11-23-2017, 08:20 AM | #1 |
Rep 3,807
Drives: Retired 2017 F87 M2
Wheel stud conversion
I am doing a wheel stud conversion for my car mainly for me to be able to install 15mm spacers infront and for me to have an easier time changing rims.
So i have to ways of achieving this: 1. Is to do a wheel stud conversion, meaning installing long studs to the hub , puting on the 15mm spacer and using lug nuts to hold the rims. Or 2. Get a set of h&r 15mm hub adapters that are bolted to the hub and then installing the extended studs on the adapter where in I would mount the rims on and lock them in with lug knuts. The question is which is the better way to go in terms of safety. Cause i have quite a number of shops refusing to do method 1 because of safety issues
Retired: |2008 328i Sedan|Montego Blue| |
11-23-2017, 05:41 PM | #2 |
Rep 3,807
Anyone?
11-24-2017, 11:22 AM | #3 |
Rep 570
#1 - racing wheel studs remove the compromise that the factory makes for production, cost, and serviceability reasons. Racing studs are stronger, provide a better inherent torque/load configuration, and make tire changes much easier. I believe that normal retail tire places don't want to work on cars equipped with racing studs, just for liability reasons. They need to be installed correctly By someone that understands how to properly install them and seat the studs
11-26-2017, 08:17 AM | #4 |
Rep 3,807
I guess I will need to find someone who knows how to do it. Thanks for the input.
02-19-2018, 08:06 PM | #5 | |
Rep 77
studs
02-19-2018, 10:00 PM | #6 |
Rep 570
What sort of Studs did you buy? Some have a flat in the center that you can get a wrench on. Usually it's around 25 foot pounds to seat them properly with Loctite. In my case, it was just a round stud, so you had to double nut the stud until you feel it seat...And it felt right around 25 to 30 pounds by my wrist calibration. The most important part is to feel them seat and almost bottom out without overtorquing. If you haven't done it before, you may just want to get some help.
02-20-2018, 11:59 AM | #7 | |
Rep 77
studs
02-21-2018, 01:17 PM | #9 |
813
Rep 526
We use Motorsport Hardware conversion studs on our M2. One end of the stud has the M14x1.25 thread that threads in to the OEM hub, and the wheel side has M14x1.5 threads to prevent stripping when removing wheels over and over again. The studs also have allen fittings in the end to install them. We've used them on track with 15mm spacers without no problems!
https://store.activeautowerke.com/co...-nose-stud-kit |
gsrbri559.50 |
11-11-2018, 02:30 PM | #11 |
Rep 168
Hey everyone, revisiting an old topic..I am going to use the apex racing stud conversion kit. the torque recommendation for the torque for the M2 nut bolt of BMW factory vs the nut for apex kit is different. 105 ft pound vs 85-90 ft pound to be exact. Any suggestions for this? Thanks!
