04-17-2023, 11:56 AM | #155 |
Rep 75
I got it back from the shop and they said it wouldn't fit anymore and I haven't tried.
2018 M2 with a few mods.
Charge, boost and inlet pipes, Nexsys, Stage 2 HPFP, Stage 3 LPFP, Stage 1 injectors, TC Klines, Phoenix intake manifold, Bend Calibration fuel filter, Turbosmart BOV, PTF BM3 Flexfuel kit, BM3 custom tune, xHP trans tune, CTS Boss turbo, Full SPL, diff bushings, motor & trans mounts |
ericlr1225138.00 |
04-19-2023, 11:04 AM | #156 |
Rep 255
05-23-2023, 02:41 PM | #158 |
Rep 643
not apples to apples, since i am on m235i (n55 ewg) stage 2+ MM v1.3, but working as it should on e30 map, 93 map, and flat torque map.
you looking for something specific? here's my latest logs (back to back, first with 93, then filling up to about e40) using WMI 93 map: https://www.bootmod3.net/log?id=6468...90c605604263f3 e30 map: https://www.bootmod3.net/log?id=6468...729beaa27d4206
M235i rwd 6mt
ZM22827.50 |
05-23-2023, 06:49 PM | #159 | |
Rep 4,195
Mods: Yes.
05-24-2023, 12:03 PM | #160 |
Rep 643
that's just what the tune is, not an adaptation issue. you can see there were no timing corrections on cyl 3-6
M235i rwd 6mt
05-27-2023, 06:59 AM | #161 | |
Rep 3,709
https://bootmod3.net/log?id=6471344fc090c66243bfeef0 Looks like 1psi less boost than v1.1 to help the stock turbo guys. |
05-30-2023, 09:41 AM | #162 | |
Rep 643
your target boost is less than mine, your timing is way higher, and your lambda is quite a bit leaner.
M235i rwd 6mt
05-31-2023, 06:47 AM | #163 |
Rep 3,709
Yeah, the N55 and M2 OTS maps are a bit different. I am getting more timing advance from the PTF Flexfuel sensor and E50.
06-05-2023, 08:30 AM | #164 | |
Rep 643
if so, then this is saying that even with flex fuel feature enabled, and you have e50 fuel in the tank... then it matters which map you select? i would assume then if you had 93 oct in the tank, then you should NOT be running the e30 map even with flex fuel enabled? this can be dangerous since the multimap for f3x/f2x defaults to map 1 (e30) and an unsuspecting person could be fueling up with 93 oct and be none the wiser
M235i rwd 6mt
06-06-2023, 10:25 PM | #165 | |
Rep 255
06-06-2023, 10:28 PM | #166 | |
Rep 255
06-06-2023, 10:37 PM | #167 |
Rep 3,709
Log?
There’s a different tune strategy with v1.2. The target is there as kind of a ceiling, but other parameters are now being used to let actual boost float to a max level while keeping the turbo in its efficiency range. I have a v1.3 map that does that for my TTE460, just haven’t had a chance to post v1.1, 2, and 3 up with logs and discussion to compare. Should have time soon. |
06-06-2023, 10:50 PM | #168 | |
Rep 255
I remembered cuz when v1.2 came out on early april. I flashed immediately. BM3 has a bug for dorch stage 2 hpfp config. Car is undrivable, I think I posted in this forum. Then I worked with them and did a log with their test map on 04/26. They updated it couple hours later. https://www.bootmod3.net/log?id=6449...729bd12ab6de7f This is the only one I saved on 04/26, Ignore how bad the timing is. I did this just to make sure hpfp is functioning and send it back to ptf. |
06-19-2023, 02:24 PM | #169 |
Rep 212
Hey guys. I'm currently running the multimap stage 2 tune and seeing lots of timing corrections/knock occasionally. I didn't want to derail this thread, but if anybody would like to take a look at my logs and let me know your thoughts I would really appreciate it.
https://f87.bimmerpost.com/forums/sh....php?t=2025961 |
06-24-2023, 09:42 PM | #170 |
Rep 55
I don’t seem to have v1.2, but I just ran v1.1 on track with ~E47 in cloudy 65 degree weather on my stock turbo. 5 sessions and everything ran beautifully, although I haven’t done any logging. It was incredible being able to keep up with a stock G80, older model R35 and a GT4RS (kinda) on the straights.
