04-19-2020, 08:20 AM | #67 |
6643
Rep 4,145
Drives: '18 M2 6MT
04-19-2020, 05:55 PM | #68 |
Rep 85
No I mean anti roll bars or sway bars as you call them, forgive me if im wrong but I always thought the M2C had thicker ones over the normal M2,I'm sure read it somewhere ages ago.
04-20-2020, 01:34 AM | #69 |
Rep 4,529
Kev - sways/ARB's are identical between OGM2 and M2Comp - probably an urban myth like the rose jointed suspension.... BP
Current '22 X3M LCI.. |
04-25-2020, 06:20 PM | #70 |
Rep 394
infinitekidM2C4229.50 |
04-25-2020, 06:54 PM | #71 |
6643
Rep 4,145
Drives: '18 M2 6MT
05-03-2020, 11:29 PM | #73 |
Rep 8,679
I did some real hard driving today on some backwoods roads in the middle of nowhere and I have to say it is scary how bouncy this car is. I think if you are on some perfect roads (which never exist) then maybe it's fine but every time I came across a bump the car felt so uneasy and felt like it wanted to almost take off. I don't know if the rebound dampening was tuned by Boeing to help the car take off but I am blown away by the fact the engine, tranny and cooling are absolutely stellar, it is the suspension where the M car truly takes a shit. I know what mod is up for me next... it will be the best corner balanced coil over kit i can find.
05-03-2020, 11:33 PM | #74 | |
Rep 1,466
I’m still running stock suspension but with the retrofit and though I still want coil overs at some point, it’s no longer a necessity. As has been said many times... it’s the strut brace that makes the M2C so much better than the OG from a comfort and handling perspective. |
05-03-2020, 11:37 PM | #75 | ||
Rep 8,679
I think this car left the factory with a subpar suspension setup.. i can only think it was done for comfort reasons but it makes the car very very hard to drive confidently on less than ideal surfaces (which like i said dont exist).
05-04-2020, 01:46 AM | #76 |
847
Rep 1,962
Comfort would not have been my first thought as to why it rides the way it does...
05-04-2020, 02:45 AM | #77 | |
Rep 4,529
05-05-2020, 11:01 PM | #78 |
Rep 108
is there any proven hardware differences in the 2 suspensions between OG and M2C?
IG: Stacked911
604 M2C/M2/E46M3 Exhaust Videos: https://www.youtube.com/channel/UC0o...R6EYk-oIdduslA 04 330CI / 18 440I MPE / 18 M2 N55 / 02 M3 / 20 M2C |
05-06-2020, 12:32 AM | #79 | |
Rep 128
Current: M Roadster Silver/Black (Fun car), BMW 330ti Compact (Trackday), Mercedes C220d AMG Estate (Everyday)
Previous: BMW M2 DCT M Performance Suspension/Stage2, Porsche 993 Carrera 2S, Porsche 993 Carrera 2, Porsche 964 Carrera 2 Cab,Mazda RX8, Porsche 930 Turbo, BMW M3 E36, BMW M3 E30, BMW M5 E34, BMW 325iM Coupe |
05-06-2020, 12:55 AM | #80 |
Rep 1,466
I can only guess that it does so because the strut brace prevents the body shell from acting as an un-damped spring in the system.
My feeling is that the suspension setup in the OG M2 is stiff enough that it causes more of the shocks to be transmitted through to the body shell. A standard 2er might not require the strut brace, but the M2 does benefit from it, and hence why the M2C has it stock. I think I remember hearing that the OG M2 was seen with a strut brace whilst in development that never made it to launch, but I might be wrong about that. One thing that is interesting is that the strut brace fits all around the packaging of the N55, even though it's quite different to the S55.... I suspect this isn't a coincidence.
2018 ///M2 LCI, LBB, 6MT...
PLF693771.50 |
05-06-2020, 12:56 AM | #81 |
Rep 1,466
Sorry, missed that... you'd be even more unhappy with an OG M2 then!
