05-16-2021, 09:08 AM | #89 | |
Rep 3,672
Do you think that the VW emissions test mode program was cheating? YES The difference is lack of Intent. A student sneaking answers into a test does so with intent. VW intended to cheat. Red Bull produced a wing that passed the current FIA test. Plus to the naked eye the wing is flexing. There was no intent to deceive in the Red Bulls case thus no cheating occurred. Other teams just weren't smart enough to figure it out. |
M5Rick61842.50 ///M Power-Belgium64713.00 |
05-16-2021, 09:44 AM | #90 | |
2435
Rep 11,669
RB has a history of this. Almost exactly the same circumstance with the front wing a few years ago. The wings passed the static load tests but were later found to flex under racing conditions. Now it's the rear wing... rinse and repeat. Here we go again. The thing that bothers me the most is RB are usually the ones taking issue when others (like Ferrari) are being "creative". But it's OK for them to do it. |
MKSixer34192.50 |
05-16-2021, 11:15 AM | #91 | |
#buildnotbought
11118
Rep 4,930
Neither of these 2 options are very likely. Everything a layman like me sees in a video, the aerodynamicists at Mercedes have seen 10 times over and have measured and calcualted at that phenomenon. If those vibrations and flexing should impede performance.... I'm pretty sure they would have fixed it. Nothing we could ever ever see in these videos are things the engineers at mercedes would have missed. Everything we see is a result of what they engineer very very carefully. When you see something flapping around in the breeze on an F1 car.......it's ment to do that. Trust me, they are very much ahead of us My only point was regarding the statement of 'rigid'. If that RB spoiler isnt rigid, that merc finn also isnt 'rigid' And imho none of those issues are 'coincidental'. Those engineers are way too smart for that.
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
4
05-16-2021, 11:33 AM | #92 | |
34193
Rep 11,637
Drives: 2015 BMW i8, E63 M6, 328d
Article 3.8 of the F1 technical regulations states that bodywork must be "rigidly secured to the entirely sprung part of the car" and "remain immobile in relation to the sprung part of the car" Passing a test doesn't make one a master of any subject matter in college or in any school. Red Bull Racing, as has been done historically in that shop, have created a wing that passes the test, which has know levels of pressure in a static application, but successfully deforms under full load at a certain dynamic aero pressure level. Passing the test designed by the FIA doesn't mean they are complying with Article 3.8. Article 3.8 doesn't read, "rigidly secured to the entirely sprung part of the car and pass the static deformation test performed by the FIA." Now as to intent: The way you design a CF part to do this is to alter the density of the matrix solution and alter the number of carbon strands and their diameter in that area relative to the number in the remaining portion of the cf material. To design in this way is the very definition of intent to circumvent the rules. And for context, I worked on CF as a young engineering student in 1983 when I ran the materials lab in college. We ran fracture, bulk modulus, elasticity, and dozens of other test on CF back then when it was still relatively new and exotic...especially in the states. If memory serves correctly, McLaren was the first to build a fully CF monocoque under John Bernard. Edit: Smart isn't the right word to define what RBR did with the wing. Clever is probably closer to accurate with duplicitous being most accurate. Duplicitous: n. Deliberate deceptiveness in behavior or speech. n. An instance of deliberate deceptiveness; double-dealing.
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion. |
SenorFunkyPants2511.50 |
05-16-2021, 11:39 AM | #93 |
34193
Rep 11,637
It's still cheating.
05-16-2021, 11:47 AM | #94 | |
Rep 3,223
adjective not moving; motionless. By that definition, every single car on the grid should be DQ'd. The FIA defined 'immobile' with their set of static tests. RB passed the FIA's tests. I still think this has more to do with the fact that it's Red Bull doing it and not a universally liked team i.e. Williams, etc. If the latter were the case, I don't think we wouldn't be talking about this. |
05-16-2021, 12:51 PM | #95 | |
34193
Rep 11,637
And to be clear...I LOVE INNOVATION IN F1!! The Brawn Double Diffuser and the even more radical one on the never-raced Toyota TF-109 were things of beauty. DAS was brilliant. The McLaren F-Duct...brilliant. The Renault Mass Damper...brilliant. These exploited loopholes in the rules which were closed. The Flexible Wing is DESIGNED and MANUFACTURED to get around the rule and the testing for the rule. It is like the Ferrari Fuel Flow shenanigans. It was a cheat designed specifically to circumvent the letter and spirit of the rules. It's straight-up cheating.
05-16-2021, 01:06 PM | #96 | |
General
64713
Rep 24,949
Remember the Mercedes DAS , already used in "2018 by HAM while it wasn't FIA approved . You guys said : DAS isn't cheating , It's a Mercedes "Invention" and Red Bull should work harder to catch up... Well probably Red Bull found an so called Invention as well , and you guys start to cry like a little baby girl . Mercedes can better look what's under HAM's PU cover , regarding the Warp-Speed Mode ... Otherwise Red Bull will do it before this season is over...#FIA !
