07-22-2022, 07:39 PM | #68 |
Rep 44
I have esys running and connected to the car. I've gone through all the guides but I'm unable to figure out how to actually find the option "C_Ffunktion_Bremsbereitschaft_aktiv_I" in esys.
I'm also looking for any other settings that affect the braking system. I'd like to tweak things on my own while I'm at the track so I can test out each setting individually instead of relying on someone coding 1 specific setup on my car and then i'm stuck with it until they code it again. |
07-22-2022, 07:59 PM | #69 | |
Rep 3,549
07-22-2022, 08:02 PM | #70 | |
Rep 44
Thank you for your response! |
07-22-2022, 08:09 PM | #71 |
Rep 44
When I try to change a simple setting. IE.
ACSM: Disable Welcome 3 Gongs: 3000 Initialwarnung_GWF_IW set to: nicht_akti I go to read the code, edit the ncd, but then all I see is: View post on imgur.com |
07-28-2022, 10:40 PM | #73 | |
Rep 3,549
08-02-2022, 07:23 PM | #74 |
Rep 44
Thanks! That's pointed me in the right direction. I'm now stuck at the Launcher not being able to start esys. "can't create java virtual machine" even though I have java installed.
08-02-2022, 07:43 PM | #75 |
Rep 44
from the instructions it seems like I'm stuck at step 9.
9. Click on FDL Codes to get activation request I only see a "FDL Cheat Codes" button in the launcher, and when I click it, it don't receive an "activation request" just a list of the xml files in from the "FLD Codes" folder. when I click update, it just errors out on all of them, and then i click ok. I'll see if there's anything over at bimmerscene about this and report back, might help someone else out. |
08-07-2022, 10:03 AM | #76 |
Rep 70
Scammers BE AWARE
Recently my inbox was getting full of messages from people asking me to share the exact coding parameters from my development, I politely reply to all of them, telling that the coding parameters reamain confidential and that I wont reveal them even for a payment, sadly they started to reply a lot of bad things and now I need to clear my inbox daily. Lately I found out that some coding companies now offer my development, Please be aware, the coding parameters of my development still remain confidential and unfortunately people is starting to reach out to me telling that they coded their brakes with some ig guy and don´t feel any improvement at all. When I remote and check everything I found out that they are turning off brake standby and offer that as complete abs remap or even tell that I´m working with them, also they tried to contact some previous customers and offer money to let them connect and check what parameters I have code on their cars.
Hope no more people gets scammed. Last edited by daap1193; 08-08-2022 at 11:47 AM.. |
kthor70348.00 |
08-07-2022, 01:11 PM | #78 | |
Rep 2
07-01-2023, 10:43 AM | #79 |
Rep 2
Hi Daap1193
i'm after your brake coding if still possible on my M2C, can you DM me? I'm in the UK Thanks Aaron Last edited by AaronMn; 07-01-2023 at 11:11 AM.. |
01-21-2024, 11:45 AM | #80 | |
Rep 3
05-11-2024, 04:53 PM | #82 |
Rep 9
I have always found the brakes to be great but a bit weird in their consistency so I dove into the forums for a look at the issue and Found this thread. I made the changes to "C_Ffunktion_Bremsbereitschaft_aktiv_I" the pre-tension braking. Basically it’s when you snap off the throttle and hit the brakes the pedal is rock hard with high initial clamping pressure. Took it for a run in the hills yesterday and have to say it was noticeably easier to modulate, should be more so at a track shakedown next week.
