10-04-2020, 05:28 PM | #1387 | |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
He just helped me setup full screen CarPlay on my 21' last week
-2021 M2C, HS, 6MT
-AST 5100, AP Racing 9660, BMW-788M, RF-GT4, BW-TA5R, APR GT 250 Wing & Front Splitter -TMS Diffuser, TMS F80 Skid Plate, HEX Armor PPF, CAN-Checked Data Logger, RaceBox -Recaro Pole Position , 2kBody Half Cage, Pinnacle Motorsports Half Cage (On order), CAE Shifter -Remus Race + BR EL Mid |
10-08-2020, 09:32 AM | #1388 |
Rep 23
Another recommendation for Kubax86 - He was fantastic to work with (does he sleep?) and got my fullscreen carplay up and running even though I had weird issues on my end that were absolutely not his problem. C'mon you know you want the fullscreen carplay so just message the guy and get it done - It's a big difference.
10-17-2020, 04:02 PM | #1390 | |
Rep 213
Drives: BMW F87 M2C
He emails across a link for your file, place it in the root folder on usb then plug into the car. Runs through the update process, couple of reboots and you're good to go! |
10-17-2020, 04:15 PM | #1391 |
Rep 1,899
10-23-2020, 11:09 AM | #1392 |
8
Rep 13
fullscreen life
why did I wait 16 months to do this. Big thanks to Kubax86.
Had to find a windows laptop and order an ENET cable from amazon, but worth the hassle for this tweak that took less time, all-in, than boiling an egg. Well worth the tiny amount of money involved. For those of you who are considering - just ping Kubax86 and his response will be immediate, clear, and simple to follow.
2019 M5C
1985 FJ60 |
10-25-2020, 03:50 PM | #1393 |
Remove Before Flight
6945
Rep 1,616
Ok-- Although I'm a Mac guy, I "liberated" an old laptop from my father under the guise of upgrading his OS, cleaning up his HDD, etc.
Which means, I now (temporarily) have a (soon to be) functional Windows machine. Query: What cable to I need for the full-screen CarPlay upgrade? Inexpensive is good, as it's going to be a "Use Once, Throw In Basement" cable. Thanks. R. |
10-25-2020, 05:44 PM | #1394 | |
Rep 8,679
https://www.amazon.com/AuraTech-Inte...665822&sr=8-11 |
flybigjet6944.50 |
11-10-2020, 10:22 AM | #1395 |
Rep 126
Can any of you confirm that you get a sound notification when a message shows up on you carplay screen in you M2?
Mine is not, when a whatsapp or Waze notification pops up i hear nothing. My music plays trough.
@Rub1con76
11-10-2020, 09:35 PM | #1397 |
Rep 425
hi all - I used this site to check if I have a wifi antenna:
https://www.bimmer-tech.net/compatib...ay-activation/ Can anyone confirm if this site and link is accurate in determining whether my car has a wifi antenna? It states for my car "You car is equipped with the original CarPlay hardware from BMW, including a WiFi antenna." Strange thing is when I looked up my vin on mdecoder.com, under the multimedia section I see that I don't have the CarPlay preparation (6CP) option. So from the mdecoder site results, does this mean I don't have a wifi antenna in my car (contrary to what the above bimmer-tech link says)? |
11-11-2020, 02:30 AM | #1398 | |
Rep 126
Its more about the sound notification that comes with it. I miss alot of speed camera's because there is no sound with the warnings
@Rub1con76
11-11-2020, 08:41 AM | #1399 |
6945
Rep 1,616
One data point--
I reached out to Kubax, and he says that the full-screen CarPlay is not exactly compatible w/ BimmerCode. His recommendation is to do all of your BimmerCode modifications first, THEN do the CarPlay upgrade, otherwise there can be problems. R. |
11-11-2020, 09:27 AM | #1400 |
Rep 8,679
In what sense... what carplay mods would one make with bimmercode? Those are different modules as far as I know.
11-11-2020, 09:33 AM | #1401 |
6945
Rep 1,616
11-11-2020, 09:36 AM | #1402 | |
Rep 8,679
Seems seem odd there... |
11-11-2020, 10:09 AM | #1403 | |
6945
Rep 1,616
R. |
ASAP10258.50 |
11-11-2020, 01:38 PM | #1404 | |
Rep 3,070
This is strictly bimmercode fault as you can use E-Sys to code after patch without any issue. Any other coding will work normally using Bimmercode app. To code again headunit, you need to restore to OEM, code headunit, then apply patch again. Thanks |
11-11-2020, 01:54 PM | #1405 | |
Rep 70
kubax861804.00 |
11-11-2020, 02:23 PM | #1406 |
6945
Rep 1,616
Could you explain a bit more? Not sure what you mean by patching the head unit?
In other words, If you do the full-screen CarPlay (and I *just* got the cable to do it in the mail), I'm assuming that you're out of luck on any BimmerCode mods? TIA. |
11-11-2020, 04:38 PM | #1407 |
Rep 8,679
I think that makes sense... some module "headunit" coding is then limited...
That includes Video in motion, rear camera, ringtone changes, disclaimers, chimes and a few others then. |
11-11-2020, 04:39 PM | #1408 |
Rep 8,679
Sounds like some... only the bimmercode modes related to the headunit... mine already done.
Tags |
apple bmw, carplay |
