View Poll Results: Have your M2C rear indicator units failed? | |||
Yes | 137 | 64.02% | |
No | 77 | 35.98% | |
Voters: 214. You may not vote on this poll |
09-02-2020, 05:37 PM | #111 |
Luxury at the redline :)
9108
Rep 7,563
I'm not saying Poochie does either, just that this is hilariously incorrect.[/QUOTE]
I never claimed to be an expert, neither do I play one on TV. I always correct members here when they assume otherwise.. I merely found a viable solution to the subject at hand and shared it with the class, just like the hundreds of other amateur threads here.. I didn't expect it to be an attacked on my intentions or my qualifications. Take or leave it, it's a free suggestion. If you feel it's unsafe, that's your call but It's my way of giving back, in exchange for the all information I've learn here.. Sorry.. 🤷🏻 |
chris7197390.50 |
09-02-2020, 05:40 PM | #112 | |
Rep 7,340
Poochie9107.50 |
09-02-2020, 05:42 PM | #113 | |
Rep 7,340
I'm not saying you're wrong at all, but at the very least Anthony1s doesn't understand how circuits work. I guess it's possible he is right for the wrong reason, but yeah, he clearly doesn't understand what he is talking about. |
Poochie9107.50 |
09-02-2020, 05:53 PM | #114 |
Rep 3,257
My left rear is considering retirement. It seems to work about 90% of the time. I’ve just been too lazy to take it in. Usually it fails in the first 5 mins of a trip then works fine after. No issues with the right.
09-02-2020, 06:06 PM | #115 | |
757
Rep 2,149
09-02-2020, 06:11 PM | #116 | |
Rep 7,340
http://hyperphysics.phy-astr.gsu.edu...ic/ohmlaw.html http://hyperphysics.phy-astr.gsu.edu...ic/elepow.html (W == Watts == Power) != (I == Ampere == Current) |
Poochie9107.50 Threeebowel31.50 |
09-02-2020, 06:12 PM | #117 | ||
9108
Rep 7,563
I kind of understand why he's worried but the way is going about it is misguided and patronizing .. If I thought or if anyone can confirm with certainty that there was ounce of danger by removing the bulb checks, I wouldn't of done it or clearly state a disclaimer, as I'm Mr. Play-it-Safe.. I'm sorry I got dragged down this rabbit hole and word of advice, I suggest you don't get sucked into that dark void either; trust me, it's a dead end.. |
09-02-2020, 06:22 PM | #118 | |
757
Rep 2,149
You do realize the very first sentence of your very first link proves I'm right, right? "For many conductors of electricity, the electric current which will flow through them is directly proportional to the voltage applied to them. " |
09-02-2020, 06:24 PM | #119 | |
Rep 7,340
The only concern I have is that it is not tripped when the car is brand new. That suggests that even if it is improperly coded by BMW, something is changing over time. Once I read through the older threads and TSB I can tell you what my opinion is. Gut feeling is that disabling the check is not any worse than ignoring the fault. Why do I say that? Because the fault condition causes a rapid blinking which still means it's driving the LEDs. It doesn't seem any safer to me if the concern is localized heating of a wire or connector. Is it still safer to head right to the dealership than disable the bulb check? Maybe, but I would guess that the end result is your turn signals stop working completely one day rather than causing a fire. It's just a guess though, if people have pictures or evidence of things like melted wire jackets then I would learn towards not disabling this check. |
09-02-2020, 06:26 PM | #120 | |
Rep 7,340
The bottom line is that you clearly do not understand the relationships here and you should not pretend that you do or that you are qualified to speak on this. I'm not gaslighting, I just want to be sure other people reading this thread know that anything you do propose comes from an incorrect understanding of how electronics work. |
Poochie9107.50 |
09-02-2020, 06:29 PM | #121 | |
757
Rep 2,149
And I have absolutely no incomprehension of how electronics work. You are literally taking an example I made out of context and building an argument that I don't know what I'm talking about out of that. It's honestly pathetic and if you actually had an understanding of electricity, you wouldn't need to make such a sorry argument against me. |
