06-02-2021, 02:59 PM | #68 | |
Rep 1,821
Tool32 -> connect to car (ENET or K+DCAN) with ign on, load S55.prg -> find job steuern_soundtuning_deak, enter 1 in the argument box, and run job once. This is likely the routine that bimmercode or bimmerlink are using. In Tool32 the job status_soundtuning_deak will tell you if it's active (0) or burble inactive (1)
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. Last edited by Enabled; 06-02-2021 at 03:11 PM.. |
Capt Canuck704.00 agent_orange152.00 |
06-07-2021, 04:47 PM | #69 | |
Rep 331
So in Bimmerlink-> Sound Tuning
Does ON mean - Pops and Bangs are ON or does OFFmean Pops and Bangs are ON Recently acquired 21 M2C (2nd owner) and car has zero pops and bangs so far in sport or sport plus :/ Quote:
__________________________________________
SOLD: 2015 M4 coupe Tanzanite Blue/Full Black/Black 19s/CCBs/6MT |
06-07-2021, 05:02 PM | #70 |
Rep 842
06-07-2021, 07:22 PM | #71 | |
Rep 331
06-07-2021, 08:07 PM | #72 |
Rep 1,681
Slightly off topic but if I am to purchase an app to do this and other coding is bimmerlink or bimmercode the same or is one superior?
Current: ///M2C
G01 X3 xDrive30i Past: ///M2 997.1 Turbo ///M3 E92 |
06-07-2021, 08:09 PM | #73 | |
Rep 1,821
Bimmerlink focuses on diagnosis (and the burble "soundtuning" setting) and Bimmercode is for coding changes to the car settings (but not burble / pops settings)
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. Last edited by Enabled; 06-08-2021 at 09:27 AM.. |
06-07-2021, 11:17 PM | #74 |
Rep 638
Drives: M2C
I used BimmerCode to disable ASD / fake engine noise and BinmerLink to disable the exhaust burbles.
Annoying to have to pay for two apps but oh well. |
06-08-2021, 07:21 AM | #75 |
Stay Ripping
60
Rep 547
I was able to disable ASD and burbles with Bimmerlink. It also kept the changes.
THE GOBBLER- S.O.H
06-08-2021, 02:11 PM | #76 | |
Rep 22
06-09-2021, 05:45 PM | #77 |
Rep 1,681
So after some digging around it seems that bimmerlink doesn't actually save your settings once you turn off the car. If I purchase the app and set my flaps to open all the time, will it revert to default after I disconnect and turn off the car?
Current: ///M2C
06-09-2021, 08:26 PM | #78 |
Rep 36
It must, because I disabled burbles once, and havent plugged in the obd unit once since. Burbles remain off. This was months ago.
06-10-2021, 06:53 PM | #79 | |
Rep 341
Drives: 2020 M2, 6MT
06-10-2021, 09:49 PM | #80 | ||
Rep 638
Drives: M2C
But TUNEDM3 above said that BimmerLink did keep their changes for ASD. So idk - YMMV. I guess I'd start with buying BimmerCode since you'll for sure need that for the burbles ("sound tuning"). Then try to use it for ASD. If it works for ASD - great! If not, then get BimmerCode 🤷*♂️ |
06-11-2021, 07:06 AM | #82 |
Rep 1,681
I think that is only possible with a tune.
Current: ///M2C
06-12-2021, 06:39 PM | #83 |
Rep 36
Ah that makes sense. I used Bimmercode for everything except using link for burbles, so everything I changed has stuck without the need to have the app/adapter going.
06-12-2021, 06:53 PM | #84 | |
Rep 1,821
Unsure if there's a way for that dme in this manner.
06-13-2021, 09:14 PM | #85 |
Rep 17
I'm 21 and embarrassed by the burbles haha. I wish it was as simple as fiddling with some setting in iDrive. Thx for making this thread, right when my factory expires I'm puttin an end to them.
06-13-2021, 09:23 PM | #86 |
Rep 842
FWIW, I'm still under factory warranty and have Bimmerlink/Code. No mention of factory warranty being voided when I brought it in for break-in service.
06-14-2021, 12:14 AM | #87 |
Rep 638
Drives: M2C
I gotta say despite being happy without having burbles 99.9% of the time, I find myself sometimes wishing they were there.
It would be pretty neat if I could make it so that burbles are off in Sport mode but on in Sports+. Would work perfectly for me since I'm usually not in Sports+ while buzzing around town. |
BSM2C16.50 |
06-16-2021, 02:54 PM | #88 | |
Rep 604
If you're on bm3, they just released an update and you should live burble adjustment.
