there is actually more sliding around than there was before with the same tires. Final thoughts. The whole reason I got the MPS was to drop the car, and it has done that perfectly IMO. And there are a few perks to the MPS as well, like bumps being less harsh, and the car feeling more point-and-shoot. However, since I use the car as a daily driver, I do miss the stock suspension's increased low-speed grip, and generally how it caused me to move around less in the car. And if you need that in list form: Stock: - Increased low-speed grip - I moved less in the car MPS: - Great drop - Bumps are much less crashy - More point-and-shoot feel |
09-06-2020, 07:41 PM | #58 | |
Rep 8,626
Thank you very much for that thorough comparo... I too was interested in these and even this week was asking around about qoutes for install prices. My main consideration for this was the improvement for the car in terms of it being settled on uneven surfaces, bumps and any uneven undulations. I think the stock suspension is incredibly bouncy due to rebound settings that are simply too firm... From what you are seeing, it seems that you are seeing the opposite effect w the mpss... I am concerned about this. As far as your grip issues, those could probably be easily resolved with more aggressive tires. |
09-06-2020, 09:12 PM | #59 | |
6637
Rep 4,145
Drives: '18 M2 6MT
The thing that ISN'T minor is how composed the suspension is. So much less crashy, and wonderfully so. This is the suspension that should have come on the car IMO. And a shot from tonight. |
09-07-2020, 08:12 AM | #60 |
6637
Rep 4,145
Drives: '18 M2 6MT
After driving the car a bit yesterday, and taking some pix, I did a measurement.
All the way down on the rear gave me a 19mm drop. 3.5 threads showing on the front gave me a 25mm drop. Spacers are 10mm rear, 12mm front. The car sits pretty much where I wanted, but I may lower the front just a bit more. The weirdest thing is that I can't for the life of me get a decent picture. This is as clean as I can make it, and it still doesn't show what reality looks like (looks much lower in real life). It's the shadow on top of the tires, it makes the gap seem more and the sidewalls seem skinnier than they really are. |
ASAP10161.00 |
09-07-2020, 08:19 AM | #61 |
6637
Rep 4,145
Drives: '18 M2 6MT
This one shows it a bit better because the light is directly on the sidewalls. And you can see what a marked difference there is between the look of the gap and tires between the two pictures, though they were taken just minutes apart.
ASAP10161.00 |
09-07-2020, 11:55 AM | #62 | |
Rep 396
Reduce the front compression by several clicks (not just one) and go for another drive. Keep reducing until you are satisfied with front end grip. If the car dives under brakes go back the other way a bit. Find a safe sweeping bend and push the speed to the limit of grip. Don’t give it a boot full and force power oversteer. Just feel how it grips at constant throttle. At the limit, the rear will probably want to slide first now (oversteer). Soften the rear compression progressively until the car retains neutral handling. If you can get a gentle four wheel drift out of it you’ve nailed it. Once you have the grip and balance where you want it you can tweak the rebound settings. Those will depend far more on the type of roads you drive and the speed you intend to drive at than the grip or balance of the car. |
4
09-07-2020, 01:42 PM | #63 | |
6637
Rep 4,145
Drives: '18 M2 6MT
09-07-2020, 06:28 PM | #64 |
Rep 1,054
Great thread and detailed explanation VisualEcho.
The front definitely settled for me a little. It looks aggressive in a good way...without being slammed. The rears were adjusted somewhat recently, so I will have to see how far they settle. I do believe the car needs wider rubber, and am going 255/275 next...at the minimum. Although, I do want to tweak the front compression as Caduceus mentioned as well. I also agree, the M2 (and Comp) should have came with this suspension as stock. I am enjoying the car even more so with the MPSS installed. But obviously then it would not be a sub $60K car. Which is a magic number price wise in the car industry. Last edited by csbear; 09-07-2020 at 06:35 PM.. |
VisualEcho6636.50 |
09-07-2020, 08:27 PM | #65 |
Rep 3,006
Measurements
595mm/600mm August 2019 installation 590mm/593mm March 2020 after sitting in garage all winter 590mm/595mm P/A; 585mm/590mm D/S September 2020 I find it strange that the springs would settle this much or that the set screws on all four sides are not set? Either way seems I need to pull a wheel and definitely raise it back up before installing a front splitter. I know it's a bit late but finally got around to taking a picture of my front suspension and surprised it's set so low. Last edited by omasou; 09-07-2020 at 08:56 PM.. |
VisualEcho6636.50 |
09-07-2020, 08:33 PM | #66 |
Rep 8,626
looks perfect to me
VisualEcho6636.50 |
