08-28-2017, 03:29 PM | #89 |
Rep 574
Should've uploaded this here.
The car has: Steinbauer tuning box (claimed 430bhp) Forge intercooler (new) ITG panel filter Fabspeed 200cell DP M-performancs Exhaust Here is the graph. 5th gear pull. 2 runs, one with tune box on one with it off. Intercooler on first run was steady 40deg C second run was also same until the last 1000rpm and temp went to 60deg c, timing pulled about 8 deg and a drop in power. So, across the range the power was about 35-40 engine hp and torque was massive. On the road I think it would be different at the top end, probably gaining 15hp. Anyways I'm happy with stock and tune. Not sure why it died on the last 800rpm but it is what it is. |
08-31-2017, 02:04 PM | #90 | |
IG @bmwF9xG80
3817
Rep 7,595
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
08-31-2017, 02:33 PM | #91 | ||
Rep 198
And yes, i can flash to stock, but with a catless dp, they are not truly stock baseline, they would be baseline to the tune only
*1996 S54 E36 M3* •2017 F87 M2•
Sold: 07' e90 335i, 08' e92 M3 |
08-31-2017, 06:26 PM | #92 | |
IG @bmwF9xG80
3817
Rep 7,595
Yes STD reads higher not denying that, but also has less correction and more of a happy number. With SAE (American Muscle) mostly used, barely by BMW.
60-130 6.5s X4M
09-01-2017, 11:37 AM | #93 | ||
Rep 198
386whp 413wtq
FSociety3816.50 |
09-01-2017, 11:56 AM | #94 |
Rep 5,392
SAE is the industry standard. BMW's quoted numbers for it's US cars are in SAE. Correcting Dynojet numbers to STD will elevate the numbers about 4% above SAE. If you dyno, you should correct to SAE. When one reads a dyno plot, they should definitely factor in how the numbers are corrected. Plot smoothing also comes into play as well.
FSociety3816.50 |
09-01-2017, 12:54 PM | #95 | ||
IG @bmwF9xG80
3817
Rep 7,595
At the end of the day Baseline + Tune in SAE is the same Delta as in STD with maybe 1whp 1wtq difference at least in my case.
60-130 6.5s X4M
09-02-2017, 06:28 PM | #96 |
Rep 2,829
I'm surprised with all those goodies you didn't hit 400+ damn shity 91oct...
BMW I12 i8 Frozen Yellow- H&R springs, 22" Radenergie F10 Monoblock Forged /// F87 M2 Aw -Vorsteiner Aero Kit, VFF-107,Macht Schnell-Springs,VF-Engineering/Hex tuning Stage Two,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe/// Wish list :Mexico delivery 2024 BMW M2 (G87) |
09-03-2017, 05:15 PM | #97 |
Rep 574
09-09-2017, 04:33 PM | #98 |
Rep 240
Bone Stock M2 Dyno - 94 Octane (Husky)
Instagram - @niru.s1k
24 BRG M3 - Pending Delivery 17 BSM M2 (SOLD) - PureTurbos Stage 2 - BM3 - Tuned by F80Paul @ Paul Johnson Tunes |
FSociety3816.50 |
09-10-2017, 11:25 AM | #99 |
Rep 5,392
09-14-2017, 01:33 AM | #101 |
Rep 752
I've got a FBO M2 6MT (w/ california jet fuel 91 octane) with the following mods, will dyno once I custom tune it, currently running the bootmod3 stage 2 91 octane OTS map:
-PURE Hi Flow Turbo Inlet -ER Catless Downpipe -FTP Charge pipes (both hot and cold side) -Wagner EVO II Performance Intercooler -Stock airbox w/ BMC drop in filter and eventuri air scoop -Akrapovic evolution exhaust -bootmod3 tune -NGK 1 step colder spark plugs (PTF recommended) Again, California 91 octane...excited to see how much she puts down! |
09-20-2017, 05:32 PM | #102 |
Rep 195
Excellent thread. Looks like with only bolt-ons, there is still a good amount of power that be be extracted out of the "maxed out" N55 that some initially called it.
09-20-2017, 05:40 PM | #103 |
enthusiasm > practicality
4027
Rep 2,247
Drives: 987 CS | G35x
The stock turbo is essentially maxed out, not the engine itself.
09-20-2017, 05:41 PM | #104 | |
IG @bmwF9xG80
3817
Rep 7,595
60-130 6.5s X4M
09-20-2017, 05:45 PM | #105 |
Rep 195
Yeah I hear you. But it's nice to see guys are getting around 40hp increase and tons of torque from bolt ons. Being a car of balance, I don't think the M2 needs much more than that. Of course, many would beg to differ.
No Boost4027.00 |
09-20-2017, 06:56 PM | #106 |
Rep 166
So I have a thread going thought I would post in here to.
Stock dyno 354 whp and 388 ft lbs I have another session coming up soon with my mods Vrsf dp, vrsf street intercooler, fabspeed muffler bypass, BMS intake, and jb4.. so it should be interesting. I'm going to do a couple pulls on map 0.. with jb4 turned off. And than a couple pulls on map 2 in jb4 To see the difference with and without jb4 |
09-20-2017, 07:32 PM | #107 | |
Rep 2,577
Lemania 2320
09-20-2017, 07:44 PM | #108 | |
Rep 195
What octane did you use for the stock dyno run? |
09-20-2017, 07:53 PM | #109 | ||
Rep 166
09-20-2017, 07:54 PM | #110 | ||
Rep 166
