11-14-2014, 01:22 PM | #23 |
Chief Warrant Officer
1025
Rep 1,638
Not if they push the price of the car up by $8k just for brakes that 90% of buyers don't need. They should be an option, not standard. Otherwise they will artificially inflate the entry price of the vehicle up to around $60k, which will be a deal-breaker for a lot of people, based on the feedback from this forum.
In fact, if they came as a no cost option, I would NOT get them. Here is why: I will be honest: I am one of the 90% of potential buyers that will never really need the marginal performance upgrade. I am not a poseur - I am simply a driving enthusiast who enjoys spirited driving and wants a great DD for track use 2-3 times a year. So if I am not likely to need the upgrade, why would I opt for a relatively fragile component that costs 10x as much to replace and is 100x more likely to get chipped, dinged, or otherwise inadvertently damaged. I actually think that most of the people who DO get them will be poseurs because they are the cool "gotta have it" performance item. "check out my bitchin' CC brakes, brah" |
11-14-2014, 01:25 PM | #24 |
Rep 657
I just did a search for replacement M3 rotors: $4500 each was the lowest I found.
There's an article in the latest Panorama (PCA magazine) by a Boxster owner with PCCB. Six track days and the wear indicators were showing. His lap times improved after switching to iron Probably not the result of brakes, but clearly the iron rotors didn't slow him down. Make mine metal until the technology improves and the cost comes down. |
11-14-2014, 01:52 PM | #25 | |
Rep 365
- The same racing drivers also dislike the consistently of brake modulation with ceramics, which changes with temperature. Some also report poor release characteristics. So it just depends on how extreme your requirements are. For light tracking, ceramic should be no problem. An option better suited to street cars IMO. The big caveat is that ceramics are improving with every generation, so who knows what we'll get on the M2. Nor do I think people really would track the M2 as hard as some other ground up sports / race cars. Let us know how they are in two years! Last edited by vantagesc; 11-14-2014 at 02:10 PM.. |
11-14-2014, 01:59 PM | #26 |
Rep 898
Drives: '69 GT3, GT4, 1M, 912
GT3 SuperCup cars, as opposed to the regular GT3 Cup cars, use PCCB ceramic brakes. They work well with slicks and motorsports pads. They changed rotors every other race weekend as of a couple years ago, I'm not sure if that has increased recently with the move to larger rotors.
1M, GT4, 1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
11-14-2014, 04:07 PM | #27 |
General
17528
Rep 25,128
surely this might as well be do you intend to track your M2. For me not really or very infrequently so no, not for GBP£6000. Thats a lot of fuel covered in Sport+
My car made front page of Bimmerpost
11-14-2014, 07:08 PM | #28 | ||
Croatian
884
Rep 3,613
Drives: PORSCHE
NARDO GREY '18 PANAMERA TURBO
Ducati V4 S Corse (track only) Husqvarna FS450 (track only) Looking for an SUV |
11-14-2014, 08:55 PM | #29 |
Rep 75
If I could easily afford them I'd get them, both for the slight performance increase and the pride of ownership factor, but given the huge law of diminishing returns of ceramics over the best standard set-ups it doesn't bother me at all that I can't.
11-16-2014, 01:09 AM | #30 |
Rep 686
I do hope they're offered as an option.
I would hate to see BMW significantly handicap the M2, just because of the M3/M4 M2 vs M3/M4 debates will look very similar to Cayman vs 911 debates Last edited by LDSM; 11-16-2014 at 01:18 AM.. |
11-18-2014, 05:46 PM | #32 |
Enjoying driving
388
Rep 1,169
Are you sure lack of pad choices is what is keeping Cup cars from using PCCBs? I know Porsche offers motorsport pads for PCCBs, so probably there is another reason. May be, do you think, the racing series rules do not allow it depending on the Cup car version? As Pete_vB mentions Supercup uses them. Also, when Supercup used to use steel rotors, they were changing rotor each weekend and quite often twice a weekend, now they trippled the duration of rotor durability under racing conditions.
12-07-2014, 12:48 AM | #33 |
Rep 433
Seems everyone is ignoring the big loss in unsprung and rotating weight with CC rotors. Had a chance to talk with Boris Said about an M3 that he spec'd for himself. Only options: 6MT, LED, and CC brakes. His reco: if you track a lot or race, definitely CC. If it's a DD with an hpde 1-2 times a year, regular works great.
'07 e90 335i - SG/Black/Alum | 6 MT | Sport | Premium | Nav | CA
Dinan Stage 2 Tune, Stage 1 Suspension | BBS RS-GT |
12-08-2014, 12:53 PM | #34 |
Rep 988
I highly doubt the CCB is anything other than a negligible factor in why the M4 is faster than the RCF, the 415lb weight difference on the same size rubber (and better rubber on the M4) play a far larger role. Steel brakes will stop just as quickly as carbons until your start pulling a ton of laps and they become heat soaked
12-08-2014, 01:20 PM | #35 | |
Rep 401
Drives: 2012 911GTS & 2014 X1
04-09-2015, 03:54 PM | #36 | |
Rep 13,136
http://f80.bimmerpost.com/forums/sho....php?t=1107233
///M is art ↔ Artemis
04-09-2015, 04:11 PM | #37 | |
European Editor
10596
Rep 22,992
BMW wasn't smart like Porsche when it comes to their first generation CCB. BMW's CCB's don't have wear dots or bars. Instead... you MUST disassemble the entire braking system. Weigh the CCB rotor, and THEN you will know IF they are worn out or not. Can you imagine the repair bill to check your brakes? Dackel
04-13-2015, 03:02 PM | #39 |
Rep 115
If I could afford it I woul. There is one racetrack an hour away from the city, but it is small and there are not many open events.
Aggressive pads and rotors for autoX would be sufficient for me. CCBs would be balleur. |
04-13-2015, 06:32 PM | #42 |
Rep 13,136
...and lots of fuel (another bare necessity for driving pleasure) !
04-13-2015, 08:08 PM | #44 | |
Enjoying driving
388
Rep 1,169
