02-14-2022, 06:45 PM | #45 |
Rep 4,218
Go with V2, it fits. No reason to go V1, I don’t even know why the sell it.
04-28-2022, 09:38 PM | #47 |
22186
Rep 8,725
Somebody just hit me with rep on this thread
I will simply say this was one of my favorite modifications to my OG Really opens up the engine in the higher RPM and helps it pull strongly all the way to redline
Sundinisagod115.50 pal437.00 |
04-29-2022, 11:22 PM | #48 |
Rep 1,389
It's an incredible mod IMO. Amazing what BMW left on the table. Considering how highly strung they kept saying the whole setup was with the N55 in the OG.
///M TOWN22185.50 Sundinisagod115.50 |
04-30-2022, 12:51 AM | #49 | |
22186
Rep 8,725
I'd consider them both must have items
05-22-2022, 09:13 PM | #52 |
Rep 753
Nice discussion. Sounds like it improves throttle (and turbo) response and opens up the top end a bit more. Sounds like a must do. Has anyone dyno'd before and after with this inlet pipe?
05-22-2022, 10:41 PM | #53 | |
22186
Rep 8,725
I personally have never dynoed my OG I started off with this inlet as my first mod aside from an AFE filter and a Charge Pipe Huge difference… And I was lucky to have a 300 mile return drive home after the install because I was visiting a buddy out of the area and used his lift while visiting Next I installed a BMS Intercooler Also a huge difference in overall drivability And then finally I did a TurboSmart DV Once again the car is better to drive Stock tune, it's just astonishing
pal437.00 ///MPhatic14183.50 |
05-23-2022, 09:01 AM | #54 | ||
Rep 753
Did the turbosmart DV add any additional noises and pssshing and whistling? Not a fan of those noises. |
///M TOWN22185.50 |
05-23-2022, 10:52 AM | #55 | |||
22186
Rep 8,725
I can barely hear the TurboSmart I got the plump back version for that very reason
pal437.00 |
05-24-2022, 07:48 AM | #56 | |
24492
Rep 191,487
05-24-2022, 07:52 AM | #57 | |
The Seeker
14184
Rep 3,426
I don't suppose either require a retune? I'm at BMS2. |
///M TOWN22185.50 |
05-24-2022, 08:06 AM | #58 | ||
22186
Rep 8,725
I'd retune to pick up the benefits
05-24-2022, 09:02 AM | #60 | ||
24492
Rep 191,487
The higher flow will improve the performance automatically
///MPhatic14183.50 pal437.00 |
05-24-2022, 10:19 AM | #61 |
22186
Rep 8,725
Your stock ECU will adjust to the changes
05-24-2022, 02:15 PM | #62 |
Rep 7,540
No tune needed, the car will be able to adapt to the increase in air flow from the inlet, and the dv doesn't need a tune.
05-25-2022, 07:32 AM | #63 |
Rep 753
Thoughts on the turbosmart DV vs a GFB? I've had a trouble free experience and long service life with the GFB on my TT RS with a hybrid turbo and was leaning towards that for the M2. Also, seems like a time saver to do the DV when doing the inlet right?
05-25-2022, 09:09 AM | #64 |
24492
Rep 191,487
Never had an issue with either brand but the turbo smart is the more popular option now
pal437.00 |
05-25-2022, 09:47 AM | #65 |
Rep 7,540
I personally chose the gfb over the turbo smart, it's a bullet proof design utilizing upgraded parts where needed (the valve and piston) and retaining parts that are bullet proof and known to be reliable (the pierberg magnetic solenoid aka the electronic components). There are zero issues with clearance and or things touching hoses, and there is zero compressor surge.
pal437.00 |
05-25-2022, 11:22 PM | #66 | |
a coffee drinker
96
Rep 162
Seems I may finally get around to installing the GFB DV+ How did you know about some "early" versions having too long a plunger spring? Purchased from Mike@XPH. Specs or part nos. would be cool. Thanks! |
