11-28-2022, 12:56 PM | #68 |
Rep 227
12-04-2022, 11:00 PM | #69 |
Rep 198
Is there any special process or recommendations swapping from your track day brakes to OEM? I put my OEMs back on and they sound like the squeal much much more now than before....
12-05-2022, 07:20 AM | #70 | |
Rep 1,645
Same with prior to an event. I'll swap the track pads in a few days before and allow them to remove the oem deposits. You can't really bed in track pads without doing 100+ mph stopping to get them into heat range, so I'll be a little cautious during the first track run of the event while they do bed in. |
kthor70348.00 |
12-06-2022, 01:56 PM | #71 |
Rep 126
Drives: 2020 M2C HS
This may be a stupid question but - do you guys usually use track pads front and rear, or just front?
12-12-2022, 12:50 PM | #72 |
Rep 647
bogdiniciu135.00 |
12-12-2022, 03:53 PM | #73 |
Rep 126
Drives: 2020 M2C HS
12-12-2022, 06:04 PM | #74 |
Rep 446
Not that anyone would, but it would make more sense to have track pads in the back and stock front. If you mix you normally want the more aggressive pad rear. I tried pfc11 front and pfc08 rear and it was awful lol
Current: 2018 M2 DCT
Previous: 2011 E92 M3, 2007 E92 328xi Insta: @kmannc |
12-12-2022, 06:38 PM | #75 | |
Rep 126
Drives: 2020 M2C HS
12-12-2022, 06:41 PM | #76 |
Rep 446
It does but a track pad only front or more aggressive compound in front throws off the bias pretty bad and creates a lot of unintentional oversteer into corners
12-14-2022, 10:42 PM | #77 | |
Rep 317
National PCA instructor and 15 year advanced solo HPDE and Club Racer here.
Toys- ‘21 M2C, '20 718 GT4 (going), '14 981 CS (going), '09 C4S (gone)
-Inbound- '23 GT4 RS, 22 718 GTS 4.0 |
12-15-2022, 09:26 AM | #78 | |
Rep 446
And while more aggressive front is safest bet, I wouldn’t take it as gospel, I think it starts getting a little deep into the bite/modulation/release characteristics of the pad. 11 F and 08 R created severe unsettling of the rear into corners. Flipping provided a much smoother corner entry.
12-15-2022, 09:34 AM | #79 |
Rep 1,614
Everyone talks about Ferrodo, ect but not many talk about endless so what about endless? Seems well loved at the nurburgring but feel like few talk about them in the forum.
01-03-2023, 01:25 PM | #80 |
Rep 155
Anyone use ds1.11 rear with ds3.12 fronts?
I have ds3.12 all around and need new rears after a few front swaps. Wonder if ds1.11 at the back works better with ds3.12s front? |
01-18-2023, 10:11 AM | #81 |
1029
Rep 842
We suggest running the same pad compound front and rear on these cars. If you run the DS3.12 on the front with the DS1.11 in the rear, you're shifting more work to the front because the DS3.12 has a higher coefficient of friction (mu) than the DS1.11. Effectively, you're overworking the fronts vs. the rears in that scenario. Again, same compound front and rear is the superior choice on an M2.
blitzyo53.00 |
01-18-2023, 10:17 AM | #82 |
1029
Rep 842
Gents,
Below are some tech articles and videos from the Essex Parts Blog that you may find useful. Which Ferodo Racing Pad Compound is Right for Me? Looks at the three primary Ferodo pad compounds and discusses which one may be the best fit for you based on how you're using your car. Essex Track and Racing Pad Owner's Guide Talks about how to get more life out of your pads, and common issues like cracking, chunking, and taper. How to Bed-in pads and discs How to swap between street and track pads |
01-30-2023, 06:49 PM | #83 | |
Rep 1,823
P.S. I have now gone through my first set of Hawk DTC-60 pads. Very impressed with them. They lasted me 8 days total, and I just left them in all season long. So 8 track days and about 8000 street miles. They are quiet enough in the Camaro to leave for street use, and they never once faded. I push DEEP into brake zones, and try not to brake till I see GOD. 90% of the time they are very confidence inspiring. 10% of the time I wished for more grip. Will be getting another set. Bang for the buck is fantastic, and the fact I don't have to continue swapping pads is a huge plus. Highly recommend.
2017 BMW M2 German Spec
02-01-2023, 03:26 PM | #84 |
Rep 446
I was curious about this myself. They appear to make incredibly nice pad options but they're VERY expensive compared to PFC, pagid, and ferodo. They're also not the easiest to get stateside, I think only a couple people stock them and the lead times are pretty long. Better off with PFC 08 or 11 and call it a day
02-01-2023, 03:39 PM | #85 | |
Rep 1,614
02-01-2023, 03:48 PM | #86 |
Rep 446
Ah I was looking at blue brakes. What compound are you looking at? Looks like me20 or 22 is used or the expensive ma45b. Endless says ME are for lightweight cars so not sure their life span. I will say I loved how well pfc’s played with OEM pads. I’ve used both 08 and 11, and unless I go slicks I don’t see a need for anything else
02-01-2023, 05:02 PM | #87 | |
Rep 1,614
02-01-2023, 11:30 PM | #88 | |||
Rep 351
A staggered ME20/22 setup was floated as an option but after doing some reading, I felt they may compare more to the Pagid RSL29 than the Ferodo DS3.12 so I asked about getting more initial bite which led to the MS35 compound. I may be a little off on this so I wouldn't point anyone away from the ME20 since the MS35 is difficult to get. The Ferodo DS3.12 had previously been my favorite pad and I chose the Endless pass in hopes of finding a comparable pad that would cost less and potentially have a better wear rate. So far I would say they achieve both of those goals but are not quite the same the DS3.12 in terms of experience. The biggest difference I find between these two is the Endless feels like it is a bit more responsive and requires more finesse on initial application and release. Both provide excellent feel and modulation, and stopping power. Both are also surprisingly quiet when cold and easy to live with on the street. Maybe in the future I'll try Cobalt or Hawk to see how they compare (and see if I can save more money), but even more so than tires, I'm less likely to throw out what I know for something I don't. Last edited by M1500Z; 02-02-2023 at 02:43 PM.. |
jritt@essex1029.00 |
