10-22-2016, 11:22 PM | #1321 | |
Rep 3,091
2004 BMW X3 [8.25] 2018 Porsche 911 GT3 [10.00] 1974 BMW 2002tii [10.00] 2004 BMW M3 [10.00] |
Follow me on IG
10-22-2016, 11:26 PM | #1322 | |
Rep 324
Old school bmw look i like. |
10-23-2016, 01:20 AM | #1323 |
Rep 216
Drives: 2017 BMW M2
25112284545 - Shift knob and boot
34427846805 - Ebrake Boot (you supply your own replacement zip tie)
2016 750i X-drive
2017 GMC Sierra Denali 1997 MB SL500, 19"AMG replicas Past BMWs: E30 323i, E36 325is, E36 M3, E46 M3, E39 M5, E46 325i, E90 335i, F80 M3, F87 M2 |
BAN_M2C4197.00 Swimfanrick51.00 |
10-23-2016, 01:23 AM | #1324 |
Rep 1,681
Current: ///M2C
G01 X3 xDrive30i Past: ///M2 997.1 Turbo ///M3 E92 |
10-23-2016, 07:39 AM | #1328 |
Rep 23
10-23-2016, 07:52 AM | #1329 | |
Rep 347
Height (edge of fender to lower rime edge) Front: 595 mm Rear: 600 mm Settings on front: Rebound: 9 klicks open Bump: 6 klicks open Setting on rear: Rebound: 12 klicks open Bump: 6 klicks open Cheers |
10-23-2016, 07:56 AM | #1330 | |
Rep 347
With standard setting the lowering of the car is approximately: Front: 25 mm Rear: 15 mm On front you can go additional 10 mm lower. In the Mperformance guide the lowering is set to 5-25mm which I see as modest information. Cheers |
10-23-2016, 08:11 AM | #1331 | |
Rep 3,091
15% All Others
Follow me on IG
10-23-2016, 08:17 AM | #1332 | |
Rep 13,167
Will 255/35 front and 275/35 rear fit (not rub) on the stock wheels and/or your BBS CI-R ? As we know, BMW used the M3/M4 437M 19" Black wheels but reduced to 245/35 front and 265/35 rear as the original size was deemed more appropriate for the M2 (well, that was the official explanation).
///M is art ↔ Artemis
10-23-2016, 06:42 PM | #1333 | |
Rep 216
Drives: 2017 BMW M2
2016 750i X-drive
10-24-2016, 10:11 AM | #1335 | |
Rep 2,561
Drives: Rapidly from A to B
10-24-2016, 10:15 AM | #1336 |
Rep 337
Drives: '17 M2 DCT BSM
Connects to OBDII? Should be incompatible with JB4, right?
Check out my M2 YouTube channel: The HyperCar Collective
10-24-2016, 12:26 PM | #1337 |
Rep 3,960
I didn't hook it up since I leave it full bright all the time in my other cars. If want to dim it I just hit a button for a second.
10-24-2016, 12:28 PM | #1338 |
Rep 3,960
If you have the newer style JB4 that uses the OBDII port than no since the gauge uses the that port.
10-24-2016, 12:30 PM | #1339 |
Rep 3,960
Forgot to mention that I have the track pack software that reads AFR and gives you more performance timers.
10-24-2016, 01:38 PM | #1340 |
Rep 2,856
After having it washed and a ODB readout to investigate some limp modes I had with the car, I put it asleep... It will not move much the coming weeks.
MR |
10-24-2016, 02:04 PM | #1341 |
Rep 13,167
Planning to also get the P3 gauge.
Sober, discreet, easy install, only kills half an air vent near the door and features two independent buttons (not using the cruise control switch as the more advanced AWRON gauge does). And - apart from all its features - better readability of the (real) speed than the analog speedometer when poorly backlit in overcast lighting conditions, or the small figures of the OBC digital speedometer showing an adjusted speed. Pictures by forum fellow GetAlife75:
GetAlife75303.00 |
10-24-2016, 03:03 PM | #1342 | |
Rep 2,856
MR |
Artemis30017.00 |
