03-29-2017, 03:37 AM | #1 |
Rep 2,560
Drives: Rapidly from A to B
Camber affect on toe in?
Question for anyone who has added camber plates. Does taking the camber more negative increase the toe out or does it increase the toe in?
03-29-2017, 01:23 PM | #2 |
Rep 1,084
tie-rod attach point is slightly higher than the pivot when changing camber with plates, so adding negative camber gives toe-out
03-29-2017, 07:37 PM | #3 |
Rep 2,560
thanks
03-30-2017, 06:14 PM | #5 |
3843
Rep 54,362
Drives: F80 M3
03-31-2017, 09:44 AM | #6 |
Rep 3,714
I saw you have camber plates on your M2. Did you set your street alignment to 0 toe and when you put negative camber in at the track it goes to toe out a bit for better turn in?
Or did you just do something like -2.5 and 0 toe and leave it? |
03-31-2017, 12:56 PM | #7 |
Rep 120
-2.5F camber, 0 toe, and leave it.
CosmosMpower2050.50 |
