M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > 265/40R19 at the rear?
      01-21-2024, 06:15 PM   #1
abcfgh
Drives: BMW 328i
Anyone know if 265/40R19 tires will fit at the rear without rubbing? Found an insane deal on tires and would like to run them if no rub.
      02-13-2024, 11:06 PM   #2
BluOGM2
BluOGM2's Avatar
37
2018 bmw m2  [10.00]
I think you should be fine, I had the 275 with 40 in the rear and they would would. So the lack of 10mm should help
      02-14-2024, 07:46 AM   #3
///MPhatic
The Seeker
///MPhatic's Avatar
13863
Drives: OG M2 • Exige
It depends.
Just go to tirerack.com and compare the OD and TW of the stock tire to the OD and TW of the tire you're looking at. No other parameters matter.
If you're not dropped you'll probably be fine, but also consider if you're regularly driving with rear passengers on very bumpy/fast roads.
      02-14-2024, 03:17 PM   #4
David1
David1's Avatar
Drives: 09 E92 09 X5
Your speedometer will be even more off than it is now.