I was going to install the PS2 I have and run this tune, but I think I’ll try out the Pure500 instead—I love the stock turbo response, but I’d like a little more peace of mind and top end power |
ZM22827.50 |
06-27-2023, 12:09 PM | #171 | |
Rep 255
https://www.bootmod3.net/log?id=649b...729bd16b4aa798 |
06-27-2023, 01:21 PM | #172 | |
Rep 5,400
Drives: 2015 BMW 335i x-Drive Auto
The MultiMaps for the 335i N55 EWG currently look like this below with the version numbers and the Map slots. Are they identical for the M2 N55 EWG? BM3 MultiMap Stage1 version 1.2 Map1: ACN91 Map2: 91 Map3: 93 Map4: M2 N55 stock power level BM3 MultiMap Stage2 version 1.2 Map1: ACN91 Map2: 91 Map3: 93 Map4: M2 N55 stock power level BM3 MultiMap Stage2+ version 1.3 Map1: E30 Map2: Racegas Map3: 93 Map4: Flat Torque Map (500NM) |
06-27-2023, 02:28 PM | #173 | |
Rep 3,709
Altho, our v1.2 lowered boost some from v1.1 and changed the tune approach so it’d work better with stock turbos (even tho v1.0 & v1.1 worked fine with my TTE460). |
johnung4541.00 |
06-27-2023, 03:35 PM | #174 | |
Rep 4,195
Mods: Yes.
johnung4541.00 |
07-05-2023, 09:22 AM | #175 |
Rep 3,709
Finally had a moment to post logs of the v1.0 multimap vs v1.2 vs a Stg 2++/3 version that Halim gave me for my slightly larger turbo.
Differences: Stg 2+ Multimap v1.0 pegs boost at 20.8-psi thru the rev range. My setup could hit that no problem, but Halim released v1.1 & 1.2 which changed the tuning strategy so that the guys with stock turbos could run the Mutlimap with no issues. It means a little less power for my setup (and why Halim gave me a Stg 2++ Multimap to use), altho, I potentially like the tuning strategy a lot more for the track. You'll note in the Stg 2+ v1.2 and Stg 2++/Stg 3 Multimap logs that the tune is no longer pegging boost, instead boost is higher at lower rpms and drifts lower in higher rpms (3-4psi lower at redline), keeping the turbo in a higher efficiency zone & lower WGDC in upper rpms. For me, that means I should be generating less heat on track, albeit a little less power, but probably worth the trade off. Stg 2+ MM v1.0 log https://bootmod3.net/log?id=6333161dd10b432642ac8a1b Stg 2+ MM v1.2 log https://bootmod3.net/log?id=6471344fc090c66243bfeef0 Stg 2++ (Stg 3) MM log https://www.bootmod3.net/log?id=647b...90c6aa737bb893 Last edited by ZM2; 07-05-2023 at 09:43 AM.. |
TUDMG21.00 |
07-29-2023, 12:03 PM | #176 |
Rep 30
Hi guys. I just installed Dorch stage 1 hpfp and flashed bm3 stage 2+ multimap. İ do have a flex fuel sensor and i have E34 in the tank. Went out to test the car on the E30 map (first slot). Was doing a 3rd gear pull and even though the car pulled hard I was getting what I would describe as "hiccups" from the engine - a few times during the pull. First I thought it was wheel spin but then after doing couple more pulls I figured it's not coming from the tires. I haven't done a log yet but I will do it on my next drive when there are less cars out. Has anyone experienced this or has any idea what it could be?
