10-05-2022, 06:23 PM | #45 |
Rep 90
I got everything mostly quiet…
Stock sway bar end link was slightly loose , one on each axle. Camber plates do make noise when loading/unloading the front suspension….driveway to street curbing at almost full lock. Driving down the road I don’t hear anything. The helper springs would solve the problem. Stock M2C wheels and tires. 10 mm spacer up front. Roughly -3 on front camber. |
10-05-2022, 07:31 PM | #46 | |
3890
Rep 54,575
Drives: F80 M3
We are a dealer for TCKR so feel free to reach out to us. |
10-10-2022, 10:31 AM | #47 |
Rep 90
I installed the 400/700 after first trying the 300/600. Also installed a Whiteline front sway bar. TCK recommended street stock settings still very soft imo. Prob need somewhere in the middle of street and track settings. I honestly think a DD car would probably need to be in the 500/800-900 range.
My only real issue with the kit is the front camber plates, or lack of tension on the front springs. Turning the wheel is making noise in the camber plate area....sounds like binding springs. I really doubt it is supposed to be like this. I went with the TCK kit because it came with camber plates, but not I think I prob should have went with Vorschlag for the bearings? Any advice for me? Thanks |
10-10-2022, 12:05 PM | #48 | |
Rep 391
I agree with you on the spring rates. Could be a little stiffer, but I don't the way they ride now. Very comfortable for my use. |
10-10-2022, 08:06 PM | #49 | |
Rep 647
Problem is after it being completely gone, after 500 street miles I’m getting hints of it. To be clear, it was undriveable before so this isn’t the same thing at all, but now that I’m familiar with what spring bind is my radar is up and I definitely have detected the faintest bit of it in very rare circumstances. It’s tolerable for now, but I’ll be moving on to MCS with Vorschlag plates at some point down the road. |
10-11-2022, 08:59 AM | #50 | |
Rep 90
Last night, had the car in the air for the AA EL mid pipe install. Turning the front wheels left and right, the top not and strut sharf turn, and the spring is also trying to turn, just grinding on the lower perch....seems wrong to me? I had to replace the bearings on the stock mounting hats on my e46 M3, and the car was on Bilstein B16s, I had a binding issue. Would you say the problem is likely my bearings? Thanks! |
10-11-2022, 10:14 AM | #51 |
Rep 1,614
I was going to get some TCKlines next year but don't love that so many people are having issues, even if not major issues I still don't want to deal with noise, ect and have to go back to the shop to fix issues.
What is known to be the best coilover setup and by best I mean that has the least issues after installation (apart form the MP one which seems pretty tried and true), I guess KW3s? since they are basically the same as MP + the vorschslag plates? |
10-11-2022, 12:46 PM | #52 | |
Rep 1,263
I have ended up adjusting the shocks 1/2 way between full soft and the recommended track settings. Perfect for me As for the spring binding issue....mine will do it once in a blue moon. Usually right after its been sitting in my garage for a few days. Nothing that bothers me.... I've had TC Kline setups on all 3 of my M cars. E36, E46 and F87. Very solid, reliable C/O's
goforwand69.50 |
10-11-2022, 04:49 PM | #53 | |
Rep 90
It sounds like I did everything correctly, but it's possible the sleeves fell out right before I got the strut piston back into the camber plate. When I switched springs I just took off the piston/shaft nut and left the camber plate in place. They could be in front of my driveway somewhere.... Anyway, my improper wrenching skills shouldn't deter someone from using this system. The 400/700 and current settings are great! Honestly, the 300/600 with track settings and 400/700 close to track settings are a better, more controlled ride than stock. The customer service from TCK is better than 98% of any other retail purchase experience I have had. |
10-11-2022, 08:51 PM | #54 |
Rep 647
Glad to hear you’re working on a solution. I’m confident you can get it sorted. I’ll echo your sentiment on TC and the brand as a whole. I may eventually move to MCS but I’m incredibly happy with my TCK setup. I daily this car and it rides like a dream. You read of weird noise issues with KW and Ohlins so it kinda just comes with the territory I guess.