05-06-2020, 03:22 AM | #82 | |
Rep 4,529
As an aside, compared to F2x/3x/8x, new G2x cars have more localised re-inforcement built in around the strut top hole - see about 1min into YT clip below Am glad I fitted add-on strut top reinforcement rings during alloy CFRP retrofit onto my OG M2...
Current '22 X3M LCI.. Last edited by Bee Pee; 05-06-2020 at 03:32 AM.. |
05-06-2020, 05:12 PM | #83 |
Rep 1,389
Yes to the comments of the car acting like a spring without the brace. You just won't believe it unless you do retrofit.
Like I've said before I noticed this way before steering . You feel the whole car is keyed in and the front springs and shocks are doing so much more for you. Before they were uncoordinated or sleeping a bit, best way I can describe the feedback. |
05-07-2020, 10:36 AM | #84 |
Rep 2,700
Need opinions.
In combination with the OEM aluminium brace wich of these 2 parts do you think will provide the most stiffening ? 1- OEM Carbon part - Plastic attach points glued to carbon part - Some say it provides up to 30% of the stiffening in the complete oem system 2- Aftermarket solid stainless strut tower brace - Direct link between strut towers but no link to front - I figure much stiffer when tied down than oem carbon part.. Also keep in mind the OG M2 has these corner brace (from convertible 2 series) wich can be replaced by beefier aftermarket ones or even carbon ones.
05-07-2020, 12:30 PM | #85 | |
Rep 1,466
I also removed the small bracket glued to the underside of the brace that has no use with an N55 engine and this took forever! I tried using dental floss and fishing line to saw through the glue and that didn't work at all. In the end I carefully used a scalpel to cut it, but it doesn't flex at all even when you're half way through the cut. My point is that the glue and aluminium parts of the brace are strong, and shouldn't be considered a weakness in design. 30% seems reasonable based on driving feel. Subjectively there is an improvement after fitting the CFRP section, but it's a little less than half of the improvement from the aluminium section alone. If you really take a look at the stock OG M2 front stiffening plates and where they bolt to, you'll see that they really can't provide anything like the stiffening that the CFRP brace does, simply because of where they bolt to. They each have 4 bolts and they attach in front of the strut to the front panel. The CFRP brace attaches to the aluminium section which in turn is bolted to the bulkhead and strut towers; quite different locations. The Aluminium strut brace is so thick that I think it serves the same purpose as the typical strut tower brace, but a strut tower brace could potentially provide better bracing directly between the strut towers. The CFRP brace is a U shape and is actually slightly springy in the direction that a traditional strut brace would be super stiff, so the CFRP brace cannot be compared in any way to a traditional strut brace. Overall, I'd say that the CFRP brace is the best choice, and if you have the mounting holes for the stock OG M2 front brackets you can flatten the front sections on those and fit them as well if you want (I'm planning to do this but haven't yet). After that, you could consider a traditional strut brace but by that point I'd be surprised if it made much of a difference... but they again I was surprised that the M2C / M3 / M4 retrofit made the difference it did, so it might be great!
05-07-2020, 12:35 PM | #86 |
Rep 2,700
I don't think there is space for OEM carbon brace + aftermarket traditional strut brace ?
05-07-2020, 12:58 PM | #87 | |
Rep 4,529
Having retrofitted oem F8x alloy brace initially (then CFRP U brace much later) I did consider putting aftermarket strut brace across the engine bay. The way the alloy brace is configured it doesn't look compatible with a strut brace between the strut towers. I agree with what's been written just above that the oem alloy brace offers a noticeable improvement and then CFRP slightly more in addition to alloy only.
05-07-2020, 01:22 PM | #88 |
Rep 2,700
I already bought the aluminum alloy brace, it's in shipping right now. Looks like I'll be on the hunt for the Carbon one.
I am really not blingy with my cars I must admit all fitted + the Turner Motorsports Carbon corner braces it would look awesome !
