05-14-2018, 05:33 PM | #1 |
Rep 780
Stock Exhaust Tip Removal ***Easy***
So researched this for days. Some of the vids show claw hammers, some people smacking with rubber mallets.....on and on.
For those who have not done this: Spray the backs with WD40. Wear grippy gloves and twist and pull. Some are easier than others. They are all easy though. Took me 5 minutes tops! The clips are near the front so once you have moved the tips forward 1/2 an inch you can spray WD40 in back part (in the gap).
05-15-2018, 04:49 AM | #2 |
Rep 2,197
2 of mine were piss, the other two required a lot of hammering.. took half an hour for the stubborn two
So far: 200cell downpipe, custom exhaust, lifhtweight splitter, m4 comp seats
05-15-2018, 11:02 AM | #3 |
Rep 780
Maybe I'm stronger than I look!....my car is new though. When you see how they work you realise that spraying WD40 then moving the tips from side to side and up and down should allow them to just come off. The clips are not strong.
05-15-2018, 11:26 PM | #5 | |
Rep 6,635
05-16-2018, 06:19 AM | #6 |
Rep 780
I would think that with WD40 that breaking the clips would be highly unlikely. Also you are more likely to bend them but even then you could straighten them after you have them off. There is nothing for them to catch on unless your exhaust pipe has an exceptionally bad seam weld...which I doubt exists.
06-06-2018, 08:50 AM | #7 |
Rep 1,761
Drives: S2000, MacanS, M4CS
I used oil filter wrench to pull these out. what a PITA
2020 ///M4 CS, Alpine White, DCT
2018 ///M2 LCI, Metallic Orange, 6MT, Exec Pkg, Apple.. Sold Instagram: Tommys911 |
06-07-2018, 07:11 PM | #8 |
Rep 60
I used what we call multigrip pliers. Opened to loosely sit on the pipes in front of the tips and nestled against the tip, tap with a soft hammer and they come straight off without damage.
06-25-2018, 08:36 PM | #9 |
Rep 112
Drives: 2017 BMW M2 - Mineral Gray
Yup, same thing I did. Sprayed them on the inside with wd-40. Let it sit for 5-10 mins. Wiped off tips, get rid of excess wd-40 and dirt. Then wiggle back and worth a bit to get it loose. The outside tips on both sides were the easiest. They came off just by wiggling back and worth. The inner tips I wiggled a bit but wouldn’t come off as easily. I took a rubber mallet and tapped the tips in, towards the car. Then those tips were able to slide much easier by just turning the tips and pulling them outwards.
10-07-2018, 11:02 PM | #11 |
Rep 77
tips
I installed my Cyba tips yesterday. I sprayed the stock tips with WD-40 as above, and let them sit for a while. On the first one, I used a strap wrench to wiggle it back and forth to loosen it. Then I put the end of a stubby flathead screwdriver against the end and pounded it off. For the remaining 3, I skipped the strap wrench and just pounded them off with the screwdriver and hammer. I'd say it took me about 45 minutes to get them all off. My only regret is that I didn't have a lift!
12-16-2018, 05:16 PM | #12 |
Member
899
Rep 2,032
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [10.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
What tips did you buy and from where?
2019 X5 Alpine White M-Sport
Software Version 11/2022.31 2023 M2 (HEA) Brooklyn Gray 2021 330i XDrive Alpine White M-Sport |
06-10-2019, 01:16 PM | #14 |
Member
899
Rep 2,032
If you are talking G05 X5 and putting on the Shadowline Exhaust Finishers you will need to remove the rear bumper. I know this because I had to get the dealership to install them on our G05. The job takes 3 to 4 hours. I think there are some aftermarket 50i type finishers on eBay that are stick on.
