07-31-2018, 10:19 PM | #24 |
Rep 3,703
08-04-2018, 09:06 PM | #26 |
3885
Rep 54,481
Drives: F80 M3
When breaking new pads with used rotors the brakes may feel softer for a while due to uneven surfaces but should go away after a full bed-in process.
Yellowflash21369.50 |
08-08-2018, 12:59 PM | #28 |
3885
Rep 54,481
Drives: F80 M3
08-16-2018, 11:47 AM | #29 |
Rep 344
Just had my DS 1.11s fitted today before track days on Saturday - Sunday and have few questions:
1. The red check brake system light - drive moderately is on - this is normal without pad sensors right? There is no way around it? 2. SA told me that they can damage my calipers in the long run as they have no counterweights (something like that) and they are a bit loose. Is that true? 3. They make noise when reversing - a loud metallic clash, that is normal also right? 4. After the few track days this year I want to go back to an aggressive street pad staying in the family with minimal bedding in so DS2500. Do these come with wear sensors or can sensors be attached to them? I have to say that in comparison to OEM pads they are amazing. Just followed the Essex bedding procedure and they are neck braking initially and have nice progressive constant feel when heated up. Will see at the track but they are very good already and I even like the noise |
08-16-2018, 12:31 PM | #30 |
Rep 350
1. Did you remove the sensors entirely, i.e. unclip them? I use zip-ties to strap the sensors out of the way, usually to themselves or somewhere on the suspension where travel won't interfere, the sensor is still connected and no lights appear but the sensor wouldn't do anything.
2. I can't say but I thought the counterweights are for reducing squealing and vibration, I don't think they'd have other noticeable effects. 3. Yes, the pads don't have anti-rattle shims and are a bit looser so they will clunk the first time the brakes are applied after any change of direction. It is the pad literally sliding to the top or bottom of the caliper. 4. They wouldn't come with the sensors, sensors are usually bought separate to the pads (usually pretty inexpensive). HP Autosport or anyone that has the DS2500 would need to confirm whether the pads have the cut out for the sensor to slot into. |
08-16-2018, 02:55 PM | #31 | |
Rep 344
Ad 1. My BMW Service Center did the swap and they said they secured them so I thought they attached them to something. I just checked the stock brake pads an there are 2 sensors attached to them (1 front 1 rear) so maybe they removed them entirely? I dunno how it's exactly set up there. Should these be removed from pads, connected to the socket and then secured? I have red brake check light on and prompt to set up a visit in a nearby service centre each time I start the car + 2 alerts about front/rear brake pads to be changed. |
08-17-2018, 11:03 AM | #32 | |
Rep 3,540
Remove the sensors from the pads (just take a flat head screwdriver and gently pry up). Connect them to the sockets on the car (inside a little terminal box), and then zip tie them out of the way like tux2005 said. |
Benef1cient286.50 |
09-03-2018, 02:23 PM | #33 |
3885
Rep 54,481
Drives: F80 M3
If you are switching between the few Ferodo compounds, you do not need to bed them in again. That is a plus to stay with the same manufacturer and similar compounds.
09-05-2018, 01:54 PM | #34 |
Rep 344
10-10-2018, 09:35 PM | #36 |
Rep 190
Been on the DS2500 for about 1k miles of daily use. Perfectly fine, I do get a small squeal from time to time. Good bite when cold so no need to warm up.
:::: 2017 AW M2 :::: (SOLD)
randyt224.50 papertarget20.50 |
11-02-2018, 02:53 PM | #37 |
3885
Rep 54,481
Drives: F80 M3
03-03-2019, 09:49 PM | #43 | |
3885
Rep 54,481
Drives: F80 M3
The M2 Comp. is different though. |
03-28-2019, 02:39 PM | #44 |
Rep 238
Just to confirm, the correct front part number is then FCP4611 for the "OG" F87 M2?
Instagram - @niru.s1k
24 BRG M3 - Pending Delivery 17 BSM M2 (SOLD) - PureTurbos Stage 2 - BM3 - Tuned by F80Paul @ Paul Johnson Tunes |