10-15-2022, 11:43 AM | #55 | |
Rep 90
Bearings in camber plates were mostly stuck, mostly freed now. Less noise/binding. Will likely need at least one new bearing. Best fix without new different design plates, my plan of action… Helper springs with couplers between TCK and helpers. Problem a pair of these on the bottom of the front TCK springs….in between the springs and lower perch. Fwiw, I’m running stiffer than the track settings on the street and everything is very well controlled with the 400/700 springs. Just wanted to share my experiences, journey to help anyone else out…. https://www.bimmerworld.com/2-5-Torrington-Bearing-Kit.html https://www.bimmerworld.com/2-25-Spring-Thrust-Sheet-Set.html |
10-15-2022, 11:55 AM | #56 | ||
Rep 35
Drives: LSB E46 M3, AW F87 M2, Model 3
The 400/700 in my opinion should be the tck standard coils for the f87 m2.
I have a white f87 m2 and a blue e46 m3
10-17-2022, 08:41 PM | #57 |
Rep 647
Was also looking at those thrust sheets. A new set of bearings solved this 99% but if I were redoing the fix I’d throw the thrust sheets in for hood measure. Only reason I didn’t was I ordered the wrong size.
10-19-2022, 09:03 AM | #58 |
Rep 408
10-19-2022, 03:07 PM | #59 | |
3890
Rep 54,575
Drives: F80 M3
TCKR is typically 60mm. |
10-25-2022, 04:11 PM | #60 | |
Rep 90
Unfortunately, 400/700 is too soft for me. I bought 500/800, Eibach coupler with a hyperco helper. Of course you guys can all guess what happened to my ride height.... Front spring perch is all the way lowered and I still have way too much of a gap between the top of the front tires and fender. Ordered a pair of Eibach 5.1" high coils..... My lesson for the day (which I can never get through my head), pay extra and get exactly what you want the first time. I prefer the stance of the pic with the stock wheels on the car. |
10-28-2022, 03:14 PM | #61 | |
3890
Rep 54,575
Drives: F80 M3
No, the bearings in the E46 M3 front strut mounts are housed in a plastic housing. You will still need to run Swift stainless steel thrust sheet between them and the springs to keep them from cracking and falling apart. Swift thrust sheets are the way to go. Thrust bearings won't survive daily use. |
03-06-2024, 08:48 AM | #62 |
Rep 87
Coming back to this thread as it seems alot of other TC kline users posted in here. Curious on ride height settings for 18" and 19" wheels with the SA/DA 300/600 setup TC offers.
My current issue is extreme wear on the inside of the front tires. I have the camber plates all the way out, so I can't adjust that. When I went to measure front ride height, the front left and right were .75" of an inch different??? I'm going to raise the one side so they match, then once I get new tires on will get an alignment done. What is everyone running their ride height at with the TC suspension? I have noticed members with the Mperformance suspension run at about 595/600 and on 19's the fender gap looks perfect. I'd love to achieve that look but I don't want alignment and camber to affected by ride height to the point my tires are not wearing properly. I will get pics of my tire wear to show if this normal or not. edit: just want to add, I love the TC kline setup in terms of driving, 30,000 miles with no other issues and a great handling ride. |
03-06-2024, 12:45 PM | #63 | |
Rep 604
For 19s and stock tires, 595/600 looks great and is a solid reference point. TC setup sheet calls for .25in (6.3mm) higher rear than front for rake but otherwise says “set to taste” so that’s my recommendation here. Dropping down to 18s, even with tires that have an OD within 5% of stock I have noticeably bigger fender gap. It just is what it is. It’s doesn’t look bad enough to matter to me and actually supports more aggressive curb use on track. Last edited by ThreeStripes; 03-06-2024 at 06:20 PM.. |
03-06-2024, 01:31 PM | #64 | |
3890
Rep 54,575
Drives: F80 M3
03-08-2024, 09:50 AM | #65 |
Rep 604
Just realized BMW recommends roughly 20mm additional drop for cars on 18s instead of 19s. Looking at my car moving between 19s to 18s, this checks out.
