M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Bimmercode topics
      03-14-2018, 09:38 AM   #1695
voyagergab
voyagergab's Avatar
634
Drives: G82 M4 6MT, G01/F97 X3M
Yeah I was surprised by the answer.
      03-14-2018, 03:13 PM   #1696
F87_LCI
F87_LCI's Avatar
1789
Drives: 2018 LBB F87
I used vGate WiFi adapter and an "older" iPad (Air Gen 1). I held the iPad down under the steering wheel less than 20 centimeters from the OBDII port. I also went to a parking lot near my office, where the iPad would not "know" any of the open networks, thus would not try to connect to any of them vs. say in my garage where it could try to pick up my home network.
Was fast and I coded something in most modules. I can confirm that FEM definitely took the longest, but it was nowhere near 5 minutes as Neil experienced. Maybe 30-45 seconds to a minute max. Rest of the modules were super quick, I was actually surprised at the speed and wondered if it was actually working.
      03-14-2018, 03:14 PM   #1697
F87_LCI
F87_LCI's Avatar
1789
Originally Posted by chip_dip19 View Post
Don't have this issue but this can be turned on/off within Idrive itself
Did not know that...do you know where specifically? Just saves me hunting for it.
      03-14-2018, 03:50 PM   #1698
evilIu4
Drives: A3
Originally Posted by Nezil View Post
Not sure if it's an option without going into Expert Mode or not, but here is the location of the change:
FEM_Body -> 3020 TcMaster -> TCM_LOGIC_R_OFF_DOOR -> nicht_aktiv (00) [default for US cars] / aktiv (01) [enabled]
Thanks Nezil, I'll take a crack at this and see if this will work.
      03-14-2018, 05:16 PM   #1699
chip_dip19
151
Idrive settings -> displays -> shift indicator.
You can also turn off other items too. I turned off the date, instantaneous fuel mileage, etc so that I don't need to press the button 6 times to change from oil/water temp to speed
      03-14-2018, 07:27 PM   #1700
F87_LCI
F87_LCI's Avatar
1789
      03-14-2018, 07:38 PM   #1701
horsepower_and_hounds
Drives: BMW
I did not even know there was a "Gear Suggestion" anybody have a pic of that it looks like and location? Also where to turn it on tor off...mine might not be turned on
      03-15-2018, 09:04 AM   #1702
chip_dip19
151
It's the little box with the up/down arrows. The location to turn it on/off is in my post above
      03-15-2018, 05:02 PM   #1703
Drives: BMW
Are you manual? It's not a option on mine and am DCT
      03-15-2018, 06:57 PM   #1704
///M²
///M²'s Avatar
283
Drives: 2017 BMW M2 6MT
2017 BMW M2  [0.00]
That's why, manual only...but it's useless.
'17 BMW M2 LBB 6MT MPE
'13 BMW 335i Estoril Blue - sold
      03-15-2018, 06:58 PM   #1705
Drives: BMW
Figured as much....just making sure my coding didn't fuck shit up
      03-18-2018, 12:45 PM   #1706
ric124
ric124's Avatar
Jamaica
453
Drives: F87 M2 BSM MT
2017 BMW M2  [0.00]
Is it possible to code euro MDM with the app?
      03-18-2018, 02:08 PM   #1707
Steveo
Steveo's Avatar
153
Drives: M4
Can this app open the stock exhaust valves?
      03-19-2018, 09:04 PM   #1708
David.m
Drives: M2 LCI 6MT BSM
No, you can use the 'Bimmerlink' app for this, a different app from the same developer.
      03-20-2018, 02:53 PM   #1709
bmxcamel
bmxcamel's Avatar
Drives: F87 LCI, G01 m40i, E90 M3
Does this force the flap open constantly, or do you have to launch the app and open the flap each tome you start the car?
      03-21-2018, 03:48 AM   #1710
Drives: BMW
You can just unplug the flap when the car is cold and it is open, wrap it in electrical tape and stow it away behind the black inner cover it is attached too
      03-21-2018, 06:42 PM   #1711
David.m
The flap stays open (ie it retains the selected setting until you choose to change it), options are OPEN, CLOSE or AUTO.
I also use this app to mute ASD (it's an ON/OFF switch)
      03-21-2018, 06:56 PM   #1712
Nezil
Nezil's Avatar
1404
Drives: LCI '18 6MT M2
Is the ASD setting that you've selected retained as well?
I'd like to have it off most of the time, but on every now and again. Currently I have ti coded off, and it's not that difficult to code on again, but BimmerLink looks like it would be far quicker and easier, particularly since I use E-Sys rather than BimmerCode usually.
2018 ///M2 LCI, LBB, 6MT...
Current Performance Mods:
      03-21-2018, 10:36 PM   #1713
David.m
ASD on/off operates the same, it keeps the selected setting until you choose to change it. I decided to use Bimmerlink for ASD as I thought there would be times I wanted to turn it back on (& the reported issues with coding it back on with Bimmercode). So after 4mths of driving with it off I recently turned it back on for a mate and within 10 minutes of driving in Sport+ I'd had enough & turned it off again, the low freq drone is terrible (I have a Fabspeed sport cat on order which I hope will give me a better sound .
      03-25-2018, 01:20 AM   #1714
Who?
Who?'s Avatar
487
Drives: F87 LCI
Does anyone else have a front/side camera (non existent) error after coding with bimmercode? it goes away straight away, but upon inspection with bimmerlink, the code is stored there so thats gotta be a red flag for the dealer..
So far: 200cell downpipe, custom exhaust, lifhtweight splitter, m4 comp seats
      03-26-2018, 12:17 AM   #1715
F30.M
Yes, I get that error message every time when I code the FEM. Damn, I didn't know it can store error code...
      03-26-2018, 12:53 AM   #1716
Who?
Who?'s Avatar
487
Drives: F87 LCI
yeah its not in the Permanent errors, but I'm not able to clear it either..
I was guessing its due to one of the preselected codes on bimmercode, just not sure which one it is
