08-10-2021, 10:27 AM | #67 | |
Rep 221
08-16-2021, 03:45 PM | #68 | |
Rep 95
Be sure you have the proper bushings on the strut shaft and that you've tightened the strut nut(s) to spec. Also check all of the other bolts on the plate. Mine were competition model so they had the strut brace plate on top. All the bolts were loose (and some fell out actually) JJ
Current: 2020 X3M, 2022 911 GT3
Past: 2020 M2 Competition,2018 X3 M40i,2017 X3,2016 VW ,Golf R,2015 BMW M3,2010 VW GTI,2008 911 GT3,2005 VW GTI,2002 VW GTI 337 |
08-16-2021, 08:12 PM | #69 | ||
Rep 148
GC Conttol Plates
have a pic for what they should look like? |
08-19-2021, 11:47 AM | #70 | |
Rep 95
I'll try to find a pic. JJ
08-20-2021, 09:51 PM | #71 | ||
Rep 148
Bushings
08-28-2021, 02:14 AM | #72 |
Rep 303
Well finally fitted the negative camber hubs and took off the Millway camber plates. Not seen the camber settings but looks similar to Millway just a fraction less so guessing 2.25 degrees
Interesting I think the ride height dropped a few mm with the Millway and is now bang on the previous ride heights Only done a few miles but nvh nicely back to the car I remember steering and grip feels similar, perhaps marginally blunter and less precise moderating steering mid corner. The front and rear seem more connected more together with damping as well. I’ll be selling the Millway Camber plates after about 500 miles and a lot of labour fitment costs In my view tick for a track Day focused car and cross for a road car I’ll write a longer write up after a week or so |
CSBM52756.00 |
09-24-2021, 09:43 PM | #74 | |||
Rep 87
thanks ! |
09-25-2021, 01:50 AM | #75 | |
Rep 1,337
09-27-2021, 07:59 PM | #76 | |
Rep 557
I have Millway street plates with Ohlins R&T, go between -3.0 for track & -2.0 for street without any issues, have done 20K km since installing the Millway's. |
10-02-2021, 08:19 PM | #77 | |
Rep 87
my home track in qc is very harsh haha |
10-10-2021, 04:27 PM | #78 |
Rep 31
02-20-2022, 11:12 AM | #79 |
Rep 159
So mid to late last year, I heard mention that Vorschlag and Millway (?) were making updates to their kits. Do we know if this happened already for each company?
Also, I saw mention of slider access concerns with Milway. Is this only with the street and OG M2s? Looking to get ~3 deg at the front of a 2021 M2C and wondering the best option between Vorschlag and Millway. Could entertain the street option on the Millway plates. Thanks in advance. |
02-20-2022, 03:12 PM | #80 | |
Rep 160
Drives: 17 M2, 23 Ford F150 Raptor
FaRKle! made a video on the updated design.
Current: 2017 Alpine White M2 DCT, 2023 Ford F-150 Raptor
Past: 2015 Lexus IS 250, 2014 Volkswagen CC R-Line |
kthor70348.00 |
02-26-2022, 07:49 PM | #81 |
Rep 159
I got in touch with Millway via their email contact form. Turns out there is a new version for 2022, with a larger bearing. The website isn't fully updated yet, but the OG M2 part on their site indicates a "2022" version.
superuser53.50 |
02-27-2022, 12:00 AM | #82 | |
Rep 3,548
See, when we highlight deficiencies in products, it motivates manufacturers to give us better ones!
03-04-2022, 11:33 PM | #83 |
3890
Rep 54,576
Drives: F80 M3
PM us with any questions you may have regarding Vorshlag camber plates. We are a stocking dealer and often keep Ohlins and MCS plates on hand.
10-19-2022, 05:01 PM | #84 |
Rep 226
I wouldn't recommend Vorshlag
After doing my research and watching farkle's video, it seemed like Vorshlag was definitely the way to go for camber plates. They seem like a great small business with robust parts design. My race shop recommended Ground Control, but I was adamant that I wanted Vorshlag. Now I'm regretting that decision.
First Straw I had to wait a month after purchase to receive my camber plates. This resulted in me running 2 more track days with stock alignment settings and prematurely killing a set of front tires. Second Straw The Vorshlag plates require a sketchy/unusual install method of using an impact wrench on the top nut, which is generally frowned upon due to the (apparently slight) risk of damaging the strut. I spent way too much time digging in to this process to understand it so I could explain exactly what I wanted to my shop. Third Straw A friend with fairly new Vorshlag camber plates on his 335i had ball joint failure even though the installer swears they used the impact wrench install method described above. Now I'm nervous about the lifespan of my plates. Rebuilds are cheap, but who wants to pay for the labor to uninstall/re-install? The Last Straw Vorshlag sent the wrong top nut for the kit that I ordered, but this wasn't apparent until my shop had my front strut disassembled. Apparently Vorshlag accidentally included an F22 OEM strut top nut, even though I specified my order was for an 2017 F87 M2. I called Vorshlag and they kindly overnighted the correct part at no cost. But I'll be without my daily-driver car for a couple days due to the install delay, which is resulting in $150+ in Uber rides (from the shop and to work) and lots of wasted time. I won't be surprised if my shop tacks on another hour of labor ($115) for the troubleshooting. If I could go back in time, I would just purchase the Ground Control plates. With that life choice I'd still have: 1) a semi-fresh set of front tires 2) $265+ in my pocket 3) some hours of my life back
2017 F87 M2: MGM, 6MT, AA Tune, Eibach Pro-Kit, Fabspeed Catted Downpipe, Evolution Racewerks FMIC+Chargepipe, Autosolutions SSK, CDV Delete, Vorshlag Plates, PFC-08 pads, Apex EC-7 18x9.5"
2013 E92 328i M-Sport: BSM, 6MT, 3IM+AA Tune, BMW PE, M3 control arms, Eibach Pro-Kit, Bilstein B8, BMW SSK, CDV Delete, Apex EC-7 18x9" |
10-20-2022, 10:25 AM | #85 | |
Rep 1,337
[COLOR="Red"]personally I still believe you made the correct decision[/COLOR]
fleetfoot130.50 |
10-22-2022, 01:08 PM | #86 |
Rep 226
So I've finally got the Vorshlag plates installed. I aligned the front to -2.8 degrees of camber and 0.04 total toe. No issues with NVH. I will say it's a little more work to keep the car straight on the interstate, but not too bad. My tires are still brand new, so no comments on performance yet.
The shop mentioned that the springs didn't seat properly on the camber plates the first time they took the car off the lift. They raised the car back up and manually guided the springs onto the plates with a pole or something like that, but it required 2 people. I'm planning to have my car jacked up regularly while swapping pads by myself, so this sounds like it could be a major pain. I reached out to Vorshlag and asked if I could let the spring not seat properly, and then drive a couple turns until they drop into place, and they said there wouldn't be any risk from doing this, there would just be a loud clang when the springs drop. Does that approach seem reasonable to you all?
10-22-2022, 06:39 PM | #87 |
Rep 1,337
fleetfoot not sure on your setup but with a bit of toe in as you have it shouldn't wander to much.
If you are running c/o without helper springs then maybe look into this as it will stop the spring unseating at full droop.
10-23-2022, 12:28 AM | #88 | |
Rep 557
