01-25-2018, 12:42 PM | #1563 | |
Rep 719
Also the 4 blinks ! Very helpful |
01-25-2018, 02:42 PM | #1565 |
Rep 2,924
WIFI
BMW ///M Club Montreal
BMW ///M Club Montreal Facebook Page |
AndrewC198910931.00 |
01-25-2018, 02:57 PM | #1566 |
Rep 5,457
Drives: F30
I have WiFi as well, Vgate iCar v3. Works great.
01-25-2018, 02:58 PM | #1567 |
Rep 919
Drives: F30 328d Sport Line
01-25-2018, 03:01 PM | #1568 | |
Rep 919
I don't yet have BimmerCode or the OBDII adapter. My question is, it is easier to code the driver's seat using BimmerCode or e-sys? I'm debating purchasing BimmerCode and the adapter, but I've already purchased the e-sys cable and started learning e-sys. |
01-25-2018, 03:23 PM | #1570 | |
Rep 919
I want to code the following: Mirrors fold on lock Speed displayed on BC M Sport Gauges on head unit Remove all disclaimers Remove cold temp warning Add beep on lock/unlock Enable door LEDs on reverse Display volume pop-up on head unit Easy entry (program driver's seat) Do you recommend using E-SYS or BimmerCode? I read that BimmerCode on Expert Mode is similar to E-SYS but easier to use... |
01-25-2018, 03:23 PM | #1571 | ||
Rep 4,551
Drives: 2015 328d xDrive
Benefits - You can force the valve shut (for cold starts) and open (to make more noise) Cons - You have to buy hardware or an app to do it. How to do it - Bimmerlink app, Jb4, Awron guage or Macht Schnell (EVC) Module |
01-25-2018, 03:39 PM | #1572 | |
Rep 4,551
haagm58809.50 NYC Bimmer259.50 |
01-25-2018, 03:46 PM | #1573 | |
Rep 919
01-25-2018, 04:45 PM | #1574 |
Rep 82
backups
Does anyone know how to make a backup? I've read that the app makes auto backups but when I choose "restore" it only restores to the og restore point I think. I'd like the option to create multiple restore points to troubleshoot, etc. I'm on android if that makes a difference.
01-25-2018, 04:57 PM | #1575 | |
Rep 4,551
It doesn't overwrite the old one, it makes a new one. They are sorted by date and time chronologically. If you've only coded one thing you'll only have one back up file. I'm on IOS. Not sure if the android app works differently. I assume they're identical. |
NYC Bimmer259.50 |
01-25-2018, 08:48 PM | #1577 |
Rep 4,551
01-25-2018, 08:58 PM | #1578 |
Rep 2,577
I prefer white/orange lighting like attached picture when headlight is on (default is full orange, which I am not a big fan of). It'd be even better if brightness increases a little bit. Thanks.
Lemania 2320
01-25-2018, 09:00 PM | #1579 | |
Rep 4,551
I've tried it myself just to make sure. Doesn't work. http://www.bimmerfest.com/forums/sho...&postcount=111 |
NYC Bimmer259.50 |
01-25-2018, 10:34 PM | #1581 |
Rep 25
Carista?
I have been using the bimmerlink app for exhaust flap/asd control with the carista obd wifi connector. Is there any way to use bimmercode with carista? For some reason my car has not picked up the signal for any vgate device I've tried.
01-25-2018, 10:45 PM | #1582 |
Rep 251
Tried to code the "One Touch" Lane change count from 3 blinks to 4 but couldn't find it in FEM_01 module. Not sure where it's located at. Any thoughts? Thanks.
BMW M2 2018 LBB
BMW X1 2016 PSM Audi S4 2014 SMG |
01-25-2018, 10:46 PM | #1583 | |
Rep 82
And when you choose "restore" it lets you select a restore point? I don't seem to have that option on android. Anyone with android know? I'll check with Bimmercode as well. |
01-26-2018, 12:18 AM | #1584 | ||
Rep 4,551
Select it. Click the backups button in the bottom right hand corner. Pick the one you want to load and it will restore those settings. Quote:
My 2017 used to have the option and after a software update it ceased to exist. Also don't recall that there was ever a 4 blink option. It was 3 or 5. |
NYC Bimmer259.50 |
