06-16-2021, 01:23 AM | #45 | |
Rep 303
06-16-2021, 09:35 AM | #46 | |
Rep 266
Drives: '89 Land Cruiser, '18 M2
It would be fine with a 285/30/19, I am rubbing at high mph, large sweeping bumps. The -2.6 camber definitely helps a ton. I have a roller and a heat gun, and plan to mold the liners the best I can. I dislike rolling lips (had to do it on my WRX, STI and Golf R), and don't love the change in geometry that it causes on the lines down the side profile of the vehicle.
06-16-2021, 01:04 PM | #47 | |
Rep 303
bngcruiser277.00 |
07-13-2021, 08:58 PM | #48 | |
Rep 346
07-13-2021, 09:01 PM | #49 | ||
Rep 100
Drives: '21 A90 Supra 3.0, '11 E92 M3C
2021 A90 Supra 3.0 Nitro Yellow, 2011 E92 M3 Comp Jerez Black
Instagram @hans.device |
M2RAW121.00 |
07-13-2021, 09:07 PM | #50 | |||
Rep 346
07-13-2021, 09:10 PM | #51 | ||||||||
Rep 100
Rears are the same as before. For track use, I take the spacer off the rear and run a 12mm front to clear the strut. Most of the rubbing issues I'm having is coming from the 275 RE71R being too aggressive of a tire, especially with that really wide and square sidewall. Rubbing has gotten significantly less as I played around with damping and ride height, and it's at a point where I don't rub on a daily commute so I live with it
M2RAW121.00 |
07-18-2021, 02:57 AM | #52 | |
Rep 303
Loads of room with stock tyres I’d like to run 265/35 front and 285/35 rear but know this is a bit tricky, I wonder Is 255/35 f and 285/35 r will dial in too much understeer. Not super impressed with the additional camber and top plates I’ve added a bit of NVH for some increased precision and a tad better turn in but overall the understeer bias is broadly the same |
07-19-2021, 05:24 PM | #53 | |
Rep 266
Carrera2RS204.00 |
10-25-2021, 01:37 AM | #54 | |
Rep 204
11-22-2021, 08:31 PM | #55 |
Rep 569
Hey guys, looking to get on a set of Te37's on my OG M2.
Ideally I want to move to a 18x9.5/18x10.5 setup. I am on Msport coils at the suggested height without any aftermarket camber plates. I want to avoid rubbing as I drive canyons fairly hard but do not track the car at all. 1. Is this a viable setup size wise, if so what offset should I be going for? 2. If it is not viable, then what offset should I look to for a an 18x9.5 square setup or 18x9.5/18x10 setup? Thanks in advance. |
11-29-2021, 05:54 PM | #56 |
Rep 266
4
02-28-2022, 04:25 PM | #57 | |
Rep 57
02-28-2022, 04:47 PM | #58 |
Rep 183
A little late to this thread but here's an old pic. The car doesn't really look like that anymore though.
TE37RT Black Edition 18x9.5 et22 with 265/35/18 Advan AD08R (square setup) DSC03719 edit by bykevinlee, on Flickr
IG: bykevinlee
05-03-2022, 08:38 PM | #60 |
Rep 130
Had to add to the collection
Formula Silver 18x10+25 square 265/35 Continental Extreme Contact Sport
8
-Eidos495.50 WedgeSalad317.50 chasebish49.50 Carrera2RS204.00 aftercorbu404.50 leopard print1569.50 TUDMG24.00 shaneguags1197.50 |
05-04-2022, 12:29 PM | #61 |
Rep 28
my god... beautiful wheels
Yadadameans158.00 |
05-10-2022, 07:50 PM | #62 |
93
Rep 214
anyone know the spec needed for M2C stock brake setup.
2016 M3 Silver Stone DCT (gone)
2017 Nissan GTR (gone) 2019 Audi RS3 (gone) 2019 M2C HS 6MT (sold Aug '22) 2020 Nissan GTR 50th(Current) |
05-10-2022, 08:32 PM | #64 |
93
Rep 214
Dang so only way to do TE37s would be swapping front brakes, dang.
05-14-2022, 06:21 PM | #66 |
Rep 160
Drives: 17 M2, 23 Ford F150 Raptor
Same specs as OP. 18x9.5 ET38 with Falken RT660 265/35/18.
Since these are actually Civic Type R spec wheels, I am running spacers. 12mm Motorsport Hardware spacers all around.
Current: 2017 Alpine White M2 DCT, 2023 Ford F-150 Raptor
Past: 2015 Lexus IS 250, 2014 Volkswagen CC R-Line |
4