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
M5Rick61842.50 Killed by Death13209.00 |
05-16-2021, 01:22 PM | #97 | |
34193
Rep 11,637
05-16-2021, 01:29 PM | #98 |
General
61843
Rep 19,971
///M Power-Belgium64713.00 Killed by Death13209.00 |
05-16-2021, 01:30 PM | #99 |
34193
Rep 11,637
Read my post 95 and look up the last time RBR did this. Learn from the result of that.
05-16-2021, 01:43 PM | #100 | |
General
61843
Rep 19,971
A statical test can be made on a car (with this test) after a race to test the rigidity with little or no change. There must be ''some''give with every structure my friend or the damn thing would break. |
05-16-2021, 02:20 PM | #101 | |
General
64713
Rep 24,949
Marko said yesterday , Red Bull isn't the only team who is targeted by the FIA ... And we can help the FIA , just like Mercedes did ! HAM and Toto know that MAX is really fast (too fast) in this season , so they started their psychological BS games . As I said : "WAR"
Killed by Death13209.00 M5Rick61842.50 |
05-16-2021, 02:41 PM | #102 | |
Rep 4,381
"Formula 1 Cars must comply with these regulations in their entirety at all times during a Competition. Should a Competitor introduce a new design or system or feel that any aspect of these regulations is unclear, clarification may be sought from the FIA Formula One Technical Department. If clarification relates to any new design or system, correspondence must include: a. A full description of the design or system. b. Drawings or schematics where appropriate. c. The Competitor's opinion concerning the immediate implications on other parts of the car of any proposed new design. d. The Competitor's opinion concerning any possible long term consequences or new developments which may come from using any such new designs or systems. e. The precise way or ways in which the Competitor feels the new design or system will enhance the performance of the car" Red Bull clearly did not comply with the above WRT their moveable rear wing assembly. Whereas Mercedes did communicate their DAS design as above which was later prohibited under the following regulation: "New systems or technologies Any new system, procedure or technology not specifically covered by these regulations, but which is deemed permissible by the FIA Formula One Technical Department, will only be admitted until the end of the Championship during which it is introduced. Following this the Formula One Commission will be asked to review the technology concerned and, if they feel it adds no value to Formula One in general, it may be specifically prohibited by the FIA." And therein lies the difference...Mercedes played by the rules with DAS while Red Bull (and likely others) sought to cheat the rules. [text in italics is quoted from the 2021 F1 technical regulations] |
05-16-2021, 03:03 PM | #103 | |
34193
Rep 11,637
RBR...The NASA of Cheating https://jalopnik.com/red-bull-racing...ing-1663441969
05-16-2021, 03:12 PM | #104 | |
i'm just saying
5767
Rep 2,634
Merc's fin vibrates, Red Bull's rear wing bends.. lets separate them first.. and even if we assume your conspiracy is right.. bending rear wing gives a vast amount of advantage.. you dont need to be an aerodynamicist to know this.. yes i agree with one part that, they re ahead of time..
"Race car driving is like sex. All guys think they're good at it." Jay Leno
MKSixer34192.50 |
05-16-2021, 03:27 PM | #105 | |
i'm just saying
5767
Rep 2,634
05-16-2021, 04:03 PM | #106 | |
General
64713
Rep 24,949
As like : "It ISN'T the car " It's the driver ! That's why HAM is the 7 X World Champ .. Actually crazy BS !!! So ...Honestly ! I don't see the correlation between a stupid wing and MAX's drivers performance ! • MAX is a little too fast for Mercedes mate ! It's just there where the knot is tied ! It already stinks 7 seasons like 5H1T on the Mercedes side , and under the W12 PU cover even more ... It's useless to talk about the Mercedes cheating inventions like the Party-Mode , Magic-Mode , Tire cooling in wheels , DAS , ect... All the rest is just BS !!!
M5Rick61842.50 |
05-16-2021, 04:45 PM | #107 | |
i'm just saying
5767
Rep 2,634
MKSixer34192.50 |
05-16-2021, 05:11 PM | #108 |
Rep 3,672
Ok, dumb question, DAS moves the tires and surely affects aerodynamics of the car. Why is the effect of this system not ruled as creating a moveable aerodynamic device?
Best uneducated guess, because the wheels and tires are unsprung weight Cue the smart person, GO First to answer gets a prize. |
///M Power-Belgium64713.00 M5Rick61842.50 |
05-16-2021, 05:21 PM | #109 |
General
64713
Rep 24,949
I "never said HAM can't drive his Merc !
Honestly mate , listen : Don't you think HAM got more advantage from exceeding 29 times the track limits than MAX with the stupid RB wing ? Or pushed a stupid wing HAM to his 7 x Championships ? I don't think so...
M5Rick61842.50 |
05-16-2021, 05:48 PM | #110 | |
34193
Rep 11,637
