Classifieds Section > Sponsors Classifieds > TC Kline Racing Camber Plates F87 M2
      07-07-2022, 01:49 PM   #177
HP Autosport
Drives: F80 M3
bump
      07-29-2022, 11:14 AM   #178
HP Autosport
Drives: F80 M3
bump
      08-11-2022, 11:13 PM   #179
HP Autosport
Drives: F80 M3
bump
      08-26-2022, 11:17 PM   #180
HP Autosport
Drives: F80 M3
bump
      09-11-2022, 11:08 PM   #181
HP Autosport
Drives: F80 M3
bump
      09-12-2022, 08:00 AM   #182
ZL9M2
Drives: '17 M2 ZL9-'20 M2CS-'68 1600
Make sure you loctite the top nut on these or it will slowly loosen.
      09-12-2022, 04:02 PM   #183
HP Autosport
Drives: F80 M3
Always a good idea with any suspension component. Witness mark so you can easily check later as well.
      09-23-2022, 12:02 PM   #184
HP Autosport
Drives: F80 M3
bump
      10-11-2022, 09:25 PM   #185
HP Autosport
Drives: F80 M3
bump
      11-15-2022, 03:26 PM   #186
HP Autosport
Drives: F80 M3
bump
      12-07-2022, 02:37 PM   #187
HP Autosport
Drives: F80 M3
bump
      12-20-2022, 05:25 PM   #188
HP Autosport
Drives: F80 M3
bump
      01-06-2023, 05:52 PM   #189
HP Autosport
Drives: F80 M3
bump
      02-05-2023, 08:55 PM   #190
HP Autosport
Drives: F80 M3
bump
      03-03-2023, 02:23 PM   #191
HP Autosport
Drives: F80 M3
bump
      03-26-2023, 05:40 PM   #192
HP Autosport
Drives: F80 M3
bump
      04-11-2023, 11:31 AM   #193
HP Autosport
Drives: F80 M3
bump
      04-11-2023, 12:41 PM   #194
ZL9M2
Is there a "taller" top nut available for these Kline units? Could the lower collar area just be machined differently so that the hex area sat higher? I only have one box end wrench that is able to "grab" that top nut to tighten it. The nut sits low so that there is not a significant area available to mate with a wrench. I may try to find a few washers to fit underneath those top nuts. . I've also had these top nuts loosen..
      04-11-2023, 07:47 PM   #195
HP Autosport
Drives: F80 M3
They are already a long reach style nut. Typically, installation on Koni and MCS is not an issue. What are you installing them on? A little blue loctite is recommended for the top nuts.
Anything custom you will have to contact TCKR for custom made hardware.
      04-11-2023, 08:34 PM   #196
ZL9M2
This is on a 2017 ZL9 Performance Package m2 with the M Performance suspension. You can barely grab the top of that nut. Another 3..5 mm in height would be perfect.
      04-12-2023, 11:44 AM   #197
HP Autosport
Drives: F80 M3
M Performance/KW isn't one of the fitments. If you somehow got it to work and need special hardware, contact TC Kline Racing.