09-02-2020, 06:32 PM | #122 | |
9108
Rep 7,563
[QUOTE=chris719;26640697]
There has yet been a cases where the ground wire is burnt out in any new LED setup, the aforementioned cases are all with incandescent bulb clusters.. Also, on all the new G-Series 330i loaner car(s) and my bother's 2020 M340i, the bulb checks are all disabled for the LED turn signals, I can confirm this.. Had it been that detrimental to safety, why disable it on newer vehicles (rhetorical question). Maybe BMW finally got the memo.. |
09-02-2020, 07:01 PM | #123 | ||
Rep 7,340
Please sir, find me a 1V resistor. Or prove that if you have 12W going into a 1W rated resistor you will have 11W leaving it. I am waiting. MAYBE Poochie isn't right, but your explanations are nonsensical. You should stop attacking him for the very sin you are guilty of. |
Poochie9107.50 |
09-02-2020, 07:12 PM | #124 | |
Rep 7,340
Poochie9107.50 |
09-02-2020, 08:11 PM | #125 | ||
9108
Rep 7,563
DIY: LCI Tailights https://www.2addicts.com/forums/show....php?t=1405431 M2 LCI tail lights retrofitted on pre-LCI M2 https://f87.bimmerpost.com/forums/sh....php?t=1397351 New LED Taillights https://www.2addicts.com/forums/show....php?t=1383466 https://www.1erforum.de/threads/f22-....243355/page-4 I was hoping and praying it would, so I could take the insurance money and buy me a CS but no such luck, just an error-free turn signal, thus far.. Damn, unlucky me, I guess..🤷🏻 Also, IND was selling these lights and included coding to disable the bulb checks for this exact reason.. As I mentioned, it was merely a suggestion; if anyone wants to handle this issue without the bulb checks removed, please do as you like, it's just some friendly advice. https://www.getbmwparts.com/p-f22-23...-pkf22lcitails https://ind-distribution.com/product...tail-light-set |
chris7197390.50 |
09-03-2020, 12:23 PM | #126 | |
757
Rep 2,149
09-03-2020, 12:25 PM | #127 |
757
Rep 2,149
Remember Poochie, he agreed with me that disabling the bulbs checks is not a good idea. You seem to be forgetting that because you wanna focus on what wins your argument.
09-03-2020, 12:35 PM | #128 | |
Rep 7,340
If you had any clue what you were talking about, you would have known that the first post Poochie made was referring to a resistor to ground (SHUNT) to increase the current drawn by the circuit to fool the bulb check. Not a resistance in SERIES. The bottom line is you are aggressive, rude, and absolutely 100% incorrect in your understanding of rudimentary electronics. |
nioh_lbbm21716.50 |
09-03-2020, 12:48 PM | #129 | |
757
Rep 2,149
And you are doubling down on the resistor claim I made, while agreeing with me that a resistor is an incorrect and dangerous solution. Your picking a completely irrelevant part of my position and bring it up over and over again to discredit me. You're appealing to the wrong part of the argument, when the conclusion is agreed upon. You're blatantly nitpicking in an attempt to discredit me. And I'm the aggresor and the rude one here? Go back and your your very first mf sentence you made to me... "you should not post on electronics when you don't even have a high school level understanding of it. I'm not saying Poochie does either, just that this is hilariously incorrect." You are the fucking aggressor and the rude one. Last edited by Anthony1s; 09-03-2020 at 12:57 PM.. |
09-03-2020, 12:58 PM | #130 | |
Rep 7,340
No, I am not the one cursing and spreading misinformation. |
09-03-2020, 01:14 PM | #131 | |
757
Rep 2,149
And I'm allowed to curse when you're literally sitting here gas lighting me and accusing me of shit that never happened and taking literally everything I said out of context to prove a point. It pisses me the fuck off, dude. Be a human, have an actual conversation. Don't resort to childish tactics because you want to win an argument. |
09-03-2020, 01:18 PM | #132 | |||
Rep 7,340
Your analogies are just plain WRONG. Work it out on paper please and post it if you think you are somehow correct. Have a good day, please do not skip your medication in the future. Last edited by chris719; 09-03-2020 at 01:26 PM.. |
nioh_lbbm21716.50 MASHCT698.00 |
